Computers & Internet Logo
Anonymous Posted on Nov 26, 2008
I have acer asphire 5315-301g08m1 and i have boxes about 8 all on screen i want to no how i can restore back to original settings or factory settings it has virus
Steve Nordquist
Level 3:
  • Master 982 Answers
  • Posted on Nov 27, 2008
Steve Nordquist
Master
Level 3:
Answers
982
Questions
Helped
213488
Points
2276
Boot your OS Restore CD. I hope you have backups of any data you wanted.
How. Do I take acer touch screen PCs to factory settings
Hi. Most computers have a hidden partition on the hard drive that contains all the factory default settings and system software that originally came with the PC, including the operating system (like Windows 7/8,etc.). There is a simple method to restore your computer to factory default settings using this restore partition. Please be sure to backup any data or files that you want to save on a USB flash drive or backup media first.
I presume that your computer is an Acer Aspire One model touch-screen PC. For this model of computer, in Windows, go to "Start," then "All Programs," then "Acer Empowering Technology."
Then, you want to click on "Acer eRecovery Management."Then, click on "Restore," then lastly, "Restore System To Factory Default." Your computer will then reboot/restart, and launch the Recovery Utility.
When prompted, click "Yes," then "Yes" again to restore/revert your Acer computer to its original factory default state. Please do note that if you deleted the recovery partition from your hard drive by formatting it, you won't be able to use this recovery option. If that is the case, you should be able to use the original system DVD's that came with your computer to restore it to its original factory defaults.
I do hope that I have helped you. Please feel free to ask further questions if you still have need. Thank you.
tip
How to restore an Acer Portable to Original Factory Settings.
"Restoring a system should be a last ditch effort in trying to repair a computer, since restoration causes all programs and many files to be lost forever. Restoring an Acer computer to its original factory settings can be done in a few easy steps."
  1. Click “Start” menu.
  2. Click “Programs.”
  3. Click “Acer Recovery Management.”
  4. Click the “Restore” button on the bottom of the dialog box that opens.
  5. Click “Restore System to Factory Default.”
  6. Click “Yes” in the warning dialog box which asks if you wish to continue the recovery process.
  7. Click “Start” to restore the computer to the default factory settings.
on Jan 02, 2010 • Computers & Internet
Reset acer
The Acer Aspire One is a netbook, not a laptop.
A netbook is a smaller, scaled-down version of a laptop. It does not have the memory capacity or graphics of a regular laptop.
It also lacks a CD drive, which means you cannot restore the Acer Aspire One with restore discs. Instead, the netbook has a built-in factory restore feature.
You can reset the Acer Aspire One to factory settings just using your keyboard.
Only restore your netbook to factory settings if you cannot fix the problem any other way.
Save any files or folders on your Acer Aspire One with flash drives.
Drag and drop files onto the icon of your flash drive.
Go to Start > Restart to reboot your netbook.
Hold down Alt and F10 when you see the Acer logo on the screen.
The recovery menu will load.
Hit Enter and then Next to see your recovery options.
Choose Factory Restore to set your netbook back to factory settings.
Follow the instructions on the screen.
Choose your time zone and language when the customization menu appears.
Reboot the netbook when you are prompted.
Restore your saved files from the flash drive.
or
When a vital file becomes corrupted, it might be necessary to restore a computer to its original factory settings.
This process also cleans up the hard drive and removes old programs that can make a computer slow and unresponsive.
But, because restoration wipes away all files you have installed or created, it should be a last-ditch effort in trying to repair a computer.
If you have reached this point with your Acer laptop or desktop, the manufacturer provides a utility to restore the factory settings.
Open the Windows Start menu by clicking on the icon in the lower left corner of your desktop.
Click All Programs, then the Acer folder.
Select Acer eRecovery Management to open the utility.
If a Windows prompt asks for permission to run the program, click Yes.
Click the Restore button in the pane on the left side of the program window.
Click Completely Restore System to Factory Defaults.
Select the Yes option in the dialog box that asks you to confirm the action, and click Start.
Click OK in the second confirmation dialog box to restart the computer.
Click Next in the warning window that appears after the computer reboots.
This confirms that you realize restoring the computer deletes any data stored on your hard drive.
Click Next again in the Restore Destination window, and click OK in the popup that gives you one last warning about deleting your data.
The restoration process will begin.
Click OK when the utility lets you know that the restoration is complete.
The computer will restart, and Windows will finish the recovery process.
http://acer.custhelp.com/app/answers/detail/a_id/12869/kw/factory settings/related/1
1helpful
Need to restore computer back to it's original state Toshiba Model # PSKOQU OOKOO1
Restore Toshiba to Out of the Box Condition
If your model Toshiba laptop has a Restore partition on the hard drive then follow these steps to restore your Toshiba to the Out of the Box condition.
1. Press and hold the 0 (zero) key and at the same time, tap the power button once to switch on
your notebook.
