Question about Canon PIXMA MP830 All-In-One InkJet Printer
Menuel Required Urgently please.
1) When fax recived, the machine gives report? it should give report when we send a fax not when recived??
2) I do not hear the dialing tone when sending a fax, never know if the fax was sent or not?
3) Please forward full copy to the Menuel
  • 488 Answers
Hi!i got the manual for you, its here
hope it helps!
Posted on Nov 26, 2008
I have panasonic kx-pf711 fax machine it will send properly but it has a problem reciveing document 2pages
You are not making it clear as to what your problem is? Does it not print the second page? Is it paper jamming on the 2nd page? Is it giving an error code?
Please repost with more accurate info. Thanks
Jul 18, 2016 | Panasonic Office Equipment & Supplies
Brother IntelliFax-2820 Plain Paper Laser Fax does not automatically print a transmission report each time we send a fax. Is there a way to automatically have that happen. We can't find it.
You need to set up the Transmission Verification Report and Journal Period in the menu table.
Press Menu/Set, 2, 4, 1.
Press Menu/Set, 2, 4, 2.
You can use the Transmission Report as
proof that you sent a fax. This report lists the
time and date of transmission and whether
the transmission was successful (OK). If you
select On or On+Image, the report will print
for every fax you send.
If you send a lot of faxes to the same place,
you may need more than the job numbers to
know which faxes you must send again.
Selecting On+Image or Off+Image will print
a section of the fax's first page on the report
to help you remember.
When the Verification Report is turned Off or
Off+Image, the Report will only print if there
is a transmission error, with ERROR in the
RESULT column.
1 Press Menu/Set, 2, 4, 1.
2 Press ? or ? to select On, On+Image,
Off or Off+Image.
Press Menu/Set.
3 Press Stop/Exit.
Printing reports
1.XMIT Report
2.Journal Period
Nov 15, 2010 | Brother IntelliFax-2820 Laser Fax
Unable 2 send or recive fax
Make sure the telephone wire is plugged into the line jack (not ext jack) and should go straight to the wall, without splitters or extensions. If you still cannot send a fax, try another wire or jack
Apr 15, 2010 | Brother MFC-8220 Fax
Report of fax
Hey renzo737 - Follow these steps to have your machine print a report after you send each fax:
1)Hit the Fax button, then the Menu button.
2)Press the < and > buttons to scroll until you reach
TX Settings. Hit OK.
3)Use the < and > buttons to scroll until you reach TX REPORT.
Then hit ok.
4)First you want ATTACH TX IMAGE and then you want
PRNT FOR EACH TX.(it may also say as TX REPORT)
On your machine under TX report it may just say PRINT ERROR ONLY, which means only print if there's an error, or the PRNT FOR EACH TX. You'll find it easily. You want the print for each tx option. This will print a report and give confirmation that your fax went through after each fax. If you have any problems understandind this or need more help just give a shout.
If this solves your problem PLEASE rate this as fixed. Like I said if you need more help just add a comment and I'll be happy to assist you further. Thanks and have a good one.
Jun 30, 2008 | Canon PIXMA MX310 All-In-One Printer
Fax Journal Report
Step through the REPORTS menu and select CONFIRMATION REPORT
Jun 09, 2008 | Brother IntelliFax-2820 Laser Fax
Brother® IntelliFAX® 5750e Laser Plain-Paper Fax
1-transmission verification report.
2-fax activity report.
for(1)press menu-2-4-1
for(2)press menu-2-4-2.
Mar 20, 2008 | Brother IntelliFAX 5750e Laser Fax
Pana fax uf 8000
I'm not sure which key is used on that model but look for a key that says one of these: menu/user settings/reports/program.
what you are really trying to do is get to your reports programming section, then select tx report, then choose print tx report and will fix your problem, you may want to change you fax number if that number changed also.
Mar 14, 2008 | Panasonic PanaFax UF-8000 Laser Fax
Fax auto answer
Normally you would not be able to do this, as most standard fax machines give up after 4-6 rings.. 5 Rings is the highest normal amount of answers.
Nov 01, 2007 | Lexmark F4270 Plain Paper Inkjet Fax
How to get fax reports
Your only option is to have it print out automatically after every 32 transactions, print out after every transaction, or print out only when there was an error with the transmission.
That parameter is Comm Journal and you can get to it by going to Function 7, option 4. That should give you a fax parameter table. You want options 12 and 13. Set 13 to "1" if you want it to print out every 32 transactions. Set that to "2" if you don't.
Set 12 to 1 for Comm Journals Off, 2 for Always, and 3 for Incomplete Only (errors).
Oct 02, 2007 | Panasonic Panafax UF-490 Plain Paper Laser...
Canon PIXMA MP830 All-In-One InkJet Printer Logo
95 people viewed this question
old marine
old marine
