Question about Xerox 5665 Copier
I have a xerox 5675 copier printing blanks. Ros/lvps/hvps/image pcb replaced still blanks. dev tank turns no image on drum. Cru already replaced/\. Iot checked/Web moor checked
    New Friend:
I need a laser ROS for Xerox 5675,
Posted on Jun 07, 2013
Posted on Nov 26, 2008
How to remove xerox 7545 high voltage power supply
  1. Press the Job Status button to check that there are no jobs in progress.
  2. Switch off the power and disconnect the power cord.
  3. Remove the following parts:
  4. Remove the Tie Bar. ( Figure 1)
    1. Remove the screws (x4).
    2. Remove the Tie Bar.
    Figure 1. Remove the Tie Bar
  5. Disconnect the connectors (x2). ( Figure 2)
    1. Remove the cable band.
    2. Disconnect the connectors (x2).
    Figure 2. Disconnect the connectors
  6. Remove the Bottle Guide Assembly. ( Figure 3)
    2. Remove the Bottle Guide Assembly.
    Figure 3. Removing the Bottle Guide Assembly
  7. [7525/30/35]: Remove the HVPS (Dev/BCR). ( Figure 4)
    1. Disconnect the connector.
    2. Remove the screws (x2).
    3. Hold onto the tabs (x2) of the Bracket and pull out the HVPS (Dev/BCR) in the direction of the arrow.
    Figure 4. Remove the HVPS (Dev/BCR)
  8. [7545/56]: Remove the HVPS (BCR). ( Figure 5)
    3. Pull out and remove the HVPS (BCR).
    Figure 5. Remove the HVPS (BCR)
Sep 08, 2014 | Xerox Office Equipment & Supplies
Print is blurry
Remove the toner cartridge and print cartridge assembly. Slightly shake it from side to side to redistribute toner properly. Also, please check the supply level of your toner cartridge.
You might want to consider replacing the toner cartridge since you have already replace the PC unit.
Also, check the transfer roll for signs of toner buildup and contamination.
Inspect the HVPS contact (transfer roll) for contamination. Verify the high voltage cable is plugged into the LVPS/HVPS.
If all the steps mentioned above were done. I would suggest you contact Lexmark Technical Support for further assistance.
Apr 04, 2012 | Lexmark E360d Laser Printer
My printer doesnt work it doenst switch on at all
If printer doesn't work and it doesn't switch on, I assumed that there is no power at all on the printer. Check the AC line voltage if it is correct.
Unplug the printer. Remove the LVPS/HVPS, and check the fuses for continuity.
• If open, then replace the LVPS/HVPS.
• If not open, then check the switch continuity across its conductors with the switch on.
Turn the switch off. Plug the AC line into the LVPS/HVPS, and switch unit on.
Please try reseat power cable. If this does not resolve the issue, you may need to replace the LVPS (Low voltage power supply) on your printer.
For further assistance, please contact Lexmark Technical Support
Feb 07, 2011 | Lexmark E260 Laser Printer
Faxcentre f116 outgoing faxes are black i have replaced the scanner assy and the uc board 2 times and calibrated them each after the part was replaced
On this machine for black copies, the areas to check are the HVPS, The ROS, or the Print engin Board.
Most likely on this machine the HVPS can be the problem, then the ROS, then the printe engine board.
The definitions are the scanner platen is under the document feeder, the ROS is the actual laser scanner.
Taking this machine apart several times, one can also check the ground straps to the copy cartridge to make sure they are connecting to copy cartridge when it is inserted into the machine.
May 12, 2010 | Xerox FaxCentre F116 Plain Paper Laser
HP 4550 Color Laser jet reports no "errors" yet does not print
HP 4550 Color Laserjet Printer - Blank or white pages :
01. Your software application is sending an extra page-eject command.
02. Check the software’s printing configuration information. There is a problem with the network configuration.
03. Some sharing devices on networks may generate a blank page as a separator.
04. Check with the network administrator.
05. The printer may be feeding two or more pages at once because the paper is difficult to separate.
06. The sealing tape has been left in the toner cartridge.
07. The toner cartridge is empty or defective.
08. The laser scanner door does not open properly.
09. Remove and reseat the toner cartridge.
10. Check the laser scanner shutter door for proper operation.
11. The toner cartridge guide is damaged,
improperly positioned, or missing.
12. There is no transfer roller voltage.
13. Perform the Half Self-Test Functional Check to check all other electrophotographic processes.
14. Replace the transfer roller if necessary.
15. The high-voltage connectors are mounted on the high-voltage power supply (HVPS) PCA and protrude into the toner cartridge cavity.
16. Check the springs for functionality. Clean if dirty; replace if defective or missing.
The HVPS PCA is defective.
17.The DC controller PCA is defecti  There is no drum ground path.
18 Check the drum ground.
19. The laser scanner cable assembly is defective
20 The page length and margins are not set correctly for the paper size. Verify that the ribbon connector at J1307 of the HVPS is
properly seated.
