Can you please help me solve my 2 pc problem..
ONE: I have Gigabyte GA-8IG1000-G motherboard, Intel P4 1.5 ghz, 1 gig memory, 80 gig hard disk. I can't hear any sound on my computer, when I look at the device manager there are 2 Unknown Device with a yellow question mark on it. I have downloaded Audio driver at gigabyte web site but it doesn't solve my problem. My OS is Windows XP SP2.
TWO: There is also Universal Serial Bus Controller with a yellow question mark on it.. How can I solve it?
Hope someone can help me..
Thanks a lot...
  • khiej Nov 26, 2008
    ...,-thats the appropriate motherboard model no, i have read it at the motherboard. I'm running windows XP professional, at gigabyte web site it will suite. But after formatting my pc, and I install the drivers. After that there is still the unknown device with a yellow question mark. I've tried it several times. What should I do?
  • 849 Answers
Put the appropriate motherboard model no and choose exact operating system at gigbyte web site. it will solve ur problem. they will support u as u required. no other option if u dont have disk.
Posted on Nov 26, 2008
HI I have a Gigabyte motherboard 945GCMX-S2, I have a 1GB ddr2 (667 Hz) hynix ram already installed ..to upgrade it i installed another 1GB dynet ram (666 Hz)..but my cpu beeps now...i remember runni
You should be able to as it can take 4 gig total according to the manual.
Memory:
2 DDRII DIMM memory slots (supports up to 4 GB memory) (Note 2)
Supports dual channel DDRII 667/533 unbuffered DIMMs (Note 3)
Supports 1.8V DDRII DIMMs
Note 2. Only for GA-945GCMX-S2.
Note 3. Only for GA-945GCM-S2.
Feb 06, 2012 | Gigabyte Computers & Internet
Win Me will not Boot after load. Win 98 will not Boot either. Says not enough memory ???? 2 Gig Memory PC3200-GA-8ipe1000-g Gigabyte MB
Try just using 512Mb of memory or less as there was a bug in Me and 9x that produced that error if you had more than 512 Mb of ram.
Jul 18, 2011 | Gigabyte GA-8IPE1000-G (MBGA81PE1000G)...
I want to know that shall i put pentium 4/ 2.4 Ghz/ 533 Fsb/ Processor on this Gigabyte 845GVM-RZ board? will it support ?and i have 1 Gb ddr1 400 mhz ram will this work on this Board?
Yes for the Intel Pentium 4/2.4GHz/533FSB processor. (Socket 478)
http://en.wikipedia.org/wiki/List_of_Intel_Pentium_4_microprocessors#Northwood_.28130.C2.A0nm.29
(Scroll through. What sSpec number is on top of the processor's case? {You are following Anti-Static Precautions, correct? }
Won't support better than a Prescott Core Pentium 4. (Next chart down)
The Gigabyte GA-8I ((Supports 400MHz or 533MHz FSB)
NO to the Ram Memory.
The Gigabyte GA-8I845GVM-RZ supports DDR Sdram at 333Mhz. (PC2700)
IMHO it will not support DDR Sdram at 400MHz. (PC3200)
My reasoning is this;
Ram Memory typically operates at half of the FSB frequency rate of the Processor.
Processor FSB > MAXIMUM frequency rate is 533MegaHertz for the GA-8I845GVM-RZ
Ram memory at 333MHz is doable.
Not 400MHz.
No, you won't be able to overclock, and bring the FSB of the Processor high enough for PC3200 Ram Memory.
(The rest of the motherboard wouldn't work anyway if you did. PCI Express bus, PCI bus, etc., would not match)
http://www.newegg.com/Product/Product.aspx?Item=N82E16813128238&cm_re=Gigabyte_GA-8I845GVM-RZ-_-13-128-238-_-Product
Have more questions concerning this, or comments, please post in a Comment.
Regards,
joecoolvette
Nov 08, 2010 | Gigabyte GA-8I845GVM-RZ Motherboard
Im not sure how much ram to use with my motherboard.
Your board can support 4Gb of RAM.
CLICK HERE for the SPEC sheet.
HERE is the memory support list, there is only 1 type of KINGSTON 2GB stick that is listed as compatible.
Make sure you have the latest BIOS as there are some known issues with this board and certain 4GB RAM configs as well as fixes for 1TB HDD space errors.
Always a good idea to make sure you have the latest XP service pack. In general, XP only recognises 3Gb RAM but mine runs fine with 4 in it.
When you crash, is there any Blue Screen of Death (BSoD) or any other output to your monitor or does it just shut down with no warning or error code or anything? If this is happening then you may be getting a CPU OVERTEMP condition.
Have you recently upgraded other components as well as your RAM?
Mar 26, 2009 | Intel Motherboard
Can you help me about my pc problem???
Khiej,
It is likely that the Drivers for your Chipset have either NOT been installed or have become corrupted.
Below is a link to the driver page for your motherboard..
http://www.gigabyte.com.tw/Support/Motherboard/Driver_Model.aspx?ProductID=1758
On that page you will see a category of "Chipset"
If you have the 32bit version of Win XP SP2 then select the 2nd driver. If you have the 64bit version select the 1st driver. If you are not sure the most likely one would be 32bit.
Install theses drivers.
While your on the driver page. Get the "VGA" drivers for Windows XP (This is likely to be your 2nd "Unknown device")
OK heres why the chipset drivers are important. There are sub procecessors on the motherboard called the "Northbridge" and the "Southbridge" processors. The act kind od like traffic cops for your Main CPU. They allow data traffic to pass from the various devices on your computer. Without the Chipset drivers the Southbridge which controls the AGP/PCI bus for your computer has trouble talking to the CPU. Therefore anything attached to that bus doesn't work quite right (That would be your Sound, Video and Peripherals(USB's))
So now that we know whats going on. The fix is to install the drivers in this order.
1.) Chipset (Opens up the AGP/PCI bus so the devices communicate) After this is installed Windows MIGHT detect the other 2 and install them right away. If not continue on.
2.) VGA (These allow your video card to work to its fullest potential. Out of the box the Video card can work in plain vga mode and display the basic information. The VGA driver allows it to step up to SVGA mode (Super Video Graphics Array) allow it to show higher screen resolution and color depth)
3.) Realtek audio driver. (This one allows your on board audio processor a path to talk with the "Southbridge" chip)
Once these are all installed you should have everything up and going. If there are any further error markers (The yellow ! ) then comment back to me with your results and I will get you going.
Thanks for choosing FixYa.com
Dave
Nov 26, 2008 | Intel Motherboard
Gigabyte ga-8skml
well their could b 2 problemz as i know
1. IDE cables
2. Jumpers may b not properly configured
so u just let me know that r u connecting ur hard disk n cd rom on one cable or two different cables? then i myt suggest a solution for u! n do check ur cables n jumpers setting that r they configured correctly or not?
Nov 17, 2007 | Intel Motherboard
GA-G31MX-S2 Motherboard
try changing your CMOS Battery the CR2032...
Oct 28, 2007 | Intel Motherboard
Computers & Internet Logo
115 people viewed this question
Alun Cox
David Payne
David Payne
