Question about LG Flatron L1951S-SN 19" LCD Flat Panel Monitor
My monitor goes black and does not come on to i turn the powe off
Its not the power settings
    Genius:
  • 1,011 Answers
Dear Sir/Madam,
Reinstall the monitor drivers and right click the desktop go to Display properties->Settings->Check the Screen Resolution and select 32 bit color check the screen resolution is 1024X768 if it is not listed there will be the problem with driver software.
Posted on Nov 26, 2008
LG Flatron L227WTG goes to black/dim
Your problem is a very common one. That model uses the Aip-0165 power supply board and when the capacitors on the board start failing if can't power up the monitor correctly so you get a dim picture, after continued use the monitor will fail all the way. Here is a link to a repair guide that will show you what to look for and replace on the power supply board to get it back up and running again.
http://www.ccl-la.com/blog/index.php/repairing-a-lg-l227wtg-pf-22-monitor-no-power/
I hope this helps, if so please rate my solution.
Mar 25, 2012 | LG Computers & Internet
Monitor goes black after about 7 to 10 seconds. I can turn power off and then back on and it will be ok for about 10 seconds before it goes black again.
Check whether the cable from the system to the screen is connected properly and there is not loose contact. Also take the system into BIOS and check whether the same issue is happening in the BIOS screen.Try a factory reset on the screen by pressing the OSD button on the screen.
Switchoff the screen and disconnect all teh cables including the powe cable and press and hold the power button for around 40 sec and now reconnect the cables and try to power up the screen
Jan 04, 2011 | Proview PL926WBi 19" LCD Monitor
When on computer for some time monitor goes black
Adust the "Power Settings" in the Control Panel to never let the Computer or Monitor power off or Hibernate.
Jan 25, 2010 | HP Pavilion a810n (PP164AA) PC Desktop
Monitor goes black when i turn it on
just a big hardware problem in your monitor
Sep 23, 2009 | Samsung SyncMaster 216BW Monitor
No picture on the monitor
try to log into safemode, change the setting of your monitor or install the vga driver if its needed.
I’m happy to help further over the phone at https://www.6ya.com/expert/mustafa_06f84c65ab5cc745
Jun 17, 2009 | Hannspree HANNS G HW191DPB (Black) LCD...
DEAD IIYAMA AS4636D
Hi Sammy7!!
I have such iiyama AS4636D monitor. In this day purchase.
I have such problem with you.
My solution:
Desktop pc and lcd power off (230VAC or 110VAC)
Power on lcd, after early desktop pc.
This moment, when running the pc booting, press and hold you the " + " button.
In this moment come in one blue screen. May be running on the sreen short message: check or select input mode: VGA DVI 1 2 . Select your correct cable connection type.
Have a nice day! and happy new year!
Lajos from Hungary
Dec 13, 2008 | iiyama Pro Lite AS4636D (Black) 18.1 in....
Laptop monitor goes black
If you're working on the computer when that happens, it's not probably a power setting. Try to update your BIOS to the most current version at the toshiba support website (support.toshiba.com) & see what happens. Fixes the issue most of the time
I hope this helps.
Aug 25, 2008 | Toshiba Satellite A100-S8111TD Notebook
Dell 1704 FPTt monitor goes black after about 20 min
Go to Start, Control Panel, Power Options and change your monitor setting to never turn off. If you do leave your monitor on all the time then you should set up a screen saver.
Dec 22, 2007 | Dell UltraSharp 1704FPT 17" Flat Panel LCD...
HP 15 in. Flat panel Problem
plug in a different monitor temporarily, check your display settings (right click background, settings, advanced, monitor) and set refresh rate to 60hz. plug in this monitor again and see if that helps some monitors (lcd's especially) cannot handle beyond 60hz
Aug 14, 2007 | HP vs15 15"LCD Flat Panel Monitor
LG Flatron L1951S-SN 19" LCD Flat Panel Monitor Logo
94 people viewed this question
Top LG Computers & Internet Experts
Alun Cox
Are you a LG Computer and Internet Expert? Answer questions, earn points and help others
