Question about Sansui DTV2760 27" TV
Sansui Hard rock 294-isx service mode
In Sansui Hard rock 294-isx, i entered service mode, changed some values in the 6th option like remote operation. previously it was 2 after i changed it into 0. now the sansui remote is not working. can i open service mode without using remote? because to set old value to that remote operation.
please guide me how to restore the value.
m.jayaprakashm@gmail.cm
  • mahendran_ph May 17, 2009
    In Sansui Hard rock 294-isx, i entered service mode, changed somevalues in the 6th option like remote operation. previously it was 2after i changed it into 0. now the sansui remote is not working. can iopen service mode without using remote? because to set old value tothat remote operation.
5 Suggested Answers
Pookeybrain
  • 51 Answers
SOURCE: 1999 sansui tvm1915 tv
You'll most likely need a Sansui remote made to work with your specific model TV. I have similar problems with my Toshiba TV. Check eBay.
Posted on Nov 10, 2007
  • 1694 Answers
SOURCE: Black out; R342 Burts, Horizontal Ic Damage
Search and obtain service literature....
What part # and location is horiz output TRANSISTOR ?
.........T.
Posted on Dec 19, 2007
  • 238 Answers
SOURCE: Burst R342 and i cannot read the value of R342: Black out
hi joe, u will have 2 get the diagram from a book stores for ur model..thats the only way out,..or the manufacturer can help u with the R342..
Posted on Jan 10, 2008
SOURCE: Sansui SV 2102 GOT SOME PROBLEM PLEASE HELP TO FIND OUT A SOLUTION OR KINDLY INFORM ABOUT THE SANSUI HELP NO.
what is the cost of picture tube for model SV 2102
Posted on Sep 14, 2008
RALilja
  • 363 Answers
SOURCE: service manual/schematic
You can search this database for the service info you seek about your tv here:
http://www.samswebsite.com/photofacts.html
Most service manuals with schematics cost about $27.95 for the PDF version of it, otherwise the paper version is about $15.00 more for handling and shipping.
You will need the chassis number of the unit in question in order to search for it. I hope this helps!
Good Luck!
Rich Lilja
Posted on Feb 07, 2009
How to reset sansui to factory settings
There are two methods to reset TVs. The first is simple to do; a Hard Reset. The other is somewhat skilled; is a Factory Reset (System Reset). To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight is better. This procedure will make it a hard reset. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; check the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/
Service mode entry, adjust and exit procedure to many popular brand TVs are given. Never forget to exit the service mode, after all adjustments have been done.
Jun 06, 2016 | Sansui HDLCD3250 32 in. LCD TV
How to set my sansui tv back to orig.factory? Cuz my tv dont adopt my remote control. & my tv screen hav a factory word that cant be deleted?
There are two types of reset to TVs. The first is simple to do; a Hard Reset. The other is somewhat skilled; is a Factory Reset (System Reset). To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight is better. This procedure will make it a hard reset. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. To enter the service mode, you should have its remote control. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Feb 01, 2016 | Televison & Video
Sarvic code of sansui hard rock
NB: Please read and understand well, the instructions to enter the service mode, before you begin. Be very careful. Note how to "EXIT" the service mode; after entering and adjusting data. This is very important.
Search the site by type in the "brand name" to your device, in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
Oct 23, 2015 | Sansui Televison & Video
How do I restore my sansui SV21276 multi system tv without a remote controller?
You should have its remote control to do a reset.
To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. This procedure will make it a hard reset. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Aug 24, 2014 | Televison & Video
Sansui-hardrock 294 i sx
Waht is the picture tube Prise for Sansui Hard rock-294-i sx Telivision?
Sep 07, 2013 | Sansui Televison & Video
Iam a technition of tvs my sansui tv model 294 isx the fualt is when turn on tv h line com tv turn of again
Being a technician, why couldn't you understand that the fault to your TV is with vertical sweep failure? Check its vertical output section circuit for any loose solder terminals, or damaged component/s.
Aug 20, 2013 | Televison & Video
How do i reset my sunsui 19 inch hdmi tv to factory seting because I'm getting a cloudy signal
To reset it to its factory settings, you have to enter its service mode option. Do not change any values there if there is not necessity. Select the factory mode option only. To get more details about how to enter the service mode,http://electronicshelponline.blogspot.com/ check this link. It has details about how to enter and exit service mode. After entering the service mode, and have done the settings, it is a must get out from it, by using the exit option. All procedures are given there in detail. Pull up older posts there, by the sites' left side bar.
Jun 07, 2013 | Sansui 19 in. LCD TV
I have a sansui k2k121 tv and i want to know it's technical code , because it's screen is not properly displayed in regular form. screen is slightly curved form.
You can enter the "Service Mode" by turning the "On" then holding the Vol Down (-) on the set and the 9 on the remote for more than 2 seconds. This enters the set into service mode. Make sure the volume is all the way down first. Be Warned, messing with these adjustments can cause irreparable damage to the set. Before you make ANY changes I suggest you go through the list and write down each and every Name and Value in the menu. That way you have something to fall back on when you change something and want to restore it's original value. To exit service mode and save your changes, Power the off with the power button on the set.
Dec 01, 2010 | Sansui DTV2760 27" TV
How to enter into Service Mode in Sansui Hard Rock 21 eye model
If you wish to get some details; visit the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
May 14, 2009 | Sansui DTV2760 27" TV
Sansui DTV2760 27" TV Logo
245 people viewed this question
Top Sansui Televison & Video Experts
matt martin
matt martin
Are you a Sansui Televison and Video Expert? Answer questions, earn points and help others
