Question about Microsoft Windows Vista Ultimate Edition
Can not open control panel in window vista
When i try to open control panel in window vista its appear less then 1 second and venish from the screen its not open any condition and not to show any other features from any other place like through help section.
    Master:
  • 505 Answers
Have you installed anything else on the system? Also, you might check Event
Viewer assuming that will open. Open the Start Menu, type Event Viewer in
the search box, when you see the security prompt, click continue and it
should open.
If that doesn't resolve it type CMD in Start Search on the Start Menu. When
you see CMD at the top of the Start Menu, right click, select "Run As
Administrator." When the command prompt opens, type
"sfc /scannow" without the quotes and let it run.
If that fails to resolve it, check manufacturer websites to make sure all
your device drivers are up to date, the same with all of your software, make
sure the apps are Vista compatible and that you've installed any updates.
Also, make sure you have no malware or any viruses. If all is fine you may
need to do a repair, boot from the Vista DVD and choose the repair option at
the setup screen.
Posted on Nov 26, 2008
Cannot adjust my screen size
Click start control panel display desktop you can select a different desktop from the drop down list
or a browse button where you can select different picturesthis may vary depending on your operating system
also you can change the settings for more or less pixels or from the drop down list pick the appropriate level of color range or troubleshoot also select advanced then general dpi normal
size, larger size or custom settings
Always click APPLY after making any changes
windows 7
Open Personalization by clicking the Start button, clicking Control Panel, clicking Appearance and Personalization, and then clicking Personalization.
Click Window Color and Appearance.
Under Window Color and Appearance, click the color you want, and then click OK.
Note
If you see the Appearance Settings dialog box instead of the Window Color and Appearance
window, the theme might not be set to Windows Vista, the color scheme might not be set to Windows Aero, or the computer might not meet the minimum hardware requirements for running Windows Aero.
For more information, see Troubleshoot problems with Windows Aero.
Create Menu tab right click in the top of screen (toolbar) you will see a number of toolbar options select the menu bar
This will add to your screen toolbar File Edit View Favorites Tools and Help select the View from the drop down list will be a Zoom with percentages % and text sizes largest to smallest and Full screen option
Jan 25, 2014 | Computers & Internet
Tip
How to reset Windows Vista password?
The question about how to reset Windows Vista password is often seen on various forums and Q&A websites. It is a serious problem for you if you are not good at PC. But if you are familiar with computer, the answer to the question can be very simple. There are many fast and easy ways for you to reset the password. Here it introduce you a simple one - create a Windows Vista password reset disk and use it to help you perform Windows Vista password reset.
Method 1: Reset Windows Vista password through Vista operating system
Windows Vista allows you to create a password reset disk with a USB flash drive in a few seconds. It can help you reset Windows Vista password when you forget it.
Part 1: Create Windows Vista password reset disk
Step 1: Log on your Windows Vista computer.
Step 2: Insert a USB flash drive in computer.
Step 3: Click Start button to select Control Panel.
Step 4: Click User Accounts and Family Safety in the following screen.
Step 5: Click User Accounts when a new screen appears.
Step 6: Click Create a password reset disk in the left pane in the coming up screen.
Step 7: The Forgotten Password Wizard will open, and then click next.
Step 8: Select the portable media drive which you want to create a password reset disk on, and then click next.
Step 9: Enter your current password, and then click next.
Step 10: Click next when the progress indicator shows 100% complete.
Step 11: Click Finish in the next window.
Step 12: You can now remove the flash drive from your computer.
Now you have successfully created a Windows Vista password reset disk. And you'll find a Userkey.PSW file when you open USB flash drive. Keep the file or USB flash drive in a safe place. You'd better to mark the USB flash drive so that you can distinguish it from other USB drives. When you forget password on Windows Vista and cannot log on your PC, you can use the USB password reset disk to reset Windows Vista password. You could follow the below steps.
Part 2: Reset Windows Vista password
Step 1: Start your computer and get to the Windows Vista logon screen.
Step 2: Type a wrong password, and then press Enter.
Step 3: Click OK when the error message that the user name or password is incorrect. And the Reset password link will appear on the Vista logon screen.
