Question about Janome Memory Craft 9000 Computerized Sewing Machine
The bobbin grinds when I start to so
The bobbin makes a grinding noise when I start to sew. Especilly when I am doing a fancy stitch like applique. Once the machine is running, it doesn't grind anymore but evetually the bobbin thread get bound up underneath. I took it into the shop for repair, they reseaded the bobbin case and said it was fine. It still does not work though.
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 84 Answers
Sounds like a bobbin case related problem. Unplug the machine, then remove the needle plate to get access to the black bobbin case. Inspect the underside of it  VERY carefully for ANY marks or roughness. You can expect very fine 'scratches', but no chunks or rough bits.Now check the metal rim that the bobbin case sits on is PERFECTLY smooth. particularly look for any tiny burrs on the top or inside edge of the rim, or any sign of a needle hit. Should not be any! If there are, the mechanic shoul fix it at no extra cost cos he missed the problem. Whilst checking the bobbin case, look for ANY marks on the top surface of it. The SLIGHTEST mark WILL upset the sewing.
Hope this assists!
Posted on Oct 22, 2007
How do I get needle foot out of zig zag mode.keeps jamming and making a grinding noise.?
Try turning the flywheel and changing the stitch selector at the same time. You may be in between stitch settings while trying to sew.
Cheers,
Embroidery Services
San Diego, CA
Sep 19, 2017 | Sewing Machines
My Necchi Sofia 300. When winding bobbin the needle doesn't disengage and the matching makes a dreadful grinding noise as it winds the bobbin
Try putting a small drop of oil on the the metal shaft of the bobbin winder if it is not moving freely. The grinding noise implicates the winder tire may be ground from the locked winder shaft. The needle not disengaging requires oil in the shaft bushing. On this machine it appears you would have to remove the covers to access the appropriate areas.
Dec 05, 2016 | Necchi Sewing Machines
How to applique with my Quilters Dream sewing machine
You should practice on scrap fabric until you can get the technique down well. There are different kinds of applique.
To cover raw fabric edges, you can do a smooth line of zig-zag over the fabric edge. Set the stitch width to a wide stitch and shorten the stitch length until the thread lays nicely next to each other with no gaps of fabric showing but also not so close that the stitches are on top of each other. There are methods for turning corners or curves that are nice for making a great looking edge.
Some tutorials may be helpful.
How to Applique
How to Do Applique How to Make and Apply Appliques
How to Appliqu Like Pro Sew4Home
Sep 05, 2016 | Sewing Machines
Why does the machine hesitate and make grinding noise?
what kind of grinding noise does it make?
try changing the needle--use a needle that is for the fabric being sewed
look in your sewing machine manual and see if the machine needs to be oiled
also clean in the bobbin area for lint
also check to make sure that the bobbin is inserted correctly
Mar 17, 2016 | Sewing Machines
I have a Bernina 145 S activa and I can't get my satin stitch to work , it brings the bobbin thread to the top , what can I do ?
Do you use stabilizer when you are satin stitching? I had a teacher who also hooped the fabric with a spring-loaded embroidery hoop (turned upside-down under the presser foot so the fabric is flat against the needle plate) that would keep the fabric taut.
It is not uncommon for bobbin thread to rise to the top when doing embroidery, satin stitch, etc., especially if you are using lighter-weight thread than usual. You would normally loosen the upper tension so the upper thread will sink into the fabric. However, if loosened upper tension is not doing enough, you may need to adjust bobbin tension when doing embroidery, applique... You might try tightening the bobbin tension just a smidgen to get the bobbin thread to stay below the fabric. Be sure to mark the bobbin case before making any adjustments so you can return it to the original setting when finished with the satin stitch. (If you do a lot of satin stitch or applique, etc., you may want to invest in a separate bobbin case that is set up only for doing that kind of work--saves having to alter the bobbin tension frequently.)