21. If the HVPS has been removed recently, verify that the ribbon connector from the DC controller PCA to the HVPS is properly
seated at both ends..
22. Verify that the photoconductive drum is rotating properly. Perform is the drum diagnostic test to visually observe if the drum is rotating.
23. OR using a felt-tipped marker place an index mark on the edge of the drum outside the image area. Turn on the printer (wait for
drum rotation to occur), and then look to see if the drum has
24. moved. If the drum has not moved, investigate the mechanical
and electrical drum rotation circuitry and movement mechanisms.
25. The imaging drum shutter may not be retracting. Replace the imaging drum.
26. Lst but not the least, please fry to have the Printer int the Setcie
27. Use only HP Authorized Genuine catridges only
Jul 21, 2009 | HP Color LaserJet 4550 Printer
Hp clj 4550n printing blank pages
Replace the transfer belt. Known issue with this machine.
Hope this helps
May 12, 2009 | HP Color LaserJet 4550n Printer
Docucolor 12 printing nothing from glass
The only fuses it could be are the 24v fuses going to the ROS. In general it would "normally" be the ROS and Halftone pwb or the Vsel pwb. Both of these might not be sitting right/loose ribbon cables etc, depending if you have been working in that area.
The other option is a defective cleaner clutch for the IBT. This "normally" leaves with just the black left on the print however. You will have to watch the machine and see if there is actually an image being produced on the drum. If not, the ROS (ROS and halftone pwb must always be replaced together)
Jan 19, 2009 | Xerox DocuColor 12 Color Copier
I have a Lexmark E232 printer. It has worked great up until a few days ago. Print quality became poor. I purchased a new toner cartridge Did not help. I purchased a new drum unit. Just installed,...
Blank pages can be caused by a defective printhead assembly, LVPS/HVPS, or controller card.
Blank pages are typically caused by the PC ( photo conductor ) roller not being charged properly.
The first step would be to try a new toner AND photo conductor kit., but since you stated that you have already tried that we can rule that out.
The next most logical unit to replace would be the LVPS/HVPS.( both power supplies are combined in one replaceable unit). The reason I say this is similar to a car with a bad battery. If you try to start it, it may not have enough juice to turn it over, but it tries, and then gets slower and slower. If you wait a few minutes, it still does not start the car, but again it has more charge and then slowly dies. I think your power supply is defective, although not DEAD, and tries to do its job by charging the photo conductor unit, but just unable to complete the task.
Although a possible cause, the printhead would be the last and least likely to cause the problem. USUALLY if the printhead goes bad it results in a service code being generated.
The part number for the card assembly, LVPS/HVPS 110 V, is 56P1818
The part number for the card assembly, LVPS/HVPS 220 V, is 56P1819
The part number for the print assembly, laser/mirror E232, is 56P1812
and the part number for the controller card, is 56P3087
I do not sell parts, and just give you these part numbers for your reference. you can probably search google,ebay, and/or craigslist to get an idea of prices. Then you can at least make an informed decision on what to do as far as "fix it or just chuck it"
I wish you the best... good luck!
Oct 03, 2008 | Lexmark Office Equipment & Supplies
Xerox DC 12 Error : 9-667
Hy there
Try to replace the print drum unit.
this is the information of the error code
9-667 VH/VM Out Of Range RAP
The selected LD value was out of range.
Initial Actions
·Refer to BSD 9.1 and BSD 9.15 for the following procedure.
·Clean the ESV Sensor.
· Check that the P/J141 on the ESV Sensor, and PJ 422A on the IOT Drive PWB are firmly connected.
Perform the following in the order listed.
·Go to the IQ 38 Charge Corotron HVPS RAP and check the Charge Corotron HVPS for proper operation.
·Ensure that the Charge Corotron Wire and Grid are in good condition.
·Go to FLAG 6 and FLAG 7 on BSD 9.1. Check the wires for an open circuit or a short circuit. If the wires are good, replace the ESV Sensor ( PL 5.1 ). If the problem continues, replace the IOT Drive PWB ( PL 9.2 ).
·Replace the Drum CRU ( Machine Consumables).
Mar 08, 2008 | Xerox DocuColor 12 Printer
Xerox xc1020
is it a printer/copier? both prints and copies off the glass come out black?
yes...probably a problem in the drum/ CRU area
No- prints OK but copies black lift the lid and watch the exposure lamp...does it light up? does it move? Both of these scenarios would usually bring up a fault code, so I would still be inclined towards the drum unit.Pull the unit out and make sure no paper has sneaked up between the drum and the exposure slot, or even into the drum unit. another cause could be a broken corotron wire (very thin wire close to the drum usually behind a grid (charge grid) If it is a customer replacement drum unit (CRU) the charge grid will be built into the unit and will require the whole thing replacing.......
Dec 27, 2007 | Xerox CopyCentre C20 Black and White...
346 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
