Question about Konica Minolta DiALTA Di200 Copier
4 digit acces code
The Minolta Dialta di200 in disply show please input your 4digit acces code and press the acces key to the right.
This acces code I not have I need to reset this code or te clear cn you help me how to clear this digit code.
BR,
Agim
    Problem Solver:
  • 17 Answers
First, enter the tech rep mode:
4 digit acces code - moz-screenshot.jpgPress the Utility key, then the meter count button on the touchpad.
Enter "Stop - 0 - 0 - Stop - 0 - 1" on the keypad. You will enter the tech rep mode.
Select "Administrator # Input." Note this number, or change it to something you can remember.
Now, go back to the Utility screen and select "Admin. Management." Enter the code you just learned, select "Copy Track Mode," and change it to "Off." Exit the mode and you're good to go.
Alternatively, you can select "Copy Track Data," and note the access codes (or enter new ones).
Posted on Dec 16, 2008
Malfunction code C0040
Minolta copier show error code c0040. Please show me the picture that point of problem. The second problem. What is the way we could what kind of minolta di ...in the machine?thanks in advanced.
Apr 12, 2012 | Konica Minolta DiALTA Di200 Copier
Error cod sc32-04
There is no SC3204 or C3204 code on the Minolta Di200. I would either need the correct code or the correct model of Minolta you have. Please provide better information so I may assist you further.
Thank You for using Fixya.
Oct 28, 2011 | Konica Minolta DiALTA Di200 Copier
Minolta Dialta Di200 malfunction
1-The C0500 code can be reset following the steps below: find a small
hole on the right side of the control panel. press it using a paper clip
2) When the dot appears on the LCD after reboot, press the number 3 key.
3) The mode will change to the initialization screen.
4) Choose the selection for trouble reset.
5) After reboot the code will be cleared.
good luck
Feb 10, 2010 | Konica Minolta DiALTA Di200 Copier
C0500 error code
Verify the continuiti of the thermofuse and the heater lamp,cleaning it reset the malfunction codes to open /close the front door or enter in the service code Stop-00-Stop-01,acces 3 after appaire the * in the left side in the touch pannel,reset to trouble icons,press exit and total reset button twice.
Dec 07, 2009 | Konica Minolta DiALTA Di200 Copier
ERROR C0500 FOR DIALTA DI350
To clear this code, you will need a paper clip, stick th paper clip in the small hole on the right side of the control panel, (machine must e on) When you do that the control panel wll say please wait, then the screen will show a small blue dot for a few seconds on the left side of the screen, when you see that press 3 you will see a screen the say Maintenace Mode, touch then hit "Trouble Reset" it will again say please wait, then you will see the dot again let it go do nothing it will go thru to Ready to Copy. If The code comes back you need a new fuser unit
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Jul 29, 2009 | Konica Minolta DiALTA Di200 Copier
Minolta Di 351 code C0500 & need reset code for this
look for a small hole...on right side of the disply panel...THE HOLE IS SMALL THE SIZE OF PAPER CLIP IN DIMETER..IN FACT THE ONLY WAY TO ACCESS IS BY PAPER CLIP.PRESS IT ONCE VERY GENTLY..AND WAIT FOR A SMALL DOT TO APEAR ON THE LEFT SIDE OF THE SCREEN IN THE CENTER.ONCE YOU SEE IT>>PRESS # 3 than you will be promted by a screen to reset troublr code press it to conform MACHINE WILL RECYCLE
HOPE THAT HELP S
GOOD LUCK
Dec 30, 2008 | Konica Minolta DiALTA Di200 Copier
Minolta dialta Di200 on screen :malfunction detected code:COO4E
C004E: Power Unit Cooling Fan Motor malfunction
Check the power supply fan for proper operation.
Nov 11, 2008 | Konica Minolta DiALTA Di200 Copier
Co500
locate a pin hole on the right side of the disply panel,and use a paper clip,be very gental and depress it and wait for a samll dot on the left side of the disply panel,as soon as you see it press #3 and than a menue well pop up look for trouble reset botton and turn machine off from the main switch and back on
good luck
Sep 02, 2008 | Konica Minolta DiALTA Di200 Copier
Minolta Di200
I need the default password for my copier its. Dialta Di 200
Dec 30, 2006 | Minolta - DI200F Printer
Konica Minolta DiALTA Di200 Copier Logo
315 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
carpediemweb
Level 1 Expert
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
