Question about Pinnacle PCTV Stereo Video Capture
During installing tv test failed
During installing software the tv test showing faild. our original cd become repture hence we r using its copy. our first version were v5.9 . so please inform me as possible as early
Plz update ur all pctv divises and drivers which will give u all test possitive
Posted on Jan 20, 2009
HOW CAN I COPY THE VIDEOS IN THE TAPS TO A CD PLEASE SHOW ME THE STEPS
connect your handycam by it's original usb cable with a computer. Copy the data into it. Use nero burn software/handycam's original software to write data into any cd.
Aug 26, 2011 | Sony Handycam DCR-TRV265E Digital...
Who do you downlaod games and/or apps from a computer, what accessories do i need. can i do it from computer to computer or do i have to have internet connection on the cruz to downlaod?
Karen,
You can download games and apps from one computer to another in preinstalled stage,ie, you need the original software. Once installed, its components go to various places on the computer (which we need not know). To be able to run them, we just click on its icon and the computer and the software do the rest. if you just copy installed programs from one computer to another, you will not be able to copy whole program and hence it will not run at all.
Hence, if you have the original program, then you will be able to copy/download from one to another computer and then install and run it.
Jul 07, 2011 | Computers & Internet
My window copy did not pass genuine window validation .
if that the case, its either yo don't have the original serial key for your windows xp. if ever that is, go and reinstall your xp and try to download a program for the validation of your xp. it will bypass the authentication security and your xp will be authenticated.
Nov 07, 2010 | Microsoft Windows XP Professional With...
Fails to start
Insert the installation disc and select repair.
If problem persists, format the windows partition and install a fresh copy of the OS from a ORIGINAL CD.
Mar 26, 2010 | Microsoft Windows 98 Second Edition for PC
I cant find hpc20155.xml
This is direct from the HP website. some files were renamed... it works!
ISSUE: During the LaserJet P2015 Series USB installation, the following error message is displayed: 'hpc20155.xml' on HP LaserJet P2015 Series CD is needed SOLUTION: The HP LaserJet P2015 EWS driver on Microsoft Windows Update and Windows Market Place Web sites is newer than the driver that is included on the product CD that shipped with the printer. Because of this. the Microsoft Windows (Found New Hardware Wizard) will install the driver from the web. Some file names are inconsistent between driver version 1.0.0.12 and version 1.0.0.10, including the hpc20155.xml file, hence the attempt for the driver to search for the hpc20155.xml file will fail, and prompts the error message. To resolve this issue perform the following:
  1. Click the Browse button on the error message.
  2. Browse through the CD to Drivers -> windows 2000_XP .
  3. Select the file hppcp504.cab , and click OK .
  4. The error message "The Software that you are trying to install has not passed the windows Logo Test " appears. Click Continue Anyway .
  5. If the error message "hpc20155.xml on HP LaserJet P2015 Series CD is needed " appears again, follow steps 1-3.
  6. The required files are copied, and the driver is installed and ready to use.
If the issue still persists then perform the following in the order listed before trying to reinstall the software.
  1. Go to Start -> Control Panel -> System -> Hardware -> Windows Update.
  2. Set the option to Never search Windows Update for drivers .
NOTE: It is important to re-enable the Windows Update function after installing the printer software, otherwise the updates for all the other software on this computer will be blocked. After disabling Windows Update, complete the following steps. Be sure to reenable Windows update after installing the software:
  1. Disconnect the USB cable and remove the device listing from Device Manager
  2. Go to Start ->All programs ->HP ->P2015 ->Uninstall , "OR" Go to Add & Remove and check for the P2015 and uninstall .
  3. Then go to Printer & Faxes . Select the HP LJ P2015 icon and press the Delete button on the keyboard. After deleting the printer icon, go to File and Server properties . Go to Drivers tab and remove any P2015 drivers if listed.
  4. Also delete the following files/ folders C:\program files\HP\toolbox Fx or P2015 C:\documents & settings\app data\tool box Fx
  5. Run the scrubber.exe . Find this on the cd X:\utils\ccc\scrubber.exe & scrubber.ini NOTE: The Scrubber utility can also be downloaded from the web if the original installation CD is not available. However, it is only available as part of the full software installation package named hp_LJ_P2015_Full_Solution_AMWE.exe on hp.com . Once the files are extracted to a folder just open the util folder then the ccc folder and the scrubber.exe file will be visible.
  6. Paste these files at the following path and run the scrubber.exe C:\windows\system32\
  7. Empty the recycle bin
  8. Turn the printer back on.
  9. Now install the printer software again. Connect the communication cable to the PC and printer when prompted during the installation.
Sep 07, 2009 | Office Equipment & Supplies
Where can i downlad software for my veo stingray webcam
Here are some drivers to download.
http://www.softsci.com/veodrivers.htm
Nov 20, 2007 | Veo Stingray
Crashed Widows XP on my sahara laptop
it sounds as if you the system as you say has failed, you can use a friends copy of XP but use your product key number on the underside of your laptop. Secondly, the vista CD may be an upgrade cd but you will probably find that it will do a complete install as they are normally the same cd, just set your cd drive as first boot device and then run the cd,select new installation and not upgrade; i have an upgrade Vista cd but installed a full operating system on another partition, therefore it wasnt an upgrade but it still worked.
Sep 25, 2007 | Microsoft Windows XP Professional With...
Pinnacle PCTV Stereo Video Capture Logo
198 people viewed this question
Top Pinnacle Televison & Video Experts
David
David
Daniel Dollive
Daniel Dollive
Are you a Pinnacle Televison and Video Expert? Answer questions, earn points and help others
