Question about Danby DDW1805W Designer Series Free-Standing Dishwasher
Danby dishwasher in warranty developed a crack in the door shell.
Sirs, my wife noticed tonight that there is a crack in the door of the dishwasher we purchased from you. It is on the left hand side as you look at it from the front, and the crack starts right where a screw is screwed in from the back side of the left-hand edge of the door. Exactly when the crack first appeared we do not know, but assume it simply got larger as a little time passed, until it got more noticeable. There are no abrasions, dents, or scratches, just the crack. What do we do now to get the shell of the door replaced? My warranty number is 00501376, the model is DDW497W, and the warranty expiration date is indicated on our receipt as July 30, 2009. Please respond ASAP. My email address is sfbarbee@charter.net. Thank you, Fredrick Barbee, 1969 South 7th Street, Apartment 110N, Brainerd, MN. 56401
    Sergeant:
    Champion:
  • 291 Answers
Fredrick:
1st thing you need to do is contact a service company in your area that does the warranty on Dandy, set up a call for them to come out and check it.
being in the 1st year warranty there should be no charge to you and after they come out and check it they will most likely have to order the inter-door liner which is no problem in operation of your dishwasher and after it arrives they will come out and install the part,
you might check to see if there is a sears service in your area and if they work on your make.
be sure to give them all the info up front at far as date purchased, model and serial numbers and who you purchased it from.
Posted on Nov 26, 2008
How do I open door of the new 18 Danby dishwasher. This model has no latch under handle.
I assume you have gone through instructions supplied fully. You will have to contact, Danby directly, there should be contact information in the instructions.
Mar 11, 2017 | Danby Dishwashers
I own a 2004 Chevy Malibu Maxx. My wife hit a pot
you couldve split/cracked fule line. check where its leaking from carefully
Sep 06, 2013 | Cars & Trucks
New dishwasher already wet inside when opened for first time! Is it ok?
Sounds like it was in a flood.
I'd sure try to send it back.
Be blessed.
Apr 14, 2013 | Danby DDW1899WP Portable Dishwasher
On the front of the door .bottom right hand corner there is a small amount of water coming out.when in use.
sounds like the seal is not sealing properly. check to see if there is any debris along the seal -- or any cracks in the rubber seal.
c...
Dec 31, 2010 | Danby DDW497W 22 in. Countertop Dishwasher
Dream Maker x-500 5 person developed cracks in the shell of the 2 corner seats, nearest the access panel. It appears the seat supports molded to the base of the spa are pushing the seat bottoms upwards,...
If it's loosing water this should be a structure warranty. I have two of these and had to drain the spa and shine a light in the spa and take pictures from underneath. Then the light will show off the cracks well. If your the original owner just keep at Dream maker, they should give you a new one.
Dec 11, 2010 | Dream Maker Spas Dream Maker Ez Spa Hot...
After dry heating cycle the door has moisture in it why? moisture is inside the door where you put dishwashing liquid.
You may need to check the mating seams where the door is put together, or the inner shell for cracks. If spilt you may have to replace The door.
Jan 07, 2010 | Kenmore 24 in. 16032 Built-in Dishwasher
LG dishwasher model #LDF6810ST doesn't DRY DISHES.
ok ...first the average dishwasher will only heat the water 1 degree per mintue,,,now if your starting out with very cold water the dishes will never get clean check your water temp,,at start up..if you have 90 to a 100 degrees thats ok..that means we have problem in heater circuit...also turn up your jet dry level...keep me posted onthejob,,incase we have to look at heater circuit
Dec 31, 2008 | LG LDF6810ST Stainless Steel Built-in...
I have a hotpoint dishwasher, was installed in my house new when it was built in 2004
This is a bad control board that if replaced will only repeat in a short time .My advice is to contact the manufacturer and complain,you have the right as a consumer to do so.
Feb 14, 2008 | Hotpoint 24 in. FDW60 Free-standing...
Danby dishwasher
Call Marcone Supplies, Tampa Florida. (they are Danbys Supplier for parts.) DO NOT WASTE YOUR TYIME CALLING DANBY. They are not helpful. Danby 18" Dishwasher. Model # DDW 180 2W Parts 800-482-6022. Marcone:Very helpful. My door is open; thank goodness; it just will not stay closed. Latch broken on door. I have to order the "whole handle assembly" (all one piece which includes the door handle latch too.) $4.16 shipping from PA. I am in Calif. Total $12.53. 2 screws. Easy. I can do it, I know I can. (Signed, a woman in LA!)
Jan 22, 2008 | Danby 17 in. DDW1802W Designer Series...
Danby DDW1805W Designer Series Free-Standing Dishwasher Logo
154 people viewed this question
Top Danby Dishwashers Experts
Kevin Getz
Kevin Getz
Are you a Danby Dishwasher Expert? Answer questions, earn points and help others
