Question about Sansui DTV2760 27" TV
Power Supply Board San2701 Sansui Lcd TV
My power supply board cooked itself and burnt out 3 capacitors and it looks like the transformer as well I need to replace it or get it repaired I need to know were I can do that
  • jeffrybrown Nov 26, 2008
    I am in Australia Topbuy is in the USA
    Genius:
  • 1,011 Answers
Dear Sir/Madam,
click this link for contact sansui it will be help....
thanks
good luck
Posted on Nov 26, 2008
  • 365 Answers
Try to search the sansui site and there will be technical forum.explaining the thing to them they could help you or otherwise you can show it to a mechanic nearby since it is not much complicated
    Master:
  • 505 Answers
You can contact bestbuy. Go to their website www.bestbuy.com or call them at 1-888-BEST BUY
(1-888-237-8289).
They are opened 24x7.
They will be able to repair the product,
Thanks
THETV WONT POWER ON
Check your power supply for proper operation. Look for burnt resistors, bad diodes, leaking or bulging capacitors. If time permits check as many of the parts that you can on that board.
If you check out ebay for that tv set, often you will find parts listings for the set at a much better price.
Aug 27, 2015 | Sansui HDLCD3210 32 in. LCD TV
Philips 47PFL3603D LCD TV bue led flashing no power
The issue you describe is consistent with a power supply board issue. This is the board where the AC goes to. This problem may have occurred as a result of irregular power supply, or excess power supply or power surge.
The TV is receiving current but cannot circulate or transfer the current to other necessary part of the TV because of the defective power supply board. You might be lucky it's just a blow fuse. Also a defective transformer can cause your TV not to power on.
All these can be checked on the power supply board.
But more often bad capacitors causes problem on the power supply board. I do not think the power board needs replacement, rather those defective capacitors is causing this issue. Open unit up and take a look at the power supply board.You will probably see one or more electrolytic filter capacitors that are bulged up in the top-not perfectly flat like the others.
The value of these capacitors will be different, most likely they will be somewhere around-820 to 2200uF/25 V( or /10V sometimes)
You can replace them with same values but I would recommend the voltage rating to be higher(like 35V for an original 25V) for reliability purposes.
What happens is,these bulged top capacitors will cause a low and unfiltered DC voltage=main board will malfunction(the relay will keep clicking until the caps are holding enough charge to bring the voltage up over a threshold point).
You can buy these capacitors at any Fry's or Radioshack store or you can order them online at vendors like "mcmelectronics.com"(look for electrolytic capacitors). After replacing these capacitor(capacitors) most likely the normal operation will be restored. Or you can by a refurbished complete power board to save you some stress.
Note: There may be also some other causes for this symptom ,like a defective T con board ,or main board,but the bulged top capacitors are the most common cause for this issue.
If you don't know about TV repairers, take the TV to the nearest repairman to fix the fault for you. Also, note that TV stores a lot of current, so wait a while before opening the TV back cover.
I hope this helps.
Regards.
Jan 05, 2012 | Philips 47PFL3603D LCD TV
Our Sansui HD LCD 3212 32" has audio but no picture. Can you tell me what is wrong and how to fix it. This TV is not used much and went our of the 1 year warrant January of 2011.
Must have to take the tv aparts.U must have all the tools and understanding basic electronic and also u must able to do basic soldering works too?Yes,u must have to do examining the tv power supply board carefully,that the board where the tv power a/c cord plug into it.U must have check all the tv capacitors components parts,if the tv have any bulges or puffing up any capacitors parts at all will and could causes these problems.U must have to changes all the tv dying and leaking capacitors parts in the tv power supply board will to help the tv power supply board to work correctly again.If u check and examining tv power supply board carefully but have seen none or any dying and leaking bulges or puffing up capacitors parts at all.Than this tv have a 1 or 2 long boards that are called the LCD inverter boards it is dead.These 1 or 2 long inverter boards only job are to help and provided the tv LCD screen panel to have a backlight on the screen to see a picture on the tv LCD screen panel.Must have to be changes 1 or 2 long inverter boards to fixed the tv have sound but no pictures problems.If u can't do soldering work and can't changes capacitors components parts at parts levels.U can tries websites like Shopjimmy.com,Ebay.com to buy a whole new refurbish tv power supply board and or the 1 or 2 long LCD inverter boards too for the replacement.
Nov 10, 2011 | Sansui HDLCD-3212 32 in. LCD TV
No power
Got no power on my tv need sone advice as change fuse still not working
Sep 07, 2011 | Sansui HDLCD3200 TV
I have a Sansui SV4210 LCD and the blue standby light comes on when I plug it in but shuts down after 3 seconds, did the power supply go or what do you think is the problem?
I hope this helps.
Regards.
Aug 30, 2011 | Televison & Video
Please why is my Samsung LCD red power light on, but the tv can't come on?
I had a similar problem with my Phillips 42 in. LCD HD TV.
Here's the problem. The Power Supply Board. I opened my TV up(warranty was up of course) and found several bad capacitors. Phillips and several other companies were sold capacitors that although were highly rated failed within 5 years because of a lack of preservatives. All sorts of electronic equipment is now being effected due to these defective capacitors.
Solutions?
1. Take it in and have it fixed
2. Open it up, check the board for faulty capacitors(bulged or leaking) Buy a new Power supply board and install it.
3. Remove PSB, remove faulty capacitors and replace with compatible new ones.
Hope this helps
Dec 09, 2010 | Sansui LCDW2300 23 in. Television
Tv runs for about 3 minutes shuts off I can restart right away but 3 mins later it shuts itselfe off again
Solutions?
Hope this helps
Sep 19, 2010 | Toymax Magnavox 47MF437B 47 in. LCD TV
Picture dims, then gets brighter, then dims again. Its a HDLCD4212
There are two places to look for the problems, the backlight inverter board and the power supply. Look at the power supply first since it is easier to get to, look for burnt parts, bad capacitors, etc.
http://en.wikipedia.org/wiki/Capacitor_plague
Please post back what you find.
Nov 24, 2009 | Sansui HDLCD-2600 26 in. LCD Television
Location of Power Supply Board ???
the pwr supply board has the AC PLUG going straight to it!...and yes it has a transformer...and fairly large capacitors....but so does the x-board...and the y-board on a plasma
Dec 20, 2007 | Akai LCT2721AD 27 in. LCD Television
Sansui DTV2760 27" TV Logo
49 people viewed this question
Top Sansui Televison & Video Experts
matt martin
matt martin
Are you a Sansui Televison and Video Expert? Answer questions, earn points and help others