2. When the machine Starts beeping; release the 0 key.
3. When prompted by the warning screen; select Yes to continue with the system recovery.
4. Select Recovery of Factory Default Software; click Next.
5. Select Recover to out-of-box state. 6. Click Next again.
7. Click Next to Start recovery.
8. Restart the Toshiba laptop when there restoration process finishes running. Follow the prompts that appear on the screen to set up the laptop's date, time and language settings.
How do you do a factory restore on an acer travelmate 5742? where do u start?
I see, Follow the details below to be able to do a Factory Restore on your Acer.
  • Click on Start
  • Select and Click Programs
  • Look for Acer Recovery Management and click on it
  • There will be a dialog Box on the Bottom click "Restore"
  • Then click on Restore System to Factory Defaults
  • Then Click YES if you are sure to restore the system and that you have already backed up any personal or important documents
  • After clicking YES click on START to begin the process of restoring the system back to Factory Defaults
Note: If the Original Hard drive Settings/Partition have been deleted or changed it is possible the Restoration to Factory Defaults may not work.
I hope that this will help your restore your machine to Factory Defaults.
Have a nice day,
mvincentc
4helpful
2answers
Need factory settings aspire 5920
Laptop computers can be wonderful devices, except when the need to troubleshoot arises. Acer laptops are no different. A quick way to fix many problems with an Acer laptop running Windows is to reset it to factory settings. Resetting your Acer laptop to factory settings can eliminate slow operating, registry problems, virus problems, spyware issues and more. And a factory reset of your laptop may reduce the need for a full reinstallation of Windows.
1.Back up all necessary data to an external device such as a disk, flash drive or hard drive
2.Make sure all programs are closed and shut down your Acer laptop by opening your Start menu and selecting "Shut Down" from the options for shutting down and restarting windows.
3.Detach any external hardware such as an external hard drive or printer.
4.Press the Power button to boot your Acer laptop.
5.Press "Alt + F10" on your keyboard when the Acer screen appears at the start of the boot up process. Wait a moment while Windows loads the reset files.
6.Select "Restore System from factory default" in the Acer eRecovery Management window.
7.Click "Next" on the next screen to continue. Click "Next" on the following destination information window. This will pop up a notice telling you that resetting your Acer laptop will erase all data and restore the laptop to its original settings and configuration.
8.Click "OK" in the notice window to proceed with resetting your Acer laptop.
9.Wait while your Acer laptop is reset to factory settings.
How do I restore my acer to orginial factory settings?
Hi!
Before restoring your machine to factory default please make sure that you mback up all your program and files to any external device.
Please follow the step by step procedure to restore your machine to factory default.
1. Make sure all programs are closed and shut down your Acer laptop by opening your Start menu and selecting "Shut Down" from the options for shutting down and restarting windows.
2. Detach any external hardware such as an external hard drive or printer.
3. Press the Power button to boot your Acer laptop.
4. Press "Alt + F10" on your keyboard when the Acer screen appears at the start of the boot up process. Wait a moment while Windows loads the reset files.
5. Select "Restore System from factory default" in the Acer eRecovery Management window.
6.Click "Next" on the next screen to continue. Click "Next" on the following destination information window. This will pop up a notice telling you that resetting your Acer laptop will erase all data and restore the laptop to its original settings and configuration.
7. Click "OK" in the notice window to proceed with resetting your Acer laptop.
8. Wait while your Acer laptop is reset to factory settings.
Should you have any other questions please just leave a comment.
Cheers~
2helpful
2answers
Hgow do i restore my acer laptop back to the
Please follow the rules.
Ensure all Data is backed up, all data will be deleted.
2 Please also ensure that all USB storage devices are removed before starting the recovery process
3 Restart machine
4 When your unit switches back on, wait for the ACER screen then hold down alt & tap f10 repeatedly..
5 Please wait a moment until prompted, -How would you like to restore?-
6 Please select –Restore system to factory default-
7 Enter your defined password or enter six zeros ‘000000’
8 Click ok
9 Please wait until process completed, this will take 45min – 1hour
ALL personal information on the C: Drive I.E photos, programs, music and documents will be wiped when the above steps are taken. Files located on the D: Drive will be safe from the procedure.
Thanks and waiting for your feedback.
3answers
Would like to set it back tofactory settings
start up the computer and in the bio's there should be an option to press a key like F9 or something to open the repair console...from this menu choose re-set to factory settings...there should be a backup partition on acer hard drives to restore it back...
if this dosn't work bang in an OS cd - boot it up from the bios and follow the on screen instructions - drivers that are not installed will be avalible from acer's website - they are quite good for downloading them
Brentwood IT
43helpful
7answers
Restoring acer aspire to its factory settings
From Acer customer support:
1 Ensure all Data is backed up, all data will be deleted.
2 Restart machine
3 When your unit switches back on hold down alt & tap f10 repeatedly...(on Acer icon)
4 Please wait a moment until prompted, -How would you like to restore?-
5 Please select –Restore system to factory default-
6 Enter your defined password or enter six zeros ‘000000’
7 Click ok
8 Please wait until process completed, this will take 45min – 1hour
Steve Sweetleaf
Steve Sweetleaf
Grand Canyon Tech
Grand Canyon Tech
