Question about Whirlpool GS5SHAXN Side by Side Refrigerator
Whirlpool GD27DQ ice maker not working after changing water filter
SOURCE:
SOURCE: Ice maker not working
I replaced both silinoids and the ice maker. The ice maker will freeze water but not fill with water. My refridgeratoor is an a Amana
Posted on Mar 08, 2008
aborcass
  • 2651 Answers
SOURCE: whirlpool ice maker
this is a hard one to diag in person, let alone via email. you know your not getting water to the ice maker, problem is finding out why, ther is (or should be) a tech sheet behind the kickplate of this unit with a little trouble shooter and diag procedure for the ice maker. folded little blue/and or brown paper.
1. is the water line leading from the valve to the ice maker fill clogged/frozen??? pulll the machine out and youll see the line leadding to the top corner of freezer, disconnect that line and try to blow though to the insde of freezer, should blow withno resistance. if so your good if not youll need to thaw that line
2. is the red light blinking on the inside of door. its a sensor for the ice maker if its faulty you wont get ice either.With the flapper on rt wall of freezer depressed the light should remain on solid, if continues to blink a pattern, 1 and 1 quick blinks, 1 and them 2 quick blinks, youll need to replce the electronics
3. is the water valve itself just not sending water to the ice maker. its a dual vavle 1/2 does water and the other half feeds the ice maker . generallly youll hear the valve being energized, just no water coming through
4. ice maker itself can be damaged and not calling for water at all.a pretty common issue with these electonic control ice makers is the center gear actually over torques itself and winds up snapping itself(at least the tabs that hold ino place snap anyway). gaining acess to the face of the ice maker will tell this.
while looking at the exposed from\nt of ice maker you should see the center gear adn the 2 tabs holding the gear on as well. ther shoud be a SMALL but definite space betwwen the 2 tabs in middle of center gear, as if it were pressed on and the tabs spread back open to hold onto the gear. if 1 of the tabs is cracked or the gear isnot mounted correctly because of the tabs, you best bet is to replace the ice maker assy
GOOD LUCK
Posted on Mar 30, 2008
  • 1073 Answers
SOURCE: GE GSH22SGRE - water dispenser not working but ice cube maker working fine
check the water valve on the back of the ref. it sends water to the ice maker and water in the door one can work and the other one not
Posted on Apr 30, 2008
shaggyrat
  • 1224 Answers
SOURCE: Ice maker not getting water after changing filter
Check the following:
 Is the freezer door closed completely?
 Is the ice storage bin installed correctly?
 Is there ice in the storage bin?
 Has the ice frozen in the storage bin?
 Is ice stuck in the delivery chute?
 Has the wrong ice been added to the storage bin? Use only
cubes produced by the current ice maker.
 Has the ice melted around the auger (metal spiral) in the
ice bucket?
Dump the ice cubes and clean the ice storage
bin.
 Is the ice dispenser stalling while dispensing “crushed”
ice?
Change the ice button from “crushed” to “cubed.” If
cubed ice dispenses correctly, depress the button for
“crushed” ice and begin dispensing again.
 Has the dispenser arm been held in too long? Ice will stop
dispensing when the arm is held in too long. Wait 3 minutes
for dispenser motor to reset before using again.
The ON/OFF switch is located on the top right side of the freezer
compartment.
To turn the ice maker on, slide the control to the ON (left) position.
To manually turn the ice maker off, slide the control to the OFF
(right) position.
NOTE: Your ice maker has an automatic shutoff. The ice maker
sensors will automatically stop ice production, but the control will
remain in the ON (left) position
REMEMBER:
 Allow 24 hours to produce the first batch of ice. Discard the
first three batches of ice produced.
 The quality of your ice will be only as good as the quality of the
water supplied to your ice maker. Avoid connecting the ice
maker to a softened water supply. Water softener chemicals
(such as salt) can damage parts of the ice maker and lead to
poor quality ice. If a softened water supply cannot be avoided,
make sure the water softener is operating properly and is well
maintained
The Dispenser Lock (on some models)
Your dispenser can be turned off for easy cleaning or to prevent
unintentional dispensing by small children and pets.
NOTE: The lock feature does not shut off power to the product, to
the ice maker, or to the dispenser light. It simply deactivates the
dispenser levers. The ice and water dispensers will not work.
Style 1: Press the LOCK BUTTON to lock the dispenser. Press the
UNLOCK button to unlock the dispenser.