Step 4: Click Reset password to open Password Reset Wizard screen.
Step 5: Insert your USB password reset disk in computer.
Step 6: Click Next on the Password Reset Wizard screen.
Step 7: Select your USB password reset disk, click Next.
Step 8: Type and confirm a new Vista password.
Step 9: Input password hint, click Next.
Step 10: Click Finish when you've successfully reset Windows Vista password. You'll return to Windows Vista Logon screen.
Step 11: Enter your new Windows Vista password to log on your Vista machine.
Please Note: You must create the Windows Vista password reset disk before losing your password.
Method 2: Reset Windows Vista password with Windows Login Recovery
If you are locked out of Vista PC without a Windows Vista password reset disk, you'll need Windows Login Recovery to create one. This Windows password recovery software allows you to use a USB flash drive or blank CD/DVD to create a bootable Windows password reset disk. With it, you'll never to be worried when you need to perform Windows Vista password reset. It is also easy for you. Follow the below steps.
Step 1: Download Windows Login Recovery and install it on a computer that you could log on.
Step 2: Burn a bootable CD/DVD or USB flash drive password reset disk.
Step 3: Reset Windows Vista password to be empty.
Step 4: Log on Windows Vista without password.
on Oct 28, 2010 | Computers & Internet
NEED TO ADJUST SCREEN CONTRAST TO SEE TEXT
Step 1:
Click start control panel administration tools computer management device manager scroll to display adapters + to expand you might see a yellow question mark ? or exclamation mark ! or a red x right click select reinstall drivers You might need to upgrade your graphics card drivers. You might have to remove your graphics card to make sure the socket is clean restart your computer the reinstall it this should activate found new hardware wizard if your computer came with a mother board disk the drivers could be on it Click start control panel display desktop you can select a different desktop from the drop down list or a browse button where you can select different pictures this may vary depending on your operating system also you can change the settings for more or less pixels or from the drop down list pick the appropriate level of color range or troubleshoot also select advanced then general dpi normal , larger or custom settings
Always click APPLY after making any changes windows 7 Open Personalization by clicking the Start button, clicking Control Panel, clicking Appearance and Personalization, and then clicking Personalization. Click Window Color and Appearance. Under Window Color and Appearance, click the color you want, and then click OK. Note If you see the Appearance Settings dialog box instead of the Window Color and Appearance window, the theme might not be set to Windows Vista, the color scheme might not be set to Windows Aero, or the computer might not meet the minimum hardware requirements for running Windows Aero. For more information, see Troubleshoot problems with Windows Aero.
Apr 01, 2013 | Acer Aspire 3000 Notebook
Can not set screen resolution
Which operating system ?
Always click APPLY after making any changes windows 7 Open Personalization by clicking the Start button, clicking Control Panel, clicking Appearance and Personalization, and then clicking Personalization. Click Window Color and Appearance. Under Window Color and Appearance, click the color you want, and then click OK. Note If you see the Appearance Settings dialog box instead of the Window Color and Appearance window, the theme might not be set to Windows Vista, the color scheme might not be set to Windows Aero, or the computer might not meet the minimum hardware requirements for running Windows Aero. For more information, see Troubleshoot problems with Windows Aero. Hope this helps.
Jan 16, 2013 | HP Computers & Internet
Screen resolution is set incorrectly, don't get proper res (1200 x 800) when trying to change.
Click start control panel display desktop you can select a different desktop from the drop down list or a browse button where you can select different pictures this may vary depending on your operating system. also you can change the settings for more or less pixels or from the drop down list pick the appropriate level of colour range or troubleshoot also select advanced then general dpi Normal , Larger or Custom settings.
always click APPLY after making any changes
windows 7 Open Personalization by clicking the Start button, clicking Control Panel, clicking Appearance and Personalization, and then clicking Personalization. Click Window Colour and Appearance. Under Window Colour and Appearance, click the colour you want, and then click OK. Note If you see the Appearance Settings dialog box instead of the Window Colour and Appearance window, the theme might not be set to Windows Vista, the colour scheme might not be set to Windows Aero, or the computer might not meet the minimum hardware requirements for running Windows Aero. For more information, see Troubleshoot problems with Windows Aero. Hope this helps.
