Question about Dishwashers
Door interlock appears faulty on my whirlpool awm 321 . It wont allow program start when door closes . Needs a lot of coaxing , banging with palm of hand , knee etc .Door itself appears fine , catch looks ok , finishes and runs ok once we finaly get it started .Hve tried pressing the interlock slider in with a pencil , but cannot succeed in pushing the contacts into place and starting the program . HELP PLEASE
    President:
  • 1,462 Answers
Only solution is to replace the interlock - it is just held in by 2 screws
Posted on Nov 26, 2008
Whirlpool Model LHW0050PQ4 will not go through cycles. clotes are stuck in the washer and I can't get the door open to get the clothing out until the cycles seemingly need to be completed. Can I override...
The 'interlock' door switch is designed to stop people from opening the door and flooding the room. If you have to wait till the cycle has finished it's because power is still being supplied to the interlock. Turning the machine to 'off' and waiting approx. 3 minutes should allow the interlock time to release the 'lock'. If the door cannot be opened after that amount of time and there is no power going to the interlock, it would appear that the interlock is faulty and needs to be replaced...Not a huge job for a tech.. Good luck....Nomess (Please take a moment to rate this response)
Jul 20, 2010 | Washing Machines
Whirlpool model AWM 6101 door wont open after washing has finished
the door can take anything up to 2 and a half minutes to open anyway but if it takes any longer than this, or will simply not open at all then you will need to get a replacement door interlock switch
May 29, 2010 | Whirlpool LHW0050PQ Front Load Washer
Door won't lock
If the interlock isn't working it may not allow the machine to start. If you can open the door when it should be locked it's probably a faulty interlock.......Nomess
Apr 17, 2010 | Maytag Neptune MAH5500B Front Load Washer
Whirlpool awm 6141 wont start any cycle as the door open light comes on. the door appears to be latching ok
when my washer is switched on it sounds like the motor is strugeling to spin to the right.
Jan 07, 2010 | Whirlpool AWM6141/1 Front Load Washer
Washing machine wont start - close door message
Hi.
Most likely faulty door lock or door catch.
To access it, remove the clamp from drum front seal, and remove the seal from the front of the cabinet, undo the 2 screws that secure the door lock, and remove.
To test wether the lock is faulty or not, put a link wire across the (L) and (C)
connections on the lock, the m/c should now work, if it does not, then you have
a more serious problem.
Nov 22, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Indesit WIA 121
this could be your interlock this is what sends power if this is not working the washer wont work simple way to test is close the door and bang the front of the washer were the interlock is if its a faulty interlock or a lose wire then it may start up but more then likely that it is the interlock m8
Feb 18, 2008 | Indesit W 123 Front Load Washer
HOTPOINT AQUARIUS WF250
it may be the interlock but is more probably the control PCB in the fascia, this is not a DIY repair as it requires programming when replaced.
Reagrds
Advisor
Nov 10, 2007 | Hotpoint Aquarius WF000 Front Load Washer
Wash cycle will not start
the door interlock is faulty, hit the door handle area with the palm of your hand, make sure machine is turned off 5 mins before hand. Replace door lock IRE bye.PS it should open when you hit it bye again. remember the palm of your hand
Nov 02, 2007 | Whirlpool GHW9200L Front Load Washer
Door wont lock
to test if there is a fault on your interlock you can close the door now with your hand bang it on the front of the washer were the door hits the catch most cases if it faulty than the washer will start it will then need replacing only thing you can do if faulty m8
Sep 22, 2007 | Hotpoint WMA64 Front Load Washer
Power Surge and WD16BA
Door not shut Check that the door is properly shut.Faulty interlock A faulty interlock might not allow the door to shut properly. Find your door interlock here and replace, or contact a qualified repairer.
No power Check the flex, plug wiring, fuse and mains supply for faults.
Faulty on/off switch Check the power light if fitted. Replace your on/off switch.
Water supply disconnected or off If a washer dryer cannot load water it cannot start a wash cycle. Check water supply.
Sep 18, 2006 | Smeg WD16BA Front Load Washer / Dryer
Dishwashers Logo
123 people viewed this question
Top Dishwashers Experts