Style 2: Press and hold the LOCK OUT button to lock the
dispenser. Press and hold the LOCK OUT button a second time to
http://www.ajmadison.com/ajmadison/itemdocs/2261717.pdf
Posted on May 15, 2008
SOURCE: My whirlpool refride #GD5RHAXNQOO is not releasing water to the ice maker fill line
Hi all rootbeergirl here. I had the optics changed and the moter on the other side of the icemaker changed I was able to send them both back to Whirlpool because they were both faulty and my fridge was still under warranty and the repair person I had out was a whirlpool warranty certifed rep. I guess I was lucky but whirlpool did tell me that they were having issues with both parts burning out. But now that they are changed it has been been working like a charm. The repair man did suggest that if you are not useing your ice maker alot then you should turn it to the off posistion and let the ice run low or dump the ice holder on a weekly basis. Hope this helps. alsop to replace both parts if you have to pay runs about $300.00
Posted on Oct 06, 2008
No water no ice
Change the=> 67006531 Water Inlet Valve I believe the side of your 67006531 Water Inlet Valve that controls water flow to the ice maker has weakened and cannot open properly. Replace the water valves and I believe the ice maker will work fine, Sea Breeze
Jun 07, 2012 | Whirlpool GX5FHTXVA Bottom Freezer French...
Do i need to change the filter in order to get the ice maker to work? the water still come out but not into the ice maker. please help!
no you donot need to change the filter first. all of the water goes through the filter first. you either have a bad water valve for the ice maker. a bad ice maker. or bad optics that sense the ice bin on the door is full. can you move the ejector blades on the ice maker? that will tell you if the ice maker gear is broken.
Apr 25, 2010 | Whirlpool GS6NBEXR Side by Side...
Ice maker doesn't make ice anymore. The water works and dispenser levers on the door work for both ice (use store bought ice dumped into tray) and water. I replaced the filter after it quit making ice. Not...
you've already done the first thing i suggest, and that is to change the water filter. But if you still cant get ice made, you have a problem with either your ice maker or your water valve, or an electrical issue in the ice maker system.
Apr 02, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
Whirlpool ED25RF Does ice maker have a filter? My ice taste funny and sometimes its dirty
The ice maker doesn't have a filter , the problem could be the ice maker itself that the tray ,which is made out of aluminum is losing particles.Look at the conditions of the ice maker tray ,if you see like white spots replace the ice maker.
Aug 30, 2009 | Whirlpool Refrigerators
Freezer does not make ice
You need to check and see if ice maker has any water init. if not check the fill tube that goes thru the back wall for stoppage while you have it out rin the maker thru a harvest mode and listen for the sounds of the solonoid opening. If tube is full you'll need to replace the slow leaking valve a common problem. for parts call 704-819-6557
Mar 14, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Whirlpool Side by side Ice maker
check water valve for ice maker how old is the ice maker is more than 3 years then it might need replacement as well
Nov 03, 2008 | Refrigerators
The ice maker in my whirlpool gold refrigerator Model No, GR2FHTXTBOO, is not working.
Hello jitkagardner,
Welcome
You said, The ice maker in my whirlpool gold refrigerator Model No, GR2FHTXTBOO, is not working.
How old is the fridge?
When have you last changed the water filter.
Should be down below at the front grille!
Try these tasks!
If the ice maker is not producing ice or not enough ice
Refrigerator connected to a water supply and the supply
shutoff valve turned on? Connect refrigerator to water
supply and turn water shutoff valve fully open.
• Kink in the water source line? A kink in the line can reduce
water flow. Straighten the water source line.
• Ice maker turned on? Make sure wire shutoff arm or switch
(depending on model) is in the ON position.
• New installation? Wait 24 hours after ice maker installation
for ice production to begin. Wait 72 hours for full ice
production.
• Freezer door closed completely? Firmly close the freezer
compartment door. If the freezer compartment door will not
close all the way, see "The doors will not close completely."
• Large amount of ice recently removed? Allow 24 hours for
ice maker to produce more ice.
• Ice cube jammed in the ice maker ejector arm?
Remove ice from the ejector arm with a plastic utensil.
• Water filter installed on the refrigerator? Remove filter and
operate ice maker. If ice volume improves, then the filter may
be clogged or incorrectly installed. Replace filter or reinstall it
correctly.
• Reverse osmosis water filtration system connected to
your cold water supply? This can decrease water pressure.
Let me know how it goes!
Huuum
Please remember to leave a rating!
Oct 21, 2008 | Refrigerators
Apr 30, 2008 | Whirlpool ED2FHEXN Side by Side...
Whirlpool GS5SHAXN Side by Side Refrigerator Logo
103 people viewed this question
Top Whirlpool Refrigerators Experts
Bruce Denton
Steve Allison
Steve Allison
Norman Worley
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
