Question about HP Office Equipment & Supplies
How do I stop a black line appearing on the copy of an original document
  • mangrove460 Nov 26, 2008
    Many thanks for the solution, sadly there is no problem when i use the glass area. The problem occurs when the sheet feeder is used. As the original goes in, the copy comes out with a line down the page from top to bottom
    Problem Solver:
  • 7 Answers
Try this- Make sure the whole glass area of the copier is covered with white paper,
ie. lay the document face down, and any glass area you can still see- cover with sheets of blank white paper
Good luck
Posted on Nov 26, 2008
Bizhub C652 has horizontal lines.
its important to find out whether the \'lines\' are in scan direction/ or only through Radf or only from scan glass,
if the lines are only showing when documents are fed throught the Radf, then the problem lies with the document scan plate( left of the main glass platen (about 2" in width)) or with the scan plate blade cleaner
if the lines ONLY appear when copying from the Glass then the issue lies within the optics (probably nothing more than a clean will be needed)
another question would be to ask if the lines are solid (black line overprinting image) or if they are \'missing\' lines where the image has failed to copy, sometimes it can be hard to work out which side the fault lies,so try shaded greys as a copy original .
if the scan lines are appearing on both Radf and Glassplatten ,mode then the issue may be dirty optics/ccd sensor or it could e an indication of the ccd failing or image control pwb in error while interpreting the image file.
what to do
1) place a grey sheet of paper in the Radf and have the copier photocopy both sides of the original and print to single sided sheets ( so the printer turns the original over to complete the task)
observe the result.
2) have the copier photocopy directly from the platten glass- single sided.
observe the result.
ckeck to see if the error has appeared on both sets of prints ,
if the error has only appeared in the first set of prints then the issue may be a tiny DOT on the slit glass (left of platten) - a dot on this glass will indeed appear as a Line as the original is scanned across the glass.
hhope thhis helps
Feb 19, 2014 | Konica Minolta Bizhub C652 Color&b/w...
Black lines on copy only when printing but copying is ok i.e km 1650
If this only occurs when using the document feeder then you will need to clean the smaller glass that sits next to the large glass that you manualy place your documents. The document feeder scans the originals over the small glass and any ink ,whiteout that may be on the glass will appear as lines down the pages
Oct 24, 2013 | Kyocera Mita Office Equipment & Supplies
I have a Ricoh Aficio 1013 that prints fine but copies are unclear and off
Problem Cause Solution Colored lines appear. The exposure glass or scanning glass is dirty. Clean them. See "Maintaining Your Machine", About this Machine . Copies appear dirty. Image density is too high. Adjust the image density settings. See "Adjusting Copy Image Density", Copy and Document Server Reference . Copies appear dirty. Auto Image Density is not selected. On the control panel, select [Auto Density]. The reverse side of an original image is copied. Image density is too high. Adjust the image density settings. See "Adjusting Copy Image Density", Copy and Document Server Reference . The reverse side of an original image is copied. Auto Image Density is not selected. On the control panel, select [Auto Density]. A shadow appears on copies if you use pasted originals. Image density is too high.
  • Adjust the image density settings. See "Adjusting Copy Image Density", Copy and Document Server Reference .
  • Change the orientation of the original.
  • Put mending tape on the pasted part.
The same copy area is dirty whenever making copies. The exposure glass, scanning glass, or ADF is dirty. Clean them. See "Maintaining Your Machine", About This Machine . The same copy area is dirty whenever making copies.
  • The original that has already been printed is scanned.
  • Original Type is set to [Text / Photo], and an original with text and photographs that can hardly be distinguished from each other is loaded.
On the control panel, press [Generation Copy], and then begin copying. Copies are too light. Image density is too light. Adjust the image density settings. See "Adjusting Copy Image Density", Copy and Document Server Reference . Copies are too light. A light copy may result when you use damp or rough grain paper. Use recommended paper only and be sure its storage environment meets the recommended temperature and humidity conditions. For details about recommended paper and the proper way to store it, see "Recommended Paper Sizes and Types" and "Paper Storage", About This Machine . Parts of images are not copied. The original is not set correctly. Set originals correctly. See "Placing Originals", Copy and Document Server Reference . Parts of images are not copied. The correct paper size is not selected. Select the proper paper size. Parts of images are not copied. Even if you place originals in the ADF correctly, margin of a few millimeters on all four sides of the original might not be copied. Use "Create Margin" function to reduce the image of its original size.
