Question about Nortel Alteon SSL VPN Remote Access Server
I have a customer that needs to renew a SSL certificate. since regulations changed for CSR requirements we now need to add the field organisational unit there and therefore the certificate cannot be renewed directly. We have to create a new CSR and I´m trying to find out if it will cause a problem with the certificate that is already installed? If there is a solution to make a new CSR and enroll for the certificate it would be great if you have an explanation.
SSL Certificate Installation
In order to install an SSL on your server follow the steps shown below -
1.Generate a Certificate Signing Request (CSR)
2.This will help to determine which server will use your certificate. It will also impact the domain names that will be using the SSL.
3.The next step is to request an SSL certificate.
4.Note that you have to provide documents that prove you are the true owner of the domain if you are not hosting on your own server.
5.You will be issued a downloadable SSL certificate file that can be installed on your server.
6.Once your SSL is installed, it is recommended that you make a backup copy of the certificate and store is in a secure place. This will be very helpful for replacement in case of server crashes.
For more information - visit: https://www.eukhost.com/blog/webhosting/how-to-install-ssl-in-plesk/
Nov 07, 2017 | Computers & Internet
What documents required for AQSIQ renewal
AQSIQ LICENSE RENEWAL SERVICE
China Recycling Inspection Service Co.,Ltd
Justin Xu
Skype: AQSIQ-Justin
Email: Recycling@aqsiqgov.com
Web: WWW.AQSIQ.ORG
Mob(Whatsapp): 86-13575798844
Documents required for AQSIQ Certificate renewal as below:
1. The user name and password of the electronic system
from China AQSIQ Dept. (http://scrap.eciq.cn/)
Note:All enterprises has it's own user name and password of AQSIQ Certificate. Its created when you apply AQSIQ in the first time. As we know, lots of companies forgot password for some reasons, no worries, we will help you get the password back during the application.
2.Notarized business and Tax registration documents
as well as the translation from Notary Public,Foreign Affairs Dept.,Or China Embassy.
Note: Before you take the documents to be notarized, please send the copy to us first, we will help you confirm that three information (Company name,company address and legal representative) will shown on your docs. It should be mailed with original one to us directly.
3.CCIC Certificates (Pre-shipment inspection certificates
for scrap materials)one for each item for the past three years.
Note: for example,if you have scrap types of waste plastics and waste paper on your AQSIQ Certificate, and your license will be expire on 31,12,2015. then you need to provide;
one ccic certificate for waste plastics and one for waste paper in 2013
one ccic certificate for waste plastics and one for waste paper in 2014
one ccic certificate for waste plastics and one for waste paper in 2015
So you need to provide 6 CCIC certificates to us in total.
4.Color copy of the AQSIQ certificate.
Note: Its a simple work for everyone.
5.The layout or floor plan marked with size and unit of the office
and processing yard(if any).
To make sure that your photos will show company name, company address,offices,machines (if you have)
*If the company name, company address or company
legal representative of the supplier has been changed
during the past three years.Please let us know.
*If the applicant has any records for rejection of
shipped cargoes during the past three years.Please let us know.
Sep 01, 2016 | Computers & Internet
How to renew philgeps certification?
http://gppb.topicsolutions.net/t1317-how-to-renew-my-philgeps-certificate
Jan 28, 2015 | Computers & Internet
Have just recently changed to vodafone on my Nokai C201 mobile and previously had no problem with accessing my web based (online) emails which are hosted via my website. Instructions provided for emai
  1. Press the Menu key
  2. Select Email
    1. If there are existing accounts
    2. Select Add Account
    • Select Other
    1. Select I Agree
    2. Select the Email Address field
    3. Enter in your 3rd party email address
    4. Select the Password field
    5. Enter in your email password
    6. Select Sign In
    7. Select OK
    8. Select POP3
    9. Select Next
    10. Select the Incoming Mail Server field
    11. Enter your incoming mail server details
    12. Select SSL if required
    13. Ensure Incoming Port is set to the required port
    14. Select Next
    15. Select the Outgoing Mail Server field
    16. Enter in the outgoing server details
    17. Select SSL if required
    18. Ensure Incoming Port is set to the required port
    19. Ensure Requires Login is ticked
    20. Select Sign In
    Oct 03, 2014 | Computers & Internet
    SSL certificate error : SSLPassPhraseDialog builtin is not supported on Win32 . Please Help
    Generate Keyopenssl genrsa -des3 -out startssl.key 2048Remove Pass Phraseopenssl rsa -in startssl.key -out server.key
    Generate CSRopenssl req -new -key server.key -config "c:\xampp\apache\openssl.cnf" -out server.csr Configure it
    give csr at startssl and get certificate and run ... BEST OF LUCK
    Useserver.key and certificate u got
    Dec 31, 2011 | Computers & Internet
    How to configer email address in lotus notes
    From what provider are you trying to configure email?If its gmail,
    1. Create a Lotus Notes database file to store your POP emails: Lotus Notes does not create a file automatically as Thunderbird or other mail clients do but you have to manually point the mails to flow to a file that is already existing.
    2. In the local Address Book, create two accounts for accepting incoming email and sending outgoing email on Gmail. Names are not important but the configuration on the two accounts is!
