I have a behringer ddm4000 mixer and my problem is when i turn it on it tells me on the screen to adjust vr 24 ive pressed every button and nothing is working???
  • fysergio Dec 30, 2008
    i just got mine not to long ago and it does the same thing. As far what the guy who offered a solution said, the only way to reset to factory default setting is when this "adjust vr24..." is not happening. I did this and the message still pops up
  • DJ AlexTapia May 13, 2009
    hey Hi!!!!!!!!!!! I have the same problem..... I just bought the mixer a week ago and I couldn't use it in one the parties that I had this last saturday.... oh well too bad.....but back to the issue, if any one of you did fix it would you please tell me or should I exange it for another one???? Please I need hel and I really want that mixer when I first saw it I felt in love .....jajaja...well if any one can help me I'll thank you. you can contact me just in case at alexgt_1988@hotmail.com .... gracias!!!!
  • 2,071 Answers
Just reset your unit to factory default setting,so it will back to it's original setting.
Hope it may helps you;
Regards;
VOTIT
Posted on Nov 27, 2008
    New Friend:
  • 3 Answers
WHAT THE MIXER IS DOING A SELF TEST ON EVERYTHING
AFTER IT HAS DONE THAT PRESS THE CENTRE BUTTON ON THE MIXER AND FOLLOW INSTRUCTIONS.IT IS GONNA ASK TO PUSH BACK ALL THE BOTTONS
AFTER YOU DID THAT PUSH THE CENTRE BUTTON AGAIN AND FOLLOW INSTRUCTIONS. ITS GONNA ASK YOU TO EVERY SWITCH AND KNOBS AND SLIDERS. BUT YOU GONNA NEED A MIDI WIRE TO LOOP IT FROM IN AND OUT AFTER IT HAS DONE THE TEST YOU ARE GOOD TO GO.BUT YOU MUST REPLACE THE FUSE.THE REASON WHY IT DOES THAT WHEN YOU TURN IT ON THE FUSE IS NO GOOD.IT WILL TURN ON BUT NOT RUN A FULL SWING!
TURN OFF THE UNIT
ON CHANNEL ONE OF KILL BUTTONS HOLD DOWN ALL THREE WHILE TURNING THE UNIT ON
Posted on Mar 23, 2015
Same problem, tried the factory reset, and still had it freeze up. someone mentioned it could be overheating, so Im going to try and open the heat sinks, I think its the software/firmware, probably shipped with the bug and never got fixed, its a waste of time and money and makes behringer look irresponsible
Posted on Jun 03, 2012
How do you use the headphones with cd turn tables?
you should have a headphone out on the mixer or you need a mixer
Dec 10, 2014 | Behringer Ddm4000 5-channel Digital Midi...
Ddm4000 flashing and crashing
It sounds like it got blasted with ESD, see if you can get it repaired under warrenty.
Feb 16, 2014 | Behringer DDM4000 Digital Pro DJ Mixer...
My ddm4000 starts well but then flashing lights start and loss of control occurrs
I am not familiar with your unit but it sounds like the extension cord is connected to both the lights and mixer, if so use two extension cords. I have seen a lot of horror problems with undersized extension cords.
Good Luck
Ddm4000 system reset
TURN OFF UNIT
ON CHANNEL A HOLD DOWN ALL 3 BUTTONS ( LOW,MID,HIGH AT SAME TIME )
FOLLOW INSTRUCTIONS
BEFORE YOU START THE RESET PROCEDURE
YOU ARE GONNA NEED A MIDI WIRE
CONNECT IT TO THE IN & OUT JACKS
ITS GONNA GO INTO SELF TESTING MODE YOU ARE GONNA SEE ALL THE LIGHTS.LIGHT UP IN ORDER. FOLLOW WHAT THE SCREEN SAYS.AFTER YOU HAVE FOLLOW THAT
REMEMBER DO NOT TURN OFF UNIT UNTILL YOU HAVE COMPLETED THE TASK.IT WILL TELL YOU WHEN IT IS COMPLETED
NEVER USE OR LET NO MIXER PIONEER,BEHRINGER,AMERICAN AUDIO,RANE,ALLEN & HEATH. ETC STAY IN FULL RED PEAKING WHEN PLAYING OUT. YOU CAN PEAK INTO RED BUT NOT STAY IN FULL RED.
WHAT I ALWAYS DO IS SET THE VOLUME FIRST THAT I WANT THEN MAKE YOUR ADJUSTMENTS FROM THERE.GET A GOOD PROGRAM THAT CAN MAKE ALL YOUR MP3 THE SAME VOLUME.( YOU CAN USE WINDOWS MEDIA PLAYER USE THE VARIABLE BITE RATE SETTING LEAVE THE EQ AT DEFAULT SETTING OR USE ITUNES WITH THE SAME SETTINGS AS WINDOWS MEDIA PLAYER. THERE IS ONE PROGRAM YOU CAN USE BUT YOU ARE GONNA PAY FOR ( PLATINUM NOTES ) THERE IS NO FREE DOWNLOAD PROGRAM TO THIS )DIGITAL RECORDINGS HAVE A HIGHER FREQENCY MAINLY ON BASS. ANALOG HAS A WARMER SOUND.ME PERSONALLY I PREFER ANALOG OVER DIGITAL
PLEASE BRING BACK VINYL$$$$$
May 04, 2013 | Behringer DDM4000 Digital Pro DJ Mixer...
How do i connect my pioneer CDJ850 to my behringer DDM4000
with a RCA cable (red & white) from the CDJ's LINE OUT to the DDM's chanel 1 LINE IN then press the button on the back of the mixer that swops the channel from LINE to PHONO over to LINE..
Mar 02, 2013 | Pioneer Audio Players & Recorders
My behringer ddm 4000 dj mixer will work for roughly 1 hr to 2hrs then it will freeze i have to turn it off then back on and repeat the same process what can this be ?
I do not know this unit but unless you are experienced in electronics let the pro's do the heat sink part. Does it have a fan that quit? Try turning the levels down some and see if the problem goes away. It could be simply operating beyond its rating.
Jun 06, 2012 | Behringer DDM4000 Digital Pro DJ Mixer...
Ddm4000 freeze up and got to turn it off and turn back on
Freeze up is usually overheating, check your heatsinks and if the compound has dried up.
Dec 15, 2010 | Behringer Ddm4000 5-channel Digital Midi...
1,783 people viewed this question
 Grubhead
Grubhead
