Question about Magellan MAP 330 GPS Receiver
Lost satelite signal and screen become hard to see
Was working fine and then the icon for lost signal came on. I left it for a while and still no signal. Thought the batteries might be getting low so I put some ne ones in. When I turned it on you could only see the screen if you placed it on the right angle...still no signal?? Is it terminal or worth fixing? Any feedback would be much appreciated.
How do I download the updates to my TOMTOM GPS
You use a program from tomtom wesite named tomtom home. Download to pcinstall it then connect device to pc using usb cable. The tomtom home program will list all updates available and install all free ones. Ensure you make a backup first. If you have accidentally selected the flight mode from the menu options this turns off the satelite receiver so check this setting also from the menu you can select the satelite network and see if there is a signal being received and how many satellites it is connecting to. It requires at least three to function and possibly will not work with less than five if there is none then a reinstall of the program will need to be done following instructions from web site on reinstalling the application. You must backup the device first as you cannot download a free map. Follow the website instructions and if there is still no satelite signals being received then its busted. From the main map screen the signal strength may be segn as a small icon like a volume icon. Press this and you also get signal information.
Mar 19, 2013 | Tomtom One GPS
My Casio Gw-300 is not receiving the satelite signal to receive daylight savings time. The display is not showing the satelite dish or any bars in the receiving indicator
I'm having the same problem. It's been working fine for about 4 years and now there are no bars or the picture of the satellite. There is a little "C" or "[" next to where it should be though. Maybe that is some sort of error message? I left it in my window for three days straight to get full days of sunlight and the battery is full but still no signal. Did something happen to the atomic signal carriers? Or is my watch finally dead?
Nov 02, 2009 | Casio G-Shock GW300CA-1V Wrist Watch
My toshiba satelite L-35 screen fade to black and
The LCD ribbon convector is loose or damaged or the LCD is damaged
Apr 23, 2009 | Toshiba Satellite A100-S8111TD Notebook
Can't lock onto satelite signal!!
Sounds like the aerial. There is a very fine wire in the center of the male aerial plug. If this is bent then you will have that problem. Aerials are hard to get, dealers say they are obsolete...update your model. Cheers, Peter
Feb 27, 2008 | Lowrance Globalnav 310 GPS Receiver
RCA 40 in
Are you using just one box on this set. I suspect a bad set-top box...accordianman
Jan 08, 2008 | RCA Scenium D40W20 40" Rear Projection...
Updated to 2008 maps, now I lost my local roads and town maps
Turn on the Garmin. Look for the little wrench on the screen and select it. Now look for Map, select Map. Now look for Map Detail. Verify that it is set to "Normal" or Higher to get more map details.
Dec 30, 2007 | Garmin StreetPilot c550 GPS Receiver
Won't tune in all channels
Do you mean the channels from the internal tuner which would be channels 22 to 68, or do you mean satelite channels, as I do not know whether this set has a built in satelite receiver? Satelite broadcasters are often changing frequencies or satelites.- Programs come and go!
Oct 20, 2006 | RCA F27440 27" TV
Magellan MAP 330 GPS Receiver Logo
Top Magellan GPS Experts
Marvin
Marvin
Will Halftowaite
Are you a Magellan GPS Expert? Answer questions, earn points and help others
