Question about SanDisk Sansa Clip MP3 Player
MY computer cant detect sansa clip n i cant hear any songs...Plz help me as soon as possible
  • ashiq_khs Nov 27, 2008
    i dont satisfied
Make sure it's plugged up to both the computer and mp3 player first, then if nothing automatically pops up, click on computer and there should be a picture of your mp3 player, which is it, if nothing is showing you may have a faulty plug. =] let me know.
Posted on Nov 27, 2008
I hv sansa clip 1gb - in which i have some songs i.e aprox.850mb and that cannot be seen in my pc in sansa clip as a drive g.how to delete songs and add songs , is there any driver of software or...
1. First, check your device setting up on MTP or MSC? Turn on device, go to "settings" , press down or up to find "USB Mode", you can see the check mark at MTP (auto detect) or MSC mode. Change to another usb mode.
2. You have 2 ways to delete songs:
2.1. Delete songs by device: play songs, press down (sub menu) until you meet "delete song", select it and yes
If you delete all items in device: Settings, Format, and yes
2.2. Delete songs by computer: plug device to computer, double click on device icon, Music folder, and delete songs you want. If you don't see songs in there, unplug the device from pc, and then change USB mode, and plug device to pc to delete.
Good luck
Feb 01, 2010 | SanDisk Sansa Clip MP3 Player
How do I get the downloaded music from my computer into the clip?
You have 2 ways to transfer your songs from your computer to your sansa clip:
1. Plug sansa clip to computer, double click on "Sansa Clip ...GB", double click on "Internal Memory", you will see the file "Music", copy your songs and paste them into Music file of the device.
2. Using Windows Media Player: open windows media player, plug sansa clip into computer, click on Sync tab, select songs that you want to sync, drag and drop song selected into "Sync list" on the right side of the windows media player (you should update wmp11), then click on button Start Sync.
Good luck
Jan 24, 2010 | SanDisk Sansa Clip MP3 Player
Old songs dont show
If you mean that the songs don't show up on the computer screen, then you probably need to change the USB MODE setting on the Clip. To do this, disconnect the Clip from the computer, then scroll to SETTINGS. Select Settings, then scroll to USB Mode and select it.. (If your Clip is very old it might not have a USB Mode listed under SETTINGS. If this is the case you should update your Clip's Firmware from the sansa website). Older computers recognize the MSC Mode while newer ones should recognize either mode. (except XP Professional doesn't seem to recognize the MTP mode). Songs entered in one mode won't show up on the computer if you're in the other mode. If you mean that the songs aren't showing up on the Clip's own screen then this solution probably won't help. By the way, I've never had any luck with the "auto detect" mode.
Jun 03, 2009 | SanDisk Sansa Clip MP3 Player
Sandisk Sansa Clip 2GB not detected by XP SP2
Change the USB Mode to auto-detect and see if you get better results. If that fails, switch entirely to MTP mode.
-Tha Mp3 Doctor
Feb 20, 2009 | SanDisk Sansa Clip MP3 Player
SanDisk Sansa Clip 4GB MP3 Player
go to control panel and click on portable media devices note:will not work on windows xp even if you downgrade to classic using a disk
Feb 07, 2009 | SanDisk Sansa Clip MP3 Player
Mp3 files dont show up in sansa fuze music folder, but exist.on the player. when i run the player, it works fine all the music is there and no problems when i connect it to my computer to add/remove files...
With my Sansa Clip I just have to make sure it is set to MSC, then I can always see the files in the Clip from my computer. I transfer a lot of mp3 files to the Sansa Clip from a SmartCard with a Memorex TravelSync connected to both the Clip and a SmartCard reader. Initially, I couldn't figure out how I could play them on the Clip but not see them when connected to a computer. But when I set the USB Mode to MSC, I could see all the files.
Jan 27, 2009 | GPX MW-3847 MP3 Player
Cant put songs on sansa clip mp3 player
Use Windows Media Player to transfer songs to the device.
Dec 29, 2008 | SanDisk Sansa Clip MP3 Player
Cant transfer songs from the computer to the player
Chiquititas and oswaldjude sound like they have a similar problem. Try disconnecting the Clip, turning it off, setting the slider switch on the left to "Hold", and then reconnecting to USB while holding the center button down. Continue to hold the button for about 5 - 7 more seconds before releasing.
For 31188, what version of Windows are you running? Depending on what version of WMP you have, there are different ways to see the songs on your Clip in the interface.
Jun 24, 2008 | SanDisk Sansa Clip MP3 Player
WONT DELETE!!!!
first you have to turn your sansa on and go to the setting and then you have to go to usb mode and ptu it on "mtp"
then plug it back up to your computer and this time when you plug it up the computer will start detecting it and when add song use your windows media player
Mar 05, 2008 | SanDisk Sansa e250 MP3 Player
Sansa clip; Does not appear on icons
unplug Sansa MP3 player from your PC, go to menu ->settings, scroll down to USB-Mode, change mode from MTP to MSC, re-connect, yout PC will connect, detect new usb devive, disk drive.... and your sansa icon will be displayed at computer folder.
Good Luck
Dec 25, 2007 | SanDisk Sansa Clip MP3 Player
SanDisk Sansa Clip MP3 Player Logo
50 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
