After installing ew cartridges still get cartidge low fault lexmark x2650 how do i get rid of fault
  • 981 Answers
Easy! You solved the problem the way you were supposed to, just reset the printer (or load its new drivers and let them do it) to get it cleared up; or contact Lexmark about their bad cartridges. Perhaps if you'd filed this under the Lexmark x2650 you would have seen some similar problems and solutions.
Posted on Nov 27, 2008
Lexmark x2650 isnt recognising the black ink cartridge
There could be two reasons for this 1. take out the black ink cartridge make sure you have taken the plastic sticker off. 2. The contacts at the back of the cartridge might be damaged. in which case you will have to get a new ink cartridge.
Mar 30, 2011 | Lexmark X2650 All-In-One InkJet Printer
Where can i put lexmark ink?i can't see the place where should i put the new ink for lexkmark x2650
Make sure the Lexmark X2650 printer is on. Lift the scanner unit to access the cartridge area. The cartridge carrier will move to the center automatically for the loading position.
Press the down the carrier levers to open and remove the used cartridges. Load the new cartridges and close the cover. Close the scanner unit.
Sometimes the ink cartridge carrier won't position automatically to the middle even when the printer is on and the cover is open. Just unplug the printer from the power source. With the cover open, hold the solid white strip and gently slide the carrier to the middle of the printer. Load the cartridges. Close the cover. Plug the printer back to power source. Thanks.
Nov 06, 2010 | Lexmark X2650 All-In-One InkJet Printer
Printer error flashing 1 then E then C, after changing printer cartridge on lexmark x650, which installed correctly.
Try turning of printer, disconnect from power, Now removing ALL Ink, clean both the cartridge, and where they go, make sure is real clean. Now replace them. Then reconnect Power, & turn on. Hopefully this will have reset the printer. If NOT then your printer for what ever reason has developed a fault, OR that new cartridge is incompatible for whatever reason, perhaps a refilled, or counterfeit one?
Mar 24, 2010 | Lexmark X2650 All-In-One InkJet Printer
Black cartrtidge is not compatible can you fix this?
Remove the incompatable cartridge and replace with a genuine Lexmark cartridge.
I know, the cartridges are expensive. They are also guaranteed to work.
Nov 02, 2009 | Lexmark X2650 All-In-One InkJet Printer
What can i do my black cartridge not found in lexmark X2650
Make sure cartridge site is clear od obstructions?
Resite cartridge making sure it feels it clicks into place.
I installed new cartridges and I'm still getting a message. "cartridges replacement required" It's a Lexmark X2650 printer
did you put in new cartridge or refill the old? If you bought new ones you could have gotten one with a bad chip. I would take it back and exchange it for a different.
Oct 01, 2009 | Lexmark X2650 All-In-One InkJet Printer
Still getting message empty cartidge lexmark x2650
“Lexmark does not support the refilling of its ink cartridges. Refilling the ink cartridges can cause them to leak, thus clogging or even damaging the print head. Any damage to your printer caused by refilled ink cartridges may not be covered under warranty”. Please use genuine Lexmark cartridges for best results.
May 26, 2009 | Lexmark X2650 All-In-One InkJet Printer
Lexmark X2650 - Install of service center & compatability of ink
I regret that I just came across this. It's certainly an unusual situation. Did you contact the Lexmark Customer Support Center? Did your problem get resolved? If not, contact me directly:
Mar 26, 2009 | Lexmark X2650 All-In-One InkJet Printer
Refilled cartidges
i believe u need to do printing alignment after putting a refilled cartridge, so it would detect that there is a new cartridge installed.
see link for changing cartridge
Mar 27, 2008 | Lexmark X3470 All-In-One InkJet Printer
Computers & Internet Logo
129 people viewed this question
David Payne
David Payne
