Very strange! Assuming no programming has changed: check that all earpieces are tight into the radio. Unplug, check for audio without an earpiece and replug into radio. Make certain your batteries are FRESH (less than 1 year old) and fully charged. I am assuming you are using earpieces approved for the Motorola radio. Many speakers do not work and several earpieces are not designed well. Stay away from the auction site cheap ones. You get what you pay for, including failures. For several audio jacks to fail at once would be very unusual. Try a new earpiece. I suspect earpiece failure more than anything. All tests after this require checking programming and/or taking the radio apart.
Hi ,On the unit and donot put usb or sf card unit will automatic catch fm radio,make your there is fm radio signal is there,if still fm cannot connect that mean unit is having problem,Then go to the seller,Where you bought this .Rgds Sonilex Team.(China )
Your mouthpiece or receiver's earpiece might be not functional. To make sure, please record something and try playing it. If you can hear what you recorded, your mouthpiece is fully functional. Tell the receiver to increase the earpiece volume.Now test whether the receiver earpiece is not working. Tell the receiver to set his phone is speakerphone mode. If he can hear what you say in speakerphone mode, then the receiver's earpiece is not fully functional.
ok first of all you should open your mobile and claen it carefuly.then re pack it care fully.thats it if problem not away then tell agian me i have seen tha pic also but it is for the tecnicians if mobiles.ie mobile repairer
Go to Bluetooth settings and turn on Bluetooth. The paired devices will be shown. Delete paired device or unpair device . This should solve the issue .
Since the mobile is paired with the Bluetooth speaker every time a call comes in the phone automatically connects to the Bluetooth speaker.
Switching off the Bluetooth speaker may also work.
You are combining two different things together.
Firstly you cannot play the Radio without headset and for just playing the radio you need not any Radio Code. Hopefully you need radio code to play Visual Radio. In that case you can play it even without knowing the code. Go to Station Menu in your GPRS connected N70 and then select the Country and the nearest location for getting a list of all FM stations alongwith Visual Radio information, if available.
Alternatively you can get more information about the Visual ID at www.visualradio.com
