Question about BenQ Televison & Video
Power Supply does not work constantly
Power Supply "AELTA" S/N AXF00629023512. Problem: "on and off" every 60 seconds and the picture shows normally.
I have a Vizio E470i-ao smart TV. On the left hand side mostly bottom left corner it dims out every two seconds and then returns to normal after two seconds. Constant pattern like a neon sign blinking....
Its likely the power supply. They are notorious for problems. The backlight is powered in quadrants. Your lower left quadrant is failing. I love fixing things but Vizio is nothing but trouble. I wont even work on them they are so poor to repair.
If you are handy, check the power supply for the backlight for bad solder. If it looks ok, then Id use it until it goes bad again.
Dec 25, 2017 | Vizio Televison & Video
When I turn on computer,monitor doesn't show anything sometimes 1,2 hours , and then finally I can see descktop on computer...All that time,monitor is trying to show picture (I can see like blinki
This is a known symptom of a failure in the power supply board. Here is a link to a repair guide that shows how to dis-assemble and the unit and then what to look for and replace on the power supply board to bring the unit back to working condition.
http://www.ccl-la.com/blog/index.php/repairing-a-samsung-940n-with-a-blinking-power-light/
And here is a picture of the power supply board that needs to repair.
I hope this helps, if so please rate my solution.
BuddyMc
Feb 22, 2012 | Samsung SyncMaster 940N Flat panel Monitor
Turn TV on and no picture but sound. Turn it off for about 5 seconds and it works fine. Also ... amber light constantly stays on. is that normal?
That is not normal, more likely to either to have power supply failure or the back light inverter failure.
If you are going to DIY and have proper tools and know safety precaution then please read on:
Please see my basic troubleshooting guide here:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Jun 28, 2010 | Vizio GV42L 42 in. LCD Television
Shows picture for a second when i press button than goes dark
Issues with back light:
Please do not attempt to diagnose if no competent.
Do at your own risk.
Check for 24 Volts power to the inverter board
No Power---Check Power Supply
Power Present---
Verify status voltage 3v to 5v on inverter board harness (plug)
Replace Inverter Board
Feb 11, 2010 | Tatung V30DMTT 29.6 in. LCD Television
When i switch tv on, it shows picture for 5 seconds then goes into standby. the tv is a vistron ltm-3271e lcd
The problem is associated with the power supply that cannot run under load. The showing of picture for a brief period of time indicates that the main board, ballast, inverter and panel drive are all OK. The unit turns on but the power supply cannot sustain the power requirement of the unit and shuts down.
The usual culprit on the power supply are blown or bad capacitors. Check the power supply for such capacitors. If no apparent damage or defect is found, replace the power supply.
Nov 07, 2009 | Televison & Video
Syncmaster 226CW showing picture only for a second + flickering
Call and get the RMA for your monitor, the problem is in the power supply and it will only get worse. This is a common problem with LCD monitors after 2-3 years of use.
Buddy
Corporate Computer
www.ccl-la.com
Oct 17, 2009 | Samsung SyncMaster 2233BW 22" LCD Monitor
Samsung plasma - no picture
check the power supply board for blown/bulging capacitors
you should see 4 bad ones on the top left
Jun 12, 2009 | Televison & Video
TV cycles on and off but never fully turns on
Tv POwers on shows a picture then picture goes and audio stays on
Apr 14, 2009 | Philips 43PP9202 43" Rear Projection...
Sony TV goes to standby - constant red light
The Power Supply has gone. It needs replacing.
Jan 04, 2009 | Televison & Video
Televison & Video Logo
Top BenQ Televison & Video Experts
Lawrence Oravetz
Are you a BenQ Televison and Video Expert? Answer questions, earn points and help others