For details about missing image area, see "Missing Image Area", Copy and Document Server Reference . images appear only partially. The paper is damp. Use paper that has been stored in the recommended temperature and humidity condition. For details about the proper way to store it, see "Paper Storage", About This Machine . Black lines appear. The exposure glass or scanning glass is dirty. Clean them. See "Maintaining Your Machine", About This Machine . White lines appear. The exposure glass or scanning glass is dirty. Clean them. See "Maintaining Your Machine", About This Machine . White lines appear. The dustproof glass is dirty. Clean the dustproof glass. See "Cleaning the Dustproof Glass", About This Machine . Copies are blank. The original is not set correctly. When using the exposure glass, face the originals down. When using the ADF, face them up. A moir? pattern is produced on copies. Your original has a dot pattern image or many lines. Place the original on the exposure glass at a slight angle. Black spots appear on the copy of a photographic print. Because of high humidity, the photographic print has stuck to the exposure glass. Place the print on the exposure glass in either of the following ways:
  • Place an OHP transparency on the exposure glass, and then place the print on the OHP transparency.
  • Place the print on the exposure glass, and then place two or three sheets of white paper on it. Leave the ADF open when copying.
White stripes appear on the OHP. Fragments of paper are stuck to the OHP. Use a dry cloth to wipe any paper fragments off the back of the OHP. The image on the back side of duplex copies has mottled blank patches or is smudged. Missing patches and smudges are caused by moisture leaking from the paper.
  • Do not install the machine in areas that are susceptible to low temperatures.
  • Use paper that has been stored where temperature and humidity conditions meet the limitations we recommend. For details about the paper storage conditions we recommend, see "Paper Storage", About This Machine .
  • Install the Optional anti-humidity heater. For details about the anti-humidity heater, contact your service representative.
When You Cannot Make Clear Copies
Feb 02, 2018 | Ricoh Aficio 1013 All-In-One Laser Printer
I recently installed a new laser cartridge. Shortly after, when copying a document, two black vertical lines began appearing on the copy. What is the fix for this? The black lines do not appear when...
Clean the scanner glass. When I had that problem, I set a copy with lines on it in the scanner feed to see where the problem was, and when I lightly ran my finger on the glass over where the lines were, I could feel two small bumps. I just scraped them off with my fingernail, but here is the HP solution for cleaning your scanner glass:
http://h20000.www2.hp.com/bizsupport/TechSupport/Document.jsp?lang=en&cc=us&taskId=125&prodSeriesId=378048&prodTypeId=18972&prodSeriesId=378048&objectID=c00062196
Aug 24, 2010 | HP LaserJet 3015 All-In-One Printer
We have a black line down the center of all copies...
If the problem only happens on copies or sent faxes then no it is not your drum. There is something on your scan glass. My guess is you are getting the line on your copies when you run the original through the document feeder. If you get lines through the document feeder but not on copies made off the glass then it is a dirty scan glass. There is a thin glass strip where the document feeder feeds the original. Usually something like white out that did not dry smears off an original and ends up on this thin strip of glass. Scratch it off with your finger nail and use some glass cleaner to resolve the problem. The scan glass is about 1/2 an inch to an inch wide and will be on the same side of the machine that the copier feeds the originals in on
May 20, 2010 | Office Equipment & Supplies
Horizontal black and white lines are coming on copy
you don't mention whether the document you are copying also appears on the paper.If it does you could have 1 of 2 problems-
The drum cleaning system could be at fault or-
the fuser roller has picked up some **** easy test...... run copies and when the 1st copy edge appears switch OFF. This is a crash stop.Now examine the sheets in there.Is the stripe on the copy before the fuser (Heat) roller? If yes you could have a drum cleaning problem, usually fixed by changing the drum module.If no and the stripe appears after the heat roll, the problem is with the fuser system,dirty rolls etc. There are a number of other problems with stripes, but you have to start somewhere! If the document does NOT appear on the copy, forget all above, could be scan or ROS problem
Jul 20, 2008 | Sharp AR-5320 Black and White Copier
Black Line Down Center of Page
I had the same problem. I cleaned the strip above the glass and this fixed the problem. Hope it helps!
Feb 14, 2008 | Canon MultiPASS MP730 All-In-One InkJet...
Black lines
There is a thin strip of glass that you will see when you lift the top feeder. There is most likely white-out on it.
When you use the top feeder, it doesn't use the large glass, it only 'rolls' the original document over this small strip of glass.
Jan 18, 2008 | HP LaserJet 2840 Printer
Print Problem - vertical lines
If the problem only occurs when using the document feeder, the problem is not usually caused by the drum. When using the document feeder, try to notice where the scanner (the light assembly under your scan glass)stops just before the paper is being fed. Some multifunction machines have a small piece of glass that is separate from the large scan glass and the scanner assembly stays parked underneith it as the original is being fed over it. Most likely there is something on the glass where the scanner parks as originals are being fed thru the feeder. When putting your original on the large scan glass to copy, the mark on the glass will only show as a spot, but will show as a vertical line thru the whole copy when using the feeder.
Feb 23, 2007 | Brother MFC-7820N Laser Printer
Xerox workcenter XD120f
The small scanner glass (not the full size glass) has some dirt on it. Use a lint-free cloth (not paper) with alcohol or Windex and clean the glass. This should help.
Nov 14, 2006 | Xerox WorkCentre XD120f Copier
66 people viewed this question
Ben Johnson
