Question about Maytag 24 in. MDB7600A Jetclean® II Built-in Dishwasher
Control buttons don't work, Help.
I have a Maytag MDB7600AWB dishwasher that is about 4-5 years old. Problem started as wash cycle would not start. Then I saw that pressing other buttons that some of the them would not illuminate the little lights that come on to show activation, but others would. The delay start lights would come on, but the cycle would not start after the indicated delay time passed. I suspect that the problem is with the control board, but I would like to know if anybody else has had a simular problem and what it took to fix it. Thank you in advance for your help.
  • 4 more comments
  • Anonymous Jan 13, 2008
    I have a MDB7601AWW with the same condition.
  • Anonymous Jan 21, 2008
    I have the same problem with Maytag MDB7601AWW. I called Maytag and was told nothing on my machine is covered after 1 year including the circuit board and touchpad.
  • Anonymous Jun 22, 2008
    I have the same problem on my Maytag MDB7601AWW model. My dishwasher will work on the "normal" cycle, but I cannot use the "heavy wash", "light wash", "rinse only", or the "insta wash". The options panel allows me to select "sanitize", "hi temp wash" and "tough scrub plus", but not the "heated dry" option.
  • jebkernion Jun 27, 2008
    My problem was similar to donsson. My MDB7601AWS display would not light up when I pressed the buttons to select the cycle, but the "2H" would light up after start was pressed. Now, after a few months of this, no lights come on but the cycle usually runs. I will try the solution presented and report back. Thanks for the help, Cat
  • richmckee Nov 14, 2008
    I have the same problem with control buttons. I tried the solution of cleaning the ribbon to no avail. I cannot find directions on checking to keypad or control panel as indicated in the solution. Thus far only the front door panel timer light is working. Any other suggestions?
  • mjr1075 Apr 05, 2009
    We have a very similar problem as all of the above....
    When we go to select normal wash and press start the machine will start and then a few moments later will swith to a 9min rinse cycle. None of the buttons will work at that point. We can not cancel or switch it back. It was an intermitent issue once before and now does it every time.
    It just had a check up a few months ago and was fine. We had sears come in for a routine before our ext. warranty ran out.....of course it is now no longer under warranty!!!
    Any suggestions out there?
    President:
  • 878 Answers
Donnson, sounds more like the touch panel shorted or stuck keypads. You can remove the touch panel ribbon from the control board and try to clean it with an eraser. You will need to remove the torx screws and remove the inside panel. See if it comes back to life. Behind the toe-panel on the bottom, there should be a tech sheet showing how to check the key pad. The key pad and control board are warranteed for 5 years on this model, parts only. Catriver..post back.
Posted on Jan 08, 2007
  • DCDAWG Jul 17, 2011
    That did the trick !! Thanks :) I took off the panel removed the ribbons from control panel and cleaned both ribbons , put it all back together and it worked ! Thank you again!
Dishwasher will not start. All option buttons light up except the Start/Stop button and the cancel button. I have turn the power off and on but still no wash cycle. Inside float is clear and so is spray...
Hello, I am sorry that your dish washer isn't working. One of the biggest problems with these new dishwasher is they install the control on top of the door and the operational circuit board below the control panel. Inside the door is acceptable to moisture which creates all kinds of problems. It not the spray arm or the float, or the pump. it is where they put the circuitry to control the dish washing machine.
I hoping that all you will need is a push button control strip for this dish washer. moisture get in the micro switches and make them inoperable. These button in the control strip are hermetically sealed against moisture....for a while.
Remember, it depends on how long has the dishwasher been working and what will be the cost to repair your dishwasher. Dishwasher are really good for 10 to 12 years of service. I worked on a Kenmore that was 25 years old. I told the lady of the house it is time for a new dishwasher. I could have repaired it, but really it not worth it when it is this old. GB...stewbison
Sep 06, 2011 | Maytag Dishwasher
Flashing lights on Maytag dishwasher
Check whether the door is getting closed fully. Try pushing little hard. If the door close switch problem it may work.
Contact service for help if u can not proceed further with electrical circuits. Micro-controller board to be checked!
May 18, 2010 | Dishwashers
Maytag DWU6602AAE. My Maytag dishwasher (14 years
SOUNDS LIKE A TIMER PROBLEM. YOU MAY WANT TO PRICE A REPLACEMENT TIMER. AND PRICE OUT NEW DISHWASHERS. GOOD LUCK!
If you need further help, I’m available over the phone at https://www.6ya.com/expert/dude_653d05454b389bba
Feb 25, 2010 | Dishwashers
Control panel lights blinking
I have the same dishwasher with the same problem, try pushing the delay/resume button, then the drain/off button. When the lights go off start your wash cycle.
Sep 17, 2009 | Maytag 24 in. MDB5600A Jetclean II...
Control panel lights but won't start
the front control panel fries out.. We had to have ours replaced after 7 months ... after that was replaced it only lasted 2 months... WE ARE VERY disappointed and will be calling once again tomorrow. The dishwasher is not even a year old yet!
Aug 16, 2009 | Maytag MDC4650AW Built-in Dishwasher
Dishwasher only runs for 21 minute cycle
I bought and replaced the control board in the door. $145 CAD it took 5 min saved myself $300
May 07, 2009 | Dishwashers
Kenmore Ultra Wash Dishwasher LIghts are blinking....
I suspect for either of these units that the timer control boards are bad.
Jan 24, 2009 | Dishwashers
Maytag 24 in. MDB7600A Jetclean® II Built-in Dishwasher Logo
1,805 people viewed this question
Top Maytag Dishwashers Experts
Carmen Mikulic
Mike
Marvin
Marvin
Are you a Maytag Dishwasher Expert? Answer questions, earn points and help others