Dec 07, 2012 | Computers & Internet
What's your problem?hi iam using winods vista ultimTE but i cant change the resolution of my screen
windows 7
Note
Hope this helps.
Dec 03, 2012 | Microsoft Windows Vista Ultimate Edition
Laptop screen problem
click start control panel display desktop you can select a different desktop from the drop down list
also you can change the settings for more or less pixels or from the drop down list pick the appropriate level of color range or troubleshoot also select advanced then general dpi normal size,larger size or custom settings
windows 7
Note
hope this helps
Aug 08, 2012 | Dell Studio XPS 1645 Laptop
After being on a few minutes, the text becomes very blurry I lowered the resolution, which makes the text bigger and helps some. There is an internal adjustment, but I don't know where??
Hi hamptonwhh,
Screen resolution refers to the clarity of the text and images on your screen. At higher resolutions, items appear sharper. They also appear smaller, so more items fit on the screen. At lower resolutions, fewer items fit on the screen, but they are larger and easier to see. At very low resolutions, however, images might have jagged edges. Please follow the steps below on how to adjust your screen resolution.
Windows XP
1. Click Start, click Control Panel, click Appearance and Themes, and then click Display.
2. On the Settings tab, under Screen resolution, drag the slider, and then click Apply.
3. When prompted to apply the settings, click OK. Your screen will turn black for a moment.
4. Once your screen resolution changes, you have 15 seconds to confirm the change. Click Yes to confirm the change; click No or do nothing to revert to your previous setting.
Windows Vista/7
1. Open Display Settings by clicking the Start button, clicking Control Panel, clicking Appearance and Personalization, clicking Personalization, and then clicking Display Settings.
2. Under Resolution, move the slider to the resolution you want, and then click Apply.
Notes : When you change the screen resolution, it affects all users who log on to the computer.
When you set your monitor to a screen resolution that it won't support, the screen will go black for a few seconds while the monitor reverts back to the original resolution.
Hope it helps.
Thank you for using FixYa.
Jul 04, 2011 | MPC Computers Envision EN 775e 17 in.CRT...
In vista: taskbar does not show icons of opened files
it might be your taskbar is on auto hide try this
Show or hide the taskbar gl_icon_tip.png Applies to all editions of Windows Vista.
The taskbar is usually located at the bottom of your screen. It looks like this:
getopencontent.aspx?assetid=984f8561-57a1-4b9c-9f22-f0d8dddec294&documentset=en-us&renderkey=xml Taskbar
You can hide the taskbar to create more space. If you don't see the taskbar anywhere on the screen, it might be hidden.
Hide allShow allHide all gl_arrow_down_static.gif To show the taskbar
• If the taskbar is hidden, point to where you last saw it to show it again. If you can't remember where you last saw it, try pointing to the bottom of the screen first, and then to the side or top of the screen, if necessary. You might need to move the pointer almost off the screen to show the taskbar.
gl_arrow_down_static.gif To hide the taskbar
1. Open Taskbar and Start Menu Properties by clicking the Start button getopencontent.aspx?assetid=4f6cbd09-148c-4dd8-b1f2-48f232a2fd33&documentset=en-us&renderkey=xml, clicking Control Panel, clicking Appearance and Personalization, and then clicking Taskbar and Start Menu.
2. Clear the Lock the taskbar check box.
3. Select the Auto-hide the taskbar check box.
The taskbar is hidden from view. You can see it again by pointing to the place where you last saw it.
gl_arrow_down_static.gif To turn off auto-hide
2. Clear the Auto-hide the taskbar check box.
Jun 27, 2009 | Microsoft Windows Vista Ultimate Edition
Screen size
Most Likely: Your screen resolution needs to be 1024x768.
Less Likely: You have an Appearance scheme such as Large Contrast.
Solution: Access Control Panel, select Display, then Settings tab and then move the slider to the above or higher resolution.
In the Theme or Appearance tab (depending on OS) choose a generic Theme or Color Scheme.
Regards,
Worldvet
May 21, 2008 | Computers & Internet
Microsoft Windows Vista Ultimate Edition Logo
41 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Alun Cox
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
