Question about Philips Televison & Video
I cannot open the DVD drawer on my Philips DVDR3480 DVD RECORDER – it just won’t open? The screen display just keeps saying ‘Error’. Any help is appreciated.
I have two of these dvd recorders and both have the exact same problem where the drive won't open. It opens fine when there is a disc in the tray. So I just unscrewed the cover, press the white part which would be over the center of the disc as it's trying to open, it should then open. Then just make sure there is always disc left in the tray.
Posted on Sep 18, 2012
  • Chris Poacher Apr 29, 2013
    brilliant, I just recapped the power supply on my broken 3480 tonight and forgot about that sticking door. I wasnt happy banging it all the time to open. I just tightened up the screws for the drive, bend the front metal shielding down ever so slightly, and as Mark says, as long as there's a disk in the drive it'll always open ok. I just have to put a sticker on mine saying 'DO NOT LEAVE DVD EMPTY'. Pressing the white disk on top of the drive works fine when the top cover is off, but that is not an option while I have a 2yr old running around ;) .
  • Mo Jo
    Mo Jo Feb 03, 2016
    This worked for me too... Leaving a disc in all the time seems to work... Can't believe this doesn't have a place to slide in a paper clip to open it. Thanks Mark
  • 593 Answers
The DVD drawer might have a small hole under the tray. You can use a straightened paper clip to push into the hole and this is supposed to manually push the slot out enough to grab and pull out. The DVD might not be seated in there.
Posted on Nov 27, 2008
  • jhn12340
    jhn12340 Apr 13, 2012
    I have the same model with the same problem. If you tap the unit above the dvd drawer it should open. It may take two attemps to find the exact spot and the right weight to the hit (it's not a hard hit).
Why does not the philips dvdr3480 record?
I would start with the dvd format used for recording, the simplest being dvd+r and dvd-r. Does the unit play a pre-recorded dvd and/or cd? If not, the laser assembly would be the first suspect. The delay in reading discs can be a sign of a borderline laser. Is your record overwrite function turned on, this overwrites previous material when starting each new recording when using +-rw discs. Verify if a format is required for the type of disc used for recording, page 45. Is the correct country/region selected?
Oct 26, 2017 | Televison & Video
I have a DVD that is stuck in my TIVO. The screen
Take the DVD player aparts,take out DVD disc out of the drawer,check the open/close drawer button again.Same result indication on the screen say is open infact it close.The motor the help open and the dvd drawer it dead.Need the motor replaced.
Jun 26, 2010 | Humax T800 TiVo 80-Hours Video Recorder
DVD DRAWER won't open
OK.
I assume the display does not say 'locked' when you press eject.
A DVD drawer is run by a small rubber belt on most of these old machines. This belt can be worn out (Very common)
The DVD drawer position is detected by a switch that can be pressed in or out to detect the drawer is closed or open. This switch can cause the drawer to stay in if it thinks the drawer is not yet closed. Cleaning the switch (Take the DVD drive out and remove and clean or replace the switch) can usually fix this.
A fault with the DVD process cicuit board can also cause this. I would recommend a new machine if this is the case.
Testing:
Bad belt - the DVD drawer shifts a bit when the eject button is pressed.
Bad switch - a whirring sound can always be heard when the DVD is first powered on. May give an error in the display.
Bad process board - Generally, says open forever or close forever and will not change back to normal display. You cannot get any other functions to work after you press eject. Unplug the machine, its normal until you press eject again. (just a generic common thing)
Mar 22, 2010 | Sansui VRDVD5000 DVD Recorder/VCR
Recording with a philips DVDR3480 using dvd+r
my phillips dvdr3480 will not let me record from my camcorder it states writing has failed please help
Dec 10, 2009 | Philips Televison & Video
Unlock region code for Philips DVDR3480 region code 5
Here you go.....
The only thing you do to unlock DVDR3480 is this:
With NO disc in your DVDR3480-player you press SETUP on the remote and then press this code: 5 0 1 8 ,now you can pick Region-code with the remote from 0-6
( 0=Region free)
Karlos
Jul 07, 2009 | Philips DVD625 DVD Player
Disc drawer says BLOCKED and will not open. No disc is inserted
I had the same problem . I had to take the outer casing off and was able to open. to keep this from happining again I always leave a disc in the disc drawer it seems to solve the problem
Mar 07, 2009 | Philips DVDR3450H DVD Recorder/HDD...
Recording from my v-box to phillips dvdr3480
our dvd writer does not detect in device manager ?
Jan 28, 2009 | Philips Phillips 16X External DVD 2XRW...
Need a user manual for dvd player dvdr3480
Download User Manual of Philips DVDR3480 from Philips Support.
Regards,
Oct 02, 2008 | Philips Televison & Video
Viewing cable tv channels
Use an av output from your media box and plug it into the line input of your DVD recorder. It can record using the line input of the DVD recorder.
Aug 09, 2008 | Televison & Video
Televison & Video Logo
1,951 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
