Question about HP Vs17 17" LCD Flat Panel Monitor
My screen resolution is stuck at 640 by 480. I've tried to change it back to 1280 by 1024 pixels, but when i click apply, nothing changes. Please help!
    President:
  • 1,073 Answers
Try to reinstal your graphic drivers
Good luck
Posted on Nov 26, 2008
2 Suggested Answers
pravinbhavsa
  • 348 Answers
SOURCE: Screen Resolution stuck at 640 by 480
you first install the audio drivers if the problem persists then attach AGP card then increase resolution and pc will ask question do you want to keep these settings say yes then you can see 1280x1024
Posted on Nov 27, 2008
Tried to enlarge the screen and screen went black and now showing this! I turned it off and hit F8! It came on I pressed safe mode! I tried to get on Internet and it locked up again ! Back to this scr
When a monitor displays "Input not supported", the display resolution is set too high. To resolve this, change the resolution to a supported resolution of the monitor.
In Windows XP
  1. Click Start, click Control Panel, click Appearance and Themes, and then click Display.
  2. On the Settings tab, under Screen resolution, drag the slider to the desired resolution and click Apply.
  3. When prompted to apply the settings, click OK. The screen will turn black for a moment.
  4. Once the screen resolution changes, confirm the change by selecting Yes. A timer will count down for 15 seconds to ensure the change is desired.
    Click Yes to confirm the change; click No or do nothing to revert to the previous setting.
In Windows Vista
  1. Press the Start button , select Control Panel, select Appearance and Personalization, select Personalization, and then Display Settings.
  2. Under Resolution, move the slider to the desired resolution and click Apply.
Oct 20, 2012 | Computers & Internet
How to change screen resolution on dell inspirion 1010 to 1024 x 600
To change your screen resolution1.Open Display in Control Panel.2.On the Settings tab, under Screen resolution, drag the slider, and then click Apply.3.When prompted to apply the settings, click OK. Your screen will turn black for a moment.4.Once your screen resolution changes, you have 15 seconds to confirm the change. Click Yes to confirm the change; click No or do nothing to revert to your previous setting.
Jan 29, 2012 | Dell Inspiron Mini 10 10v 1010 1011 PP19S...
Screen Resolutions My resolutions changed to very small, when I clicked on the monitor.
Your operating system?
For Windows XP,
  • Right click in an open area on the desktop.
  • On the window that opens select properties.This opens the Display Properties window.
  • Click on settings.
  • On the screen resolution option,set to around 800x600 pixels.
  • Click O.K to save.
For Windows 7,
  • Click on the start button.
  • Click on the control panel and under Appearance and Personalization,select Adjust screen resolution.
  • On the list next to Resolution,move the slider to the resolution you want.e.g 800x600 pixels.
  • Click on keep to save the changes.
For Windows Vista,
  • Click on start button.
  • Click on the control panel and then on Appearance and Personalization.
  • Click on Personalization and then on Display settings.
  • Under Resolution,select the resolution you want.
  • Click Apply to save the changes.
Hope this helps.Thanks!
Please rate this answer.
Oct 28, 2011 | Computers & Internet
Text to small
Change Your Font size.
1.Right Click on Desktop Click Properties "Display Properties will appear".
2.Click Appearance Change Font Size to Large Fonts or Extra Large Fonts.
3.Click Apply and Ok.
Or
Adjust Screen resolution.
1.Right Click on Desktop Click Properties.
2.Click Settings Adjust Screen resolution to 800 by 600 pixels
3.Apply and Ok.
Aug 13, 2011 | Computers & Internet
I have an AMD athlon processor. I want to set my screen resolution to 1920 x 1080 (Full HD). But in Properties --> Settings, this option is not there. My monitor's native resolution is 1920 x 1080....
click start control panel,display,desktop you can select a different desktop from the drop down list
or a browse button where you can select different pictures this may vary depending on your operating system
also settings you can change the settings for more or less pixels or from the drop down list pick the appropriate level of color range or troubleshoot also select advanced then general dpi normal size,larger size or custom settings
always click APPLY after making any changes hope this helps
May 24, 2011 | AMD (axmd2400fjq4c) Athlon XP 2400+, 1.8...
How do I change my computer monitor to 1680 x 1050?
First right-click on the desktop and then left click on Properties from the menu that appears.
The display properties dialogue box will appear as shown in fig. below, click on the settings tab at the top right of the box.
The areas worth noting are: google_protectAndRun("ads_core.google_render_ad", google_handleError, google_render_ad); Screen Resolution
This slide bar is what you use to change the resolution, the options you have will depend on your graphics card and monitor, but the standard options are 800x600, 1024x768 and 1152x864.
Normally the default (in XP) is set to 800x600 which means the display will be 800 pixels wide and 600 pixels high.
Color Quality
This pull down box will contain the current colour options available, again this will depend on your grahics card and monitor, for best results select the highest option available.
Changing the ResolutionTo change your resolution simply slide the bar along to the resolution of your choice and then click the Apply button.
After clicking Apply your screen will resize to the new resolution and you will be presented with a confirm dialogue box, if you are happy with the way your screen looks then simply click Yes, if you would like to try a different resolution click No.
When you have finished simply close the Display properties box.
Jan 13, 2011 | Computers & Internet
Nov 26, 2008 | HP Vs17 17" LCD Flat Panel Monitor
Zoomed In Screen
If it's what I think it is, it's a very common occurrence. Don't worry about it, first of all.
All you need to do is right-click on your desktop and go to your display settings. Then change the pixels x pixels to a higher setting. Then click apply. Accept those settings and it should be better.
To explain, when you play a game, it is shown in a certain resolution. But the game changes your computer's resolution so that the game will display correctly. Sometimes, it doesn't change back. It's not a bad thing, but it IS a little inconvenient.
If this does not work, let me know!
Nov 21, 2008 | HP Pavilion dv9000z Notebook
We can't get our screen resolution back to what it was (1024x768) it changed when a game being played ended. It runs on 800x600 at the moment and everything is too big.
The display properties dialogue box will appear as shown in fig 1.1 below, click on the settings tab at the top right of the box.
Screen Resolution
Color Quality
This pull down box will contain the current colour options available, again this will depend on your grahics card and monitor, for best results select the highest option available.Changing the Resolution
After clicking Apply your screen will resize to the new resolution and you will be presented with a confirm dialogue box (see left), if you are happy with the way your screen looks then simply click Yes, if you would like to try a different resolution click No.
Aug 05, 2008 | Computers & Internet
Screen resolution
you will need to reinstall your video/display drivers and make sure you download the correct ones for the site. (toshiba's site).
Jun 19, 2008 | Toshiba Equium 6200M (PV1026U-01A) PC...
HP Vs17 17" LCD Flat Panel Monitor Logo
62 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
