Question about Dell XPS M1330 Laptop
Dell XPS 1330 touchpad scroll areas quit working
About a month after I bought it the areas of the touchpad used for scrolling up/down and left/right quit working. How do I re-enable them? Thank you! Patrick
  • Fajju Jan 14, 2009
    same problem can any one help....
I do have the same problem.. and if someone can let me know how to fix this.. i wud do tht by myself
Posted on Dec 06, 2008
  • Dell Master
  • 32,281 Answers
Hi Patrick,
The most likely problem is that the ribbon cable from the touch pad is not making proper connection with the motherboard.
I would recommend you get this repaired under warranty, there is a bit of work involved in pulling the laptop apart to get to this cable & connector and if you do something wrong it could void your warranty.
I can give you instructions if you wish to try and fix it yourself.
Let me know.
Posted on Nov 26, 2008
How do I enable my scroll bar on the keypad??
I trust that you understand that scroll bars are only visible if more than 1 page is to be displayed. If you have magnified a particular page, the scroll bar may be outside the view of the screen - on the right side, Scroll to the left until you see the right border.
Perhaps you are referring to the touchpad.
The scroll feature on the touch pad is not visible. You enable the touchpad by tapping twice on the upper left corner of the touchpad. A lite will appear in that corner when the touchpad is ON.
Then the scrolling feature is enabled on the right side of the touchpad. Simply run your finger up and down the right side of the touchpad. For more information, refer to the User Guide here:
http://h10032.www1.hp.com/ctg/Manual/c02102005.pdf
Dec 20, 2014 | Compaq Presario CQ62-219WM Notebook
Touchpad enable
It is more than likely a driver issue. You can navigate to the dell support site and then search for your device. Locate your mouse pad drivers download and install them and you should be good to go.
Apr 25, 2014 | Dell XPS Computers & Internet
Xps 14 touchpad problem
Hi see double click the Synaptics icon on the most right task bar then play there to get default settings.........
Good Luck
Feb 02, 2013 | Computers & Internet
Scroll on my touchpad doesnt work
You need to download your touchpad driver made for your XPS off the dell website. When windows installs, or when you buy a laptop, it doesn't come with the latest drivers.
Nov 01, 2009 | Dell XPS M1530 Laptop
Problem in dell m1330 touchpad scroll and bluetooth
you may need to re-install your touchpad scroll driver and bluetooth software, you may find it on your cd installer that came with the computer.
Oct 13, 2009 | Dell XPS M1330 Laptop
I don't know how to use the scroll areas to the Right and Bottom of the Touchpad on my Dell XPS M1730
There is a software that comes preloaded with dell called Synaptics Pointing Software .See to that it is installed.From the software enable the required scrolling mode.by moving your finger up and down slightly pressed along the right most areas of the touch pad allows vertical scrolling while moving the finger horizontally at the bottom side of the touch pad allows horizontal scrolling.Also see to that the synaptics software is enabled at startup
Sep 29, 2009 | Dell XPS M1730 Notebook
I have a Dell XPS M1710 laptop. The touch pad does not work.
Unless it is a hardware fault open the control panel>system>mice and uninstall the touchpad. Then rebott. It should solve the problem.
Jul 23, 2009 | Dell F3534 Touchpad
Xps 1530 touch pad scroll vertical horizental does not work on
What you need to do is install all the software that is included with the Dell XPS drivers and utilities cd. You also have a software there that is for your touchpad. What you need there is either the quickset or the synaptic itouch software. If you could not find it from the disk.. go to support.dell.com and download the drivers and utilities from there.
Mar 26, 2009 | Dell XPS M1530 Laptop
I have a dell xps 1330 and the touch pad stopped working abruptly. Now there is an icon that looks like a note pad and pen to the center left of the display. What did I do, and how can I get the touchpad...
had a similar problem on a laptop i was working on - the touchpad quit immediately after an update.
try using an external USB mouse and then reinstall the driver for it - that's what fixed it for me.
Jan 15, 2009 | Dell Inspiron 6400 Notebook
DELL xps touchpad
Sounds like a driver glitch, from the device manager, try uninstalling it, then do a hardware search, it will locate it and reinstall the drivers automatically. If this doesn't solve the issue, then the touch pad has failed and needs replacing.
Jun 20, 2008 | Toshiba Satellite P205-S6287 Notebook PC
Dell XPS M1330 Laptop Logo
346 people viewed this question
Alun Cox
