Laptop freezes with startup, sometimes switches off during startu
Problem since new.
System restore no help, obviously.
Error fix on Vista does not fix problem, microsoft do not come back to me on same.
Scanned reg with numerous free downloads, not fixed.
Error messages PXE-E61 and PXE MOF started displaying.
After a few attempts, Windows will start, and no other visible problems
ACER ASPIRE 7720G laptop
  • cyb5 Nov 27, 2008
    Thanks for the info anyway, much appreciated.
    Sergeant:
  • 177 Answers
PXE means Pre Boot Execution. It means that the system is trying to boot from network. To solve this, you need to enter bios. You can do this by pressing F2 during startup. Find the section where you can change boot device order and set the first boot device to HDD or CD. save your settings, hopefully your problem will be solved
Posted on Nov 26, 2008
My laptop turns on then freezes how do i fix this?
The music you have on your computer should have no bearing on your start up problem, this is more likely to be caused by a different area of the system such as a recently installed device or program.
Have your tried starting your computer in Safe Mode - press the F8 function key during the initial boot display and before Windows starts to load.
Further recovery actions will depend on which version of Windows you have installed (XP, Vista or 7).
If you can get into System Restore then you should try restoring the system settings back to a time before this problem started if possible.
If you can't use System Restore but can start in Safe Mode, then download a copy of CCleaner and use this to perform some house-keeping clean-up to get rid of temporary files, clean up registry entries etc as this may help.
If you can't start in Safe Mode then you will need to have access to your Windows installation media (CD or DVD depending on which version of Windows). For Vista and 7 you can try performing a Startup Repair - for XP you may have to do a Repair Install.
Dec 29, 2011 | Dell Computers & Internet
Toshiba Satellite L305-S5875; Recovery Error 10-fc12-045d HELP!!
no it is not fried. you just need to find a vista disk and use that instead of the recovery disks. Once you reinstall Vista you should be able to go online for the Toshiba drivers. Make sure you have the windows Vista Key which should be located under the laptop. the vista software install will ask for it.
Jan 10, 2010 | Compaq Deskpro EP PIII-650MHz/ 128MB/...
Vista Startup problem
Your best bet is to download UBCD4Win This is an operating system that runs on cd that allows you to gain access to the registry and your c: There is documentation on how to put it on a thumb drive if you have one available as well. http://ubcd4win.com/forum/index.php?s=a26bbc11e226fca4a94ffb73a2d66d80&showtopic=9630 Once you download the program you will want to download ISO burner and burn the program to a CD-R. I'm gathering you don't have a disk to reinstall your operating system? Sometimes "Last Known Good Config" can resolve logon problems as well. Good luck!
Apr 09, 2009 | Microsoft Computers & Internet
Blank screen during POST and vista startup
The screen is going bad. Take it to a reputable repair person for a a electronics check out.
Mar 26, 2009 | HP Pavilion dv1000 Notebook
I can't restart my window vista laptop solve plz
Windows Vista is not starting due to missing or corrupt files.
Run Startup Repair using Vista Operating System disc
  1. Place the Windows Vista Media Backup DVD into to the optical drive and start the computer.
  2. Press any key to boot from CD or DVD.
  3. On the Install Windows screen, click Next.
  4. On the Install Windows screen, select Repair your computer.
  5. In the System Recovery Options dialog box, click Next.
  6. In the System Recovery Options dialog box, select the appropriate operating system, and then click Next.
  7. In the System Recovery Options dialog box, select Startup Repair.
  8. The Startup Repair attempts to locate and resolve issues with the computer.
  9. If prompted, Do you want to restore your computer using system restore?, click Restore.
  10. In the System Recovery Options dialog box, click Finish. This screen can vary, dependant on if a problem was found or not.
  11. System restarts.
  12. If the problem was resolved, the computer restarts into Vista.
  13. If the problem was not fixed, the error may present itself again.
  14. Run Startup Repair again.
  15. If Startup Repair runs more than three (3) times, when available, select View advanced options for system recovery and support.
  16. For further troubleshooting, select one of the following options:
    • System Restore
    • Command Prompt
    • Last resort - Recovery Manager. Recovery Manager is not available if accessing WinRE via Vista OS Backup Media DVD
or you can use any software that can repair and recover your windows files.
Best regards
Mar 02, 2009 | Microsoft Windows Vista Ultimate Edition
Repeated freeze in Vista
Press F12 when the DELL logo appears during boot and select Diagnostics from the menu. When the initial memory tests are complete select Express Test and document any errors reported and call DELL with the results.
Dec 07, 2008 | Computers & Internet
Toshiba Sat A135-S2386 System recovery downloads??
i guess that the computer has installed vista ultimate and the creation of recovery cd option has gone with it. the new recovery cd will solve all your problems.
Nov 27, 2008 | Toshiba Satellite A135-S2386 Notebook
Freezing
ok, the dark006 user is right with the F11 on splash startup screen. you do not need any disks 4 it. if you have any more questions, please email me at meanness628@aim.com
Jun 23, 2008 | Acer Aspire 5100 Notebook
SONY VAIO notebook freezes on xp splash screen every 2-4 mos.
first, ensure your system restore is turned on and make a restore point right now!...assuming you have run a thorough disk check and de-frag. then, trust the system restore. I have used it with success 100% of the 20 or so times I have used it. Next, start using the "Hibernate" power down mode. I have found this to work wonders with third-party driver problems. It seems that once a good startup happens, then freeze it (and continue to get a good startup) with hibernate from then on. Last, check about every month for the quantity of restore points that have taken place automatically by Windows. Sometimes, depending on the size of the hard drive, too many points can begin to encroach on your free space that you want for virtual memory or data. So for example, I see 15 restore points in the last month, I will dlete them all by cancelling system restore. Then I use "clean disk" scandisk and defrag. Then I turn restore back on.
Jun 12, 2007 | Sony VAIO VGN-FE790GN Notebook
Computers & Internet Logo
717 people viewed this question
David Payne
David Payne
