Input Adapters
Problem for Input Adapters
Generic problem for all Input Adapters
Trouble recording records
By don3948 on Nov 26, 2008
Hi. I bought the Hama Stereo Phono Preamplifier product yesterday. The guy at Media Markt told me that was all I needed to record my records.
I am having trouble getting it to work and hoped you could help me. I connected my record player to the device (instead of my stereo) and the device to my computer (via USB). I also downloaded software from www.magix.de although it was only a test version.
I guess I have two problems:
1. When I plug the USB into my computer, the computer (for some reason) shuts off the external speakers. What do I need to change on my computer so that it knows the USB is Music input rather than output, etc.?
2. The Magix software does not notice any input and neither does MediaPlayer. What recording software do I need to create .mp3 files from my records? Ideally, I would have one file per song; but I am not sure how the software will know the song changed.
I would really appreciate your help with these problems.
Best regards from Germany,
don
Comments:
Nov 28, 2008
- thank you both for your trouble. I really appreciate it.
Best Solution
posted on Nov 27, 2008
Very Helpful)
fidoliedo
Rank: Guru
Rating: 87%, 114 votes
When recording from a phonograph, I use the following items.
Depending on the phonograph whether or not it's MC or MM makes a difference in sound although most can't tell the difference. Also, you need to know if your phonograph requires a pre-pre amp or if that pre-pre amp is built in and the line coming out is at line level. The Rolls item is a pre-pre amp unit which takes to older phonographs signal level to that of input levels which allow the phonograph to be connected to any aux line in.
On the back of the computer, you can plug the RCA jacks from the phonograph into the adapter and directly into your computer via the MIC (usually pink) input. Most of the time this is sufficient. If the volume is too loud, or sounds horrible, chances are you have a pre-pre amp and you then plug it into the line in (usually blue)
First I would connect the RCA's from the phonograph to the adapter and plug it into the mic and see how the sound is.
Keep in mind that you do not use the ROLLs unit when connecting this way. If it's too loud or distorted, plug it into the line in.
For recording, you can download Audacity which is free and a wonderful editing program.
Was this helpful?
Yes
No
Solution #2
Very Helpful)
babygenius55
Rank: Wiz
Rating: 84%, 50 votes
Hello don, what it seems like to me is that when you hear the external speakers shut off what is most likely happening is that the computer is actually switching the sound device, and since there is no input, you hear nothing. (I must assume that you are using windows XP, in Vista the steps may be slightly different.) first things first, connect your usb audio device and wait for the tell tale sound. next go into your control panel (start button>control panel) look for the 'sounds and audio devices' icon an double click on it. a window should open up that displays 5 tabs or so. one of thoses tabs is labled 'audio'. click on that and check to see that your default sound playback device is listed as your usb drive or your normal sound card(it should be your normal sound card). next, while in the same window check you sound recording device. that should be your usb device. if you don't see it there, then you will have to install the drivers for the device. if you do see it there, then make sure you are playing a record and that all cables are connected properly, and that the volume is turned up at least halfway one everything. yes, pc and analog devices. What is happening here is that the device is a microphone, and it is supposed to turn your usb port into a recording device. it needs sounds input so that it can convert them to a digital signal, and the drivers to let the pc know that's what all of those signals are coming in. we can tackle the mp3 conversion after you've sorted this out, but i would suggest looking into a format called '.FLAC'. it is a lossless compression scheme, and if you're taking the time to do all of this you probably want the best product possible for archiving.
Was this helpful?
Yes
No
Popular Solutions for Input Adapters
Questions and Unsolved Problems for Input Adapters
Answer
I just installed my Fast Track USB. The window says everything is in sync yet there is a full second... (More)
Answer
I had purchased this device ,Sabrent TV Tuner / Video Capture / MPEG Recording PCI Card with Remote... (More)
Answer
vista 32 bit home premium hp pavilion dv7 notebook gray screen black lines right to left says no... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Input Adapters:
Top Input Adapter Experts
Rank: Guru Guru
Solutions: 14911
Experience: 40 years of automotive repair work, home appliance repair experience and general electrical repair.
Ask Me
Find more Input Adapter Experts
Top Computer & Laptop Repair
(877) 729-0812
We connect to your computer over the Internet to...
Remote Repair
(952) 890-7770
Zkarlo.com provides discount and used laptop parts...
Zkarlo.com
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
