Question about Freezers
Freezer tripping supply
The freezer was not cooling the upper drawers so the fan was replaced. Now all is freezing but it seems to run continuously. After several hours the supply will trip. The freezer is about 2 years old.
    Sergeant:
    Champion:
  • 291 Answers
Make sure whoever put in the motor installed the right motor and if they did check to make sure the fan blade wasn't put on backwards ,,,,,,,
Posted on Nov 26, 2008
Why does it run continually?
possibly needs a service man to recharge the freon
Feb 18, 2016 | Freezers
I have a hotpoint freezer fza34 The red high temp
it could be that your fridge,freezer setting is not turned up high enough to keep the freezer cold enough.turn it up to setting number 5 at least and if that dont do it u could have a faulty thermostat.have it checked by a engineer.
Oct 30, 2013 | Freezers
My freezer drawers are very warm All food defrosted smells horrible even after cleaning. Should I clean condensor, temp is not cooling?
It is likely the condenser fan is not functioning, or the condenser is dirty. You may need to open the compressor access panel to check. If you can hear the compressor running, and the condenser feels warm, the fan should be running. If it isn't, it probably needs to be replaced. Another symptom is the area around the doors feels warm.
Jan 01, 2013 | Sub-Zero 700 Refrigerator Freezer...
Frigidaire Freezer, model # FFU20FC6AW3. Unit is not cooling and the fan motor inside behind the access panel is not running. My Temperature Alarm sounds and will not shut off, unless I switch it to the...
if the evap fan is not turning try to turn it by hand a few times then start you freezer if it does not turn it needs to be replaced.make sure there is no ice build up on the evap coils.alos check the continuity of the defrost heater below the evap coils.once you het teh fan replace your unit should cool down to the proper temps.
Nov 16, 2010 | Frigidaire Freezer Refrigeration White...
Both Lights flashing and fridge not getting cold
I turned the fridge and freezer off using the circular dials, I then turned the unit off at the mains. Left it for a few minutes and then turned the power back on. I then turned the circular dials to "max" and then depressed the super cool and super freeze buttons to turn this facility on. This time they came on normally (not flashing) and no alarm sounded. The fridge and freezer then started to get cold. Once the unit had been running for several hours I then turned the dials to the 3/4 mark and depressed the super cool and super freeze buttons again to turn them off. Over night the fridge and the freezer appear to be working properly so I hope that my problem is solved. Maybe the unit just needed to "settle" before being switched on?
Sep 03, 2009 | Freezers
Fan continuously running, non-stop
hi thanks for the question its normal for a frost free freezer to run a long time to keep a good cold temp i don't think you have a problem thanks the appliance doc
Sep 08, 2008 | Frigidaire 13.7 cu. ft. / 388 liter...
Hotpoint FAZ50 Frost Free Freezer
If this is a frost free unit as I received it posted you may have a problem in that it is not frost free. The cooling coil may be frozen over stopping air circulation. There would be a defrost timer located somewhere in back. Located the clutch head screw and turn it clockwise SLOWLY until you hear one audible click. That should put the system into the defrost mode. Wait about 30 minutes in which time the system should return to the cooling mode (usually 18-22 minutes). If it does not restart the compressor after that time turn the clutch head screw clockwise again and it should restart. If you had to turn the screw the second time it would indicate a bad defrost timer. In this case replace the timer.
Jun 14, 2008 | Hotpoint 4.87 cu. ft. / 138 liter Upright...
Not freezing equally
Look for frost build up on back wall at bottom the auto defrost may be out. Check if the evaporator fan is blowing. If not it's stuck by something or needs replaced. If not The sealed system may have a leak or restiction causing it to only work closest to the evaporator i.e. the lower shelf.
Apr 22, 2008 | Frigidaire Freezer 16.7 cu. ft. Upright...
Freezers Logo
65 people viewed this question
Top Freezers Experts
Dennis Boxerman
Charles T Nevin
Charles T Nevin
AJMAL KHAN
Are you a Freezer Expert? Answer questions, earn points and help others
