Question about Kenmore 22422 Top Load Washer
Washing machine fills with water & that's all it does
It was having a problem holding water(as quick as the water was going in, it was draining out just as quickly) & i would just stop the cycle, turn the knob forward a little bit & then restart it. that seems to work alright a couple of times, but now all it will do is fill with water. it won't agitate, rinse, drain, or spin. any suggestions? PLEASE help . thank you !!!
    Scholar:
  • 131 Answers
Sounds like the timer has bit the dust,time to replace it.this is fairly simple to do.if you decide to do this yourself,make sure the unit is unplugged,& swap the wires to the new timer one at a time(noting their location)if your not comfortable with this,then call a service tech.hope this helps.thanx for using fix-ya!!!
Posted on Nov 29, 2008
I have SE showing on my Samsung washer/dryer please respond with any suggestions
Samsung washing machine no workeing ? dL
The door was unlocked while the washer was running
dS
The door was opened while the washer was running
d5
FL
The washer failed to lock the door
Hr
Washer temperature control problem
Heater Relay Failure (on main PCB)
LO
The door will not unlock
5E
Washing machine has failed to drain the water
4E
Water fill time out
ND
Water Does Not Drain From Washer
NF
Water fill time out = No Fill
dE
Washing machine door detected as being open
UE
Washing machine has detected an imbalanced load
DC
Washing machine has imbalanced load and will not spin
3E
Motor fault detected
bE
Motor short error
OE
Washing machine has detected an overfill situation
LE
Water leak - Excessive SUDS - Bad water level switch
HE
Water heating error detected
tE
Water heating sensor (thermistor) error detected
IE
Water level sensor fault
CE
Abnormal water temperature detected
E1
Not filling in allocated time
E2
Pump won't empty - not draining
E3
Overflow - overfilling with water
E4
Out Of Balance (OOB) detected
E5
Water temp rising or falling too quickly
E6
E7
Pressure switch
E8
Temp too high on low temp washes
E9
Water leak, Water level has reduced
EA
Motor generator error
EB
Motor error
Sep 30, 2016 | Samsung Washing Machines
Is it possible to slow down or reduce the rate at which water drains out of the washing machine? My drain line is restricted and if the load is more than "Small", it drains too quickly and starts...
There is no flow adjustment on the drain on any washing machine, I had a similar problem on my old washing machine, I discovered the problem was the waste water pipe in my house was clogged with scum from detergent residue, I poured liquid plumber where the washing machine drain hose goes into the waste pipe in the house waited for 1/2 hour, then filled the washing machine with hot water, reinserted the drain hose, and wrapped it up with duct tape to prevent further leaks, and the force of hot water uncloged the pipe, .Problem solved
Nov 08, 2010 | GE WHRE5260E Top Load Washer
Kenmore dishwasher water will not stay in there
It sounds like you have a drain hose problem. The drain hose needs to have a rise in it. If it is going down hill or to a drain that is lower than the tub it can drain as fast as it fills.
Apr 24, 2010 | Kenmore Dishwashers
I have a Maytag Neptune TL. The machine is working normally except it's not able to fully extract the water out of the clothes. When the full cycle is complete the clothes are still dripping wet. I have a...
We are talking about FAV6800A or FAV9800A TL correct?
If so you need these links the Service Manual and parts look up; here is the Service Manual for reference. Sears Parts Direct for reference.
If your machine completes the wash cycle with no error code such as ND (No Drain) and there is no visible water in the bottom of the wash basket when you remove your wash load then I would do this test.
Take the next wet wash load that is dripping wet and lets do a Quick Spin Test in Service Mode. During this test test the FAV6800A LED display model will step thru the RPM (revolutions per minute) or goal is to ensure the machine will spin the wash basket up through all Spin Cycle RPM ranges. Any RPM range above 99RPM’s will be shown with a (.) dot after the two numbers displayed i.e. 350RPM will show as 35. 550RPM will shoe 55. And so on.
I’m and owner of the FAV6800A and I’m not sure what the LCD display of the FAV9800A will display.
Enter into Service Mode;
Page 14 of the Service Manual; below I have cut and paste the instructions.
Enter / Exit Service Mode
To enter Service Mode press the Enviro Plus and Spin Only keys (simultaneously) for three seconds or until the control beeps.
Now go to page 14 and enter this front panel key pad press to start a Quick Spin Test and see if the machine with that wet clothes load will spin the wash basket to 850RPM.
Quick Spin Test
While in Service Mode, press the Hand Wash
key to start a Quick Spin Test.
Quick Spin test steps are as follows:
1) Lock the lid.
2) Spin to index speed 90 rpm and hold for 60
seconds. Pump drains machine.
3) Spin to index speed 150 rpm and hold for 6
seconds.
4) Spin to index speed 350 rpm and hold for 6 seconds.
5) Spin to index speed 550 rpm and hold for 6 seconds.
6) Spin to index speed 700 rpm and hold for 6 seconds.
7) Spin to index speed 850 rpm and hold for 6 seconds.
Pump out.
8) Coast down to 0 rpm chimes 3 times.
Hit the Off button to get out of service mode.
If the machine spins the wash basket to 850 RPM then we need to start looking further. What are your results?
You can check the flow rate of the drain system by again entering Service Mode and turn the Drain Pump on in service mode. I would (hand fill) place 5 gallons of water in the machine and turn on the drain pump see page 16 for Board Output Test.
Enter Service Mode and press the Delicates key. You are now in Board Output Test now press the Presoak key and the Drain Pump will turn on. If your machine pumps out the 5 gallons of water in 60 seconds or less I would say your Sump Cap, drain line connection from Sump Cap to input to the Drain Pump, Drain Pump and discharge line are all working as designed. If the Machine takes greater then 60 seconds to dump the water then you need to start troubleshooting for a drain line restriction or Drain Pump issue…...Rich
Apr 05, 2010 | Maytag Neptune FAV6800AW Top Load Washer
Washing machine wont hold water on any setting
raise the main drain hose to the top of the back control head. there may be a problem with the main hose being to low and the water is gravity siphoning out of the washer.make sure the washer is off when you lift the hose up but do not remove it from the wall,you should here water drain out once it has stopped draining restart you machine and it should fill to the proper level and quit then go into your wash cycle
Jan 31, 2010 | Whirlpool Inglis IP4400 Washer
Washing machine does NOT stop filling w/ water!
If the m/c keeps filling, where is the water going ??? if the m/c doesnt reach the required water level it will not start, check the drain hose at the back, make sure its at least 24" above floor level, if it lower then it will just empty as quick as you fill it on gravity.
Nov 19, 2009 | GE Washing Machines
Washer won't drain.
My washer fills up with water and goes thru the wash cycle but when it's time to drain, it just sits there and clicks.
Oct 17, 2009 | Tecnik TKL9260 Front Load Washer
NOT FILLING PROPERLY
have you got the drain pipe going up to about worktop level of machine?
if the drain just goes downwards then the water just runs out as fast as it comes in. get a sililiar situation if you put drain pipe too far down a standpipe - then a syspon forms and water drains out
Jun 28, 2008 | Hotpoint First Edition FEW12 Front Load...
Washer will not fill with water
Is your drain hose lower than the top of the cabinet?? The curved part of the drain hose needs to be slightly higher than the top of the cabinet. Also, the drain hose must have an air gap around it where it goes into the house drain. It sounds to me like your washer is syphoning water out through the drain hose as it is trying to fill. Hope this helps..............
Dec 30, 2007 | Whirlpool Ultimate Care II LSQ9549L Top...
Kenmore 22422 Top Load Washer Logo
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