    Account document for Incoming Gmail:
    The Basics tab
    a. Account name: Can be anything (I chose In Gmail)
    b. Account server: pop.gmail.com
    c. Login Name: Your gmail email address (complete with the @gmail.com)
    d. Password: Your password
    e. Protocol: POP
    f. SSL: Enabled
    g. Only from Location(s): Doesn't matter. Although I would recommend creating a location document specific for Gmail if you are also using Domino Server. I chose creating a location (Gmail).
    Protocol Configuration tab: There is only one field here and it doesn't matter what you do with it.
    Advanced Tab: This is the most important tab.
    a. Port Number: 995
    b. Accept SSL site certificates: Yes (Most of the articles on the web tell you to choose No here. But it does work. Trust me. I have tried it)
    c. Accept expired SSL certificates: Yes. (Most of the articles on the web tell you to choose No here. But it does work. Trust me. I have tried it)
    d. Send SSL certificates when asked (outbound connections only): No.
    e. Verify account server name with remote server's certificate: Disabled
    f. SSL protocol version: V3.0 with V2.0 handshake
    3. Click on Save and Close to save the document and exit. Now you will need to create another account document to handle the outgoing email.
    Account document for Outgoing Gmail:
    The Basics Tab
    a. Account Name: Can be anything. I chose Out Gmail
    b. Account server name: smtp.gmail.com
    e. Protocol: SMTP
    f. SSL: Enabled
    a. Port Number: 587 or 465 (Both are SSL port and both work)
    4. Once these two documents are created, I would recommend creating a location document to ensure that you separate your gmail from your other Domino based account on the client. The steps to create are:
    5. In the same local Address Book, choose New --> Location
    Basics Tab:
    a. Location Type: Local Area Network
    b. Location Name: Can be anything (I chose Gmail)
    c. Internet Mail Address: Your gmail email address
    Leave the rest as it is.
    Servers Tab:
    a. Home/Mail server: pop.gmail.com
    Ports tab: No changes (ensure TCPIP is checked)
    Mail Tab (Most important):
    a. Mail file location: Local
    b. Mail file: My Gmail.nsf (whatever you created in step 1 above).
    Update: A couple of readers pointed out that I had missed an important step in the configuration how-to. So here it is. Step C has been added to include the missed step.
    c. Internet domain for Notes addresses when connecting directly to the Internet: gmail.com
    d. Send Outgoing mail: directly to Internet
    Leave the rest of the fields as it is.
    6. There is no need to change the rest of tabs. Click on Save and Close to create the document.
    Change to the the new location and you will see Gmail getting downloaded in the mail file you created.
    Jul 27, 2010 | Microsoft Windows XP Professional
    How to setup a domain
    You need to buy a SSL certificate to from a company to make your line secure. Usually GoDaddy has Secure lines for a very good price, here is the link:
    http://www.godaddy.com/ssl/ssl-certificates.aspx?ci=8979
    Depending on what kind of SSL certificate you need, Go Daddy has it.
    Jun 04, 2010 | HP Pavilion dv6000z Notebook
    While accessing mail i am getting message (error code:ssl_error_rx_record_too_long_
    Error code: ssl_error_rx_record_too_long Your SSL website may fail to load and display the error
    This usually means the implementation of SSL on your server is not correct. The error is usually caused by a server side problem which the server administrator will need to investigate.
    Below are some things we recommend trying.
    - Ensure that port 443 is open and enabled on your server. This is the standard port for https communications.
    - If SSL is using a non-standard port then FireFox 3 can sometimes give this error. Ensure SSL is running on port 443.
    - If using Apache2 check that you are using port 443 for SSL. This can be done by setting the ports.conf file as follows
    — clip —
    Listen 80
    Listen 443 https
    — clip —
    - Make sure you do not have more than one SSL certificate sharing the same IP. Please ensure that all SSL certificates utilise their own dedicated IP.
    - If using Apache2 check your vhost config. Some users have reported changing <VirtualHost> to _default_ resolved the error.
    Mar 18, 2010 | MPC Computers ClientPro 125D PC Desktop
    Need to fit rear seats in vw t5
    this is a mind field mate. what u SHOULD do is go to a proper coachworks and have the seats peopley fitted by them. for this you have to by seats which have been certificated (£500 - £1000) 4 two seats, and have them fitted which also requires a certificate (£300 - £500) but they want to fit their own seats . . . extra costs! ! also VOSA should inspect the seats and change the REG docs to the van . . . EXPENSE EXPENSE. . . what i did on my T5 was had a garage fit me some second hand seats which i got off e-bay with seat belts etc. they invoiced me saying the seats are fitted correctly and to current regulations. i phonned my insurance got them insured (£30) so covered my self in the event of a problem! ! also worth mentioning the MOT stations dont know anything about it . . . (i told them about the certificates needed) - For more info contact VOSA - coachworks fitters - seat companys on the net
    Hope this helps you will need to do alot of digging m8 ! ! d.jenkins
    Jan 03, 2010 | Baby Gear
    Nortel Alteon SSL VPN Remote Access Server Logo
    37 people viewed this question
    Top Nortel Computers & Internet Experts
    Gopi Venkatesan
    Gopi Venkatesan
    J John
    Jax Planet
    Jax Planet
    Are you a Nortel Computer and Internet Expert? Answer questions, earn points and help others
