Question about Ovens
Conection of a beko electric cooker
Just purchased a beko cooker and im finding it hard to connect it problem being the screws are so small and cant get them undone
  • 26 Answers
Pretty normal problem with Beko.
You need a Philips 2 screwdriver to get a suitable grip on the screwhead.
Good Luck!
Posted on Nov 27, 2008
Beko fan oven making noise
If you have a problem with your cooker or oven then this diagnostic video will help you find the fault on your beko oven and i hope it helps you. i have put a link also so you can get the parts for your cooker
cooker parts
Need help fixing your appliances
these repair guides will also help you find and understand the exact problem with your cooker
How to Repair
and if we really helped you you could always buy us a beer
Buy Paul Beer
Jan 08, 2014 | Belling XOU492 Electric Double Oven
I have a Beko Electric Cooker, The oven is making intermittent rattling noises, which i think is the fan? How easy is it solve.
some models are acsessed inside the oven if you open the door and can see screws at the rear of the oven youre in luck otherwise it remove the rear cover of the oven and do it from there
Nov 13, 2013 | Ovens
Beko oven
If you have a problem with your beko cooker or oven then this diagnostic video will help you find the fault and i hope it helps you. i have put a link also so you can get the parts for your cooker
cooker parts
How to Repair
Buy Paul Beer
Jul 06, 2013 | Ovens
I ve got beko electric cooker model DC543 and the oven doesn't work
This tutorial will show you how to check your Beko element and how to replace your Beko cooker element.
Here are the 3 main faults to look for in your oven or cooker that is not heating
    1.Your Beko oven will not work until the clock/timer has been re-set after replacing an oven element or tripping the electrical supply. Consult your Beko manual.
    2.If your Oven is not getting hot or heating up it could be a faulty element, if the fan in the oven is running and the thermostat light is on, this will lead us to believe that the element has gone faulty. With grills the thermostat light should come on there should be heat, if not then this could be the grill element or the thermostat.
    3.When you turn the oven on, the household electrical supply trips on the Rcd (this is the earth trip in the fuse board sometimes called the breaker tripping) your fan oven element has gone to earth and needs replacing. For all you Beko elements
    If this helped you why not get me a beer?
Paul is from the Naturally he would appreciate beer How to Repair Home...
Jan 15, 2011 | Ovens
Have beko D533W electric cooker oven not heating up fan still working
Generally speaking, if the fan is working o/k, then it is usually the fan oven element that has failed.
This is usually located at the rear of the oven compartment behind a removeable cover.
Nov 14, 2010 | Ovens
Have a new electric cooker but the oven and 1 of the hob plates isn't working dc5422 beko
hi chances are that the internal thermal cutout fuse has gone this fuse is situated on the right hand side of the cooker when you have taken the back plate off about half way down it has two wires attached to it and is screwed with a self tap on the right hand corner of the body of the cooker near the middle of the cooker. You can buy this part and have it delivered for about £6 so is a very cheap fix.
Sep 17, 2010 | Ovens
Beko dvc 62 ,all electrics tripped out ,put cooker
The element has blown. It will cost you around
May 16, 2010 | Ovens
No fan or heat
Hello..... have you (a) checked that you have power going to the oven...(b)...With the power to the oven switched off open the terminal block (where the cable from your socket enters the oven) check that all connections are secure....(c) remove the rear panel of the oven and check that the safety stat is ok.......(usually small square white or gray unit wit two wires running to it found on rear of main oven...it is usually fixed to a bracket or directly fixed to the cabinet...test for continuity with a multimeter if open circuit ..that is no meter reading relpace it
regards Sir Galahad
Jun 28, 2009 | Belling XOU492 Electric Double Oven
Beko D533 cooker only half working
where the power goes in there should be fuse links on both sides if they all in then its the thermal fuse inside
Dec 07, 2008 | Ovens
Ovens Logo
721 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
