Question about FEC RKMV5 Custom Rackmount Kit for JVC RKMV5
When I put certain dvd's it would say I should still insert a dvd.
  • 488 Answers
That happens when u insert a disc of the wrong region,PAL disc in NTSC only player and vice versa or if the disc is damaged and cant be read..hope it helps!
Posted on Nov 26, 2008
Will not recognize disk inserted
Try changing your DVD regional locale. Some dvd/roms will restrict certain media if the locale is set to some other region than your own. The other thing you can do is update the drivers - - this seems arbitrary and you probably hear that often when asking a techie guru... But it is well justified. Also try different brands of dvdrws. Some dvd roms will restrict +rw - rw. Hope this helps.
Feb 15, 2014 | Funai ZV427FX4 DVD Recorder/VCR Combo
Trying to copy a DVD--when I insert a blank DVD, it spits it out and asks me to insert another. I have tried with two different blank DVDs, and each time it spits it out without copying, and asks to...
1. your DVD blank may be rejected due to the program compatibility.
2. the DVD that is being copied was burn at a certain speed and this may have an affect on the
copy of the original.
3. the blank DVD should have the same capacity as the original or better that is if the
DVD blank has the capacity of 4.5 GB and the original is 8.5 GB then the copy has
reached it's capacity and will be ejected by the DVD burner.
I hope this helps. Have a great day.
Oct 05, 2010 | Sonic RecordNow! Deluxe 7.3
When I try to record Vista does not recognise I have inserted DVD or CD when I have inserted a brand new blank disc what is going on?
There is an inherent problem with Vista and certain DVD players. Your DVD player had the drivers knocked out by VISTA. I know one brand of dvd player, panasonic, has this problem I corrected this once for my friend. You don't want to hear this, you will have to call Tech support and tell them about it. They will direct to do the following: 1) You have to go into "regedit' and delete an entry in your computer's registry ( be very careful when working in the computer's registry, there is NOT a "oops" key. Once you delete something is gone for ever. Best to just rename the registry entry by putting an underscore in front of the first character on the line IE. if this is the registry entry insert under score here _heu786lokheihgtkll). 2) Download the drivers again and install a patch. After the entry is made and the driver downloaded, restart your machine and your off and running.
Nov 20, 2009 | Microsoft Windows Vista Ultimate Edition
E drive does not respond when a dvd is inserted in vista ulimate whenever i insert dvd in dvd drive it is not reading what the problem as i have to insert certain program in my pc
This is the problem with DMI Pool Header. U can go to Device manger from Right click My Computer . Over there u can find the processor bus U can check whether DMI has enabled if not enable DMI
THank U
Please rate me as it wil cost u just one click
Oct 23, 2009 | Acer (9005210464), (64 MB) Graphic Card
I've inserted several dvd's and cd's which are not being read with the display stating nodisc.The problem first started with a dvd stopping after showing about 75% of content, and since stopped working...
There can be 2 reasons for this 1. might be a collection of moisture or 2.dust.
For both put the dvd in a warmer room for about 2 hours for(unplugged) and let the moisture evaporate.
Try it again.
If dust is there blow throught the area where the dvd enters.
Also remember you can only play certain discs, and the area code should be correct.
Oct 19, 2009 | Samsung DVD-R155
Philipds tv dvd combo
your best option is to purchase a DVD cleaning disk from someone like Walmart and, clean your laser with it
the law requires certain DVD to only be playable in certain regions the USA is region #1 this is not changable
Apr 28, 2009 | Televison & Video
Will not play some dvd
some tapes you put in mite be made of the computer witch some times does'nt work or your dvd's are scratched up. my old dvd player did that same thing (i bought a new 1 at the end it worked fine after)
Jan 14, 2009 | Emerson EWR20V4 DVD Recorder/VCR
After I insert a dvd disc in the dvd drive, it still asks me to isert a disc in the drive. It seems that it is not able to read the disc. We currently subscribe to netflix. Certain dvd"s whhen inserted...
If it is a hardware fault, a fault in your drive, it occurs on every disk
if it is a disk fault it occurs only when faulty disks are used.
Probably Netflix discs are bad, wrong region code, or scratched, or badly copied
Jul 18, 2008 | Televison & Video
Insert disc code 011-02-1028
It may be compatibility issues with that certain blank dvd media, dvd drive may not have dvd writing capabilities or drive is faulty.
Feb 20, 2008 | Toshiba (SD-R2412) for Satellite A10, A15,...
NEC DVD-RW 16x DL
If you switched to a different brand of DVD's try using the brand you used before. DVD burners are tested with certain brands of DVD's and sometimes the brands that aren't on that list don't work.
Jun 11, 2006 | NEC 16X Multiple Format DVD+/-R/RW/DL...
Televison & Video Logo
83 people viewed this question
Top FEC Televison & Video Experts
Are you a FEC Televison and Video Expert? Answer questions, earn points and help others
