BenQ LCD TV the power "on and off" every 30 seconds.
Power Supply "AELTA" s/n AXF00629023512
LCD TV Model: V37P
VA 371
P/N : 9H.01575.BAS
s/n QLW 7600162008
Made in Taiwan
  • 8 Answers
SOURCE: Haier 37" LCD TV...need a power supply
There is a Haier Authorized Servicer in NYC who repairs the panels. Give them a call . Website is www.asnyonline.com
Posted on Jun 30, 2008
ginko
  • 19396 Answers
SOURCE: 26" Insignia LCD TV will not power up. Green Light Blinks 1x
If the TV goes in standby, then it is in protection mode.
Ensure also that the fault is not coming from a faulty receiver box sending
bad signal, check if you get same problem on DVD with no receiver box
connected.
Try first leaving the TV power cord unplugged for some times, let say one hour or so.
The flashing light indicates a diagnostic state called protection.
When the TV goes on protection there are only two possible causes.
1The internal circuits are jammed because of electrostatic charges accumulating on capacitors, or because of a wrong voltage read by the main chip on your monitor controller board. this started the protection circuit.
2 The protection circuit detected a wrong voltage or abroken contact, identified an internal fault and kicked in , starting the flashing light.
If you are in situation one, then the TV will reset just unplugging power cord for one or two hours,sometimes even minutes.
If you are in situation 2 , then there is an internal fault.
If under warranty contact the manufacturer ringing the number on the user manual
If you want to repair at your own expenses, just locate any good qualified repairer.
If you want to DIY you find parts here,
All: Appliance parts, electronics parts & more from PartStore.com
Encompass Parts Distribution
LCD/Plasma Electronic Replacement Parts: Plasma & LCD TVs, Appliances |
On LCD Pay particular attention at inverter and power board, power board can be inspected looking for bulged or leaking capacitors, then tested with a multimeter. The inverter is more difficult to test , there is need to read voltages, should be done by a tech. Also the LCD controller board can cause same problem
On Plasma, test Sustain (Ysus/Zsus) / Buffer boards , cables to plasma, digital board and power board.
On Rear Projection : check lamp, lamp ballast, power board, and convergence.
On CRT TVs, check ballast , flyback transformer, CRT, Tuner, Convergence.
Posted on Apr 19, 2009
SOURCE: SYNTAX OLEVIA LT30 POWER SUPPLY
Yes they are bankrupt, and they did see repair services out to third party vendor- this appears to be phone support at $25 per 1/2 hour.
email response from service inquiry....
Thank you for contacting us. My name is Ravin and I understand that you have called in today for further troubleshooting but you were offered a paid service instead. Based on the information provided, I believe that the following steps should effectively resolve the issue:
I am sorry to inform you that, Syntax-Brillian, the manufacturer of the Olevia Brand, has declared chapter 11 bankruptcy and has ceased all operations. Because Syntax-Brillian is no longer in business the warranty for your product is void.
Amergence Technology, a 3rd party repair company, can offer paid repair services for your television and a paid service for further troubleshooting. Since Syntax-Brillian went out of business, Amergence is offering repair services to owners of Olevia HDTV's.
If you have any further questions or concerns, please do not hesitate to contact our Support Team at 866-965-3842 Monday through Friday between 7.00am 5.00pm PST
Sincerely,
Ravin
Posted on May 14, 2009
John-INSG
  • 312 Answers
SOURCE: insignia 32 HELLP
You can find parts for your TV here. If the power supply is an internal component, it is strongly recommended that it be installed by a TV repair professional.
Posted on Oct 01, 2009
SOURCE: Power Supply Board for SAMSUNG 40" LCD TV Model LA40R81BX
You'll find some Samsung power supply boards here : http://www.usefulparts.com/index.php?main_page=index&manufacturers_id=11&sort=20a&filter_id=98&alpha_filter_id=0
but you have to open your TV first and find out model number
Posted on May 10, 2010
Power automatic shut off after 5 seconds
check the lamp first
We supply original projector lamp,bulb,parts,Lcd panel,Lens,DMD chip,color wheel,motherboard,powersupply,ballast... with high quality and competitive price.
any questions, feel free to contact me
have a nice day!
Jerry,Lampdeng Limited
Jan 29, 2014 | BenQ Office Equipment & Supplies
How to adjust va,vs,vr set-up and set-down?
If its an LCD TV as stated (42LC2D), you do not adjust Va/Vs etc. this is only done on Plasma TV's especially after replacing either the power supply or the screen itself.
Oct 17, 2013 | LG 42LC2D 42 in. LCD HDTV
Benq lcd fp0537s on for just 2 second
There are one or two capacitors in the power supply that open," leaving a slight puff at the top" in some cases.
Mar 16, 2012 | BenQ FP92W LCD Monitor
After start monitors works 15-30 sec, and write Nonpreset Mode! and torn off. Green led lamps light normal.
Replace bad electrolytic caps on power supply module,or just replace power supply, that should fix your problem.
Jan 17, 2011 | BenQ T701 TFT 17" LCD Monitor
Vizio VX37L LCD TV can not stay on for one minute. When I turn on the TV set, the power on for about 30 seconds, then automatic off. No picture, no sound at all. Please help.
hello,
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Power supply board have problems,just not dead yet.Replaced the power supply board,will solved this problems.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish power supply board for the replacement.
Good luck....
May 23, 2010 | Vizio L32 32 in. LCD HDTV
Mt tv turns itself off after about 30 seconds and
Power supply board is dead.Replaced it with a purcharse of a refurbish power supply board at websites at Shopjimmy.com,Ebay.com for the replacement.
Mar 18, 2010 | Sylvania 6620LCT 20 in. EDTV-Ready LCD...
I have a Sony Model # KDF-E55A20 HD Television. I
So what ur prob?Yes the power supply prob.if getting nothing,no response to power,click when turn on,or no standby light indicator.
Oct 19, 2009 | Sony KDF-E55A20 55 in. LCD Television
Benq FP71G+ 17" LCD with Power Recycle (shutdown & return).
Seems either aproblem with Invertor board or Front panel switches are leaky.
Samir
Aug 17, 2008 | BenQ FP71G 17" LCD Monitor
Dark disp-lay
sorry mate,that is dreaded power interter board inside lcd,read about similar benq model dramas here http://www.electronicrepairguide.com/benq-t705-lcd-monitor-repair.html
Jun 03, 2008 | BenQ T705 17" LCD Monitor
Televison & Video Logo
82 people viewed this question
Top Televison & Video Experts