Sewing Perfect Satin Stitch Wildly Wonderful Wearables Patterns Notions...
https://www.google.com/url?sa=t&rct=j&q=&esrc=s&source=web&cd=3&ved=0ahUKEwiRr76k0sbLAhXBKGMKHei6AfIQFggqMAI&url=http%3A%2F%2Fmachinequilting.mqumag.com%2Fwp-content%2Fuploads%2F2014%2F12%2FSatin-Stitch-Techniques-Part-1.pdf&usg=AFQjCNFXYKp2C-RJEAAUMWwApqZlU895uQ&cad=rja
Mar 16, 2016 | Bernina Sewing Machines
How can I use my Bernina 640 Artista to applique
Perhaps I'm not understanding your question. When doing applique, I use a very tight zigzag stitch with a satin stitch foot or open-toe embroidery foot (so the thickness of the stitches do not create buildup under the presser foot). Set the tension so the bobbin thread stays mostly under the fabric so the top thread is the only thread that shows on the top (sometimes threading the bobbin pigtail will help).
Fuse the cutout fabric to the backing fabric. Then zigzag so the raw edge of the fabric is covered by the zigzag (helps to use a thicker thread so the coverage is easier).
Some newer machines have the ability to miter corners. On my 930, I set the needle position to the outside of the raw edged. Then when I near the corner, I gently, but consistently, narrow the stitch width to an an outside point, since the needle on the outside edge, turn the fabric and gently, but consistently, widen the stitch to full width. This creates a nice mitered corner.
When making curves, stitch small lengths and then sink the needle on the outside of the curve, and gently turn the fabric to follow the curve and repeat while going around the curve.
https://books.google.com/books?id=MQneD8cQ5KAC&pg=PA13&lpg=PA13&dq=mitered+applique+corner&source=bl&ots=1sHsUrkVAz&sig=1WZ-i2-T3RtvUEW797sHxTKiq4E&hl=en&sa=X&ved=0ahUKEwiaoZeiwunKAhVslYMKHewdDFEQ6AEIKzAC#v=onepage&q=mitered%20applique%20corner&f=false
How to Appliqu Like Pro Sew4Home (FWIW, IMHO, the satin stitch on the bird is really a poor example. The stitch is not very even at all--could be the sewing machine.)
How to Make and Apply Appliques (The giraffe is a better example, although choosing a simple design to applique usually yields better results.)
Practice, practice, practice!
Feb 08, 2016 | Bernina Artista 640E Sewing, Quilting and...
Nv500 brother machine maked a grinding sound and wont stitch it just gathers and knots can you sugest what it might be?
Something is bound up. Stop trying to sew. Turn off the machine.
Take off the foot, take out the needle, take off the bobbin cover, take of the needle/throat plate and check for the reason for your problem. Look for lint, threads caught up underneath and in between the parts.
Clear all that out and put it back together and attempt test seam.
Nov 19, 2012 | Sewing Machines
I have a brother SE-400 and it sounds like the bobbin case is grinding.
I have a Brothers SE400..while free motion quilting, it sounds like the bobbin case is bouncing around. A lot of clanking noises. Does anyone know what I need to do to adjust this problem? It also seems like my stitches are very small and tight. I do see the top thread overlapping with my bobbin thread on the backing...what do I need to do to adjust this problem
Feb 10, 2011 | Brother XR7700
CLICK AND GRIND IN 270D BROTHER SEWNG MACHINE
Make sure you're using the correct foot for the stitch. Is this during sewing or embroidery? Take off the bobbin plate using the screwdriver and remove the bobbin. Make sure everything is clean under and around the shuttle. If you've ever broken a needle the tip might have fallen down into the mechanism and occasionally be jamming it.
Nov 19, 2008 | Brother SE-270D Computerized Sewing...
Machine makes a loud noise and will not make stitches.
sounds like something is broken. best to get it checked out. take to the sewing machine doctor.
Oct 16, 2008 | Brother CS-8150 Computerized Sewing...
Janome Memory Craft 9000 Computerized Sewing Machine Logo
464 people viewed this question
Top Janome Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Irene Tulloch
Are you a Janome Sewing Machine Expert? Answer questions, earn points and help others
