I use canon ip1880,i use to refill those ink by myself,sometimes the resume button blink and message comes up said my color catridge couldn't recognize,i cleen those pins and it's long after that,both my cartridge not work,even that i've cleaned it for many times. i try to use tools called iptool,this software can be used after i set my printer to service mode,and can print some sample pattern,but other program can't do it.Can You help me with some suggestions?
  • 385 Answers
The best is to buy new cart untill it gives problems again!refilling is not good for the head of the printer and thats why its not picking the cart up!but buy new ones and refill them again till it doesn't work and so on!
Posted on Nov 26, 2008
I refilled the catridge and inserted its showings a message check color ink
Press and hold the Stop/Reset button until the message disappears. You will have to do this every time you insert a "new" refilled cartridge.
Sep 15, 2012 | Canon Pixma Mx340 All-in-one Inkjet...
I have canon ip1880 when i give a print command it shows the message on my monitor ink cartridge cannot recognised - color
Solution: press and hold (10 second) reset button/resume (Button reset/resume, under the power button)
Sep 23, 2011 | Canon Office Equipment & Supplies
Would not print, oraqnge light blinks 5 times then one green flash. Open the door to ink and the head does not move to center as it used to.
This is a waste ink code and needs to be reset. follow instructions below.
Canon pixma iP90 released almost at the same time with canon Pixma iP 1880. Canon iP90 is printer with single function. Cartidges which used in canon Pixma iP90 is BCI-15BK, BCI-115C dan BCI-16C. Resetting procedure canon iP90 almost the same as manual reset canon iP1880. You can use combination of button in the printer to reset the printer.
Following step by step resetting canon Pixma iP90 :
  • Before resetting printer canon iP90, start with printer power off .
  • Press resume button coincide with power button.
  • While pressing power button, release resume button.
  • Press resume button 2 times and then release both button
  • Green LED indocator will blinking and then stopped blinking.
  • When the Power LED lights in green, press resume button 4 times.
  • Press power button and the printer power will off. otherwise off, depress again power button.
  • And the turn on the printer again, your printer canon iP90 should be response as normal.
Please rate my help++++Thanks for using FIXYA
google_protectAndRun("ads_core.google_render_ad", google_handleError, google_render_ad); google_protectAndRun("ads_core.google_render_ad", google_handleError, google_render_ad);
Nov 24, 2009 | Canon PIXMA iP90 Mobile Printer
Canon mp460 printer. refilled cartridge not recognised
Dear Sir,
This is deffinately due to catridge circuit problem.Canon suggest that we have to replace emptied catridges with new genuine canon catridge they dont suggest refilling and also not give any support for refilling catridges. So you can replace catridge with new one.
This Happens due to weakining of catridge circuit portion or may long period printer not in use.
If you not want to replace catridges i will give you the possible hints it may fix refilled catridges.
1.Clean the catridge circuit portion with soft cloth,care must be taken that there is no smudge or ink traces on catridge circuit.
2.Clean the ciruit of printer catridge placing box present inside the printer .wipe out the any sumdge or ink traces.
Then re install the catridges. give the print if it shows error press resume button continuosly. I think it will fix your problem.
If it is not solution is replace the catridge with new one.
good luck
Aug 26, 2009 | Office Equipment & Supplies
Catridge problem
when printing try to press resume button for about 5 seconds
Apr 06, 2009 | Canon PIXMA iP1800 InkJet Photo Printer
Problem on my Canon ip1880
Unplug the printer from power for a few minutes. If this doesn't reset it, then try the following:
PLUG the printer into power.
1. Press Resume button ( hold for 1 – 2 minutes )
2. Open the cover
3. Release the catridge and then put them in again
4. Close The Cover…
5. Turn Off, then Turn On
Jan 21, 2009 | Canon Office Equipment & Supplies
The ink absorber is full for pixma 1880
This is the REAL working method of manually resetting Canon ip1880 - ip 1980.
1. Unplug the POWER cord.
2. Press & hold the power button.
3. Connect the power cord WHILE holding the power button.
4. Keep on holding the power button for about 30 seconds.
5. Release the power button. The printer should be turned off.
6. Turn the printer on and that's it!
NOTE: You have to do this every time you turn on your printer. Or you will get the waste pad full error.
Hope this helps.
Jan 15, 2008 | Office Equipment & Supplies
Reset Ink levels for canon mx310
I've heard that with canon there is a way around the ink-level chip monitoring on the cartridge by doing the following:
  1. Power off printer
  2. Hold RESUME button then press and hold POWER, the beeper will sound once.
  3. Hold POWER and release RESUME
  4. Press RESUME twice
  5. Release POWER button
  6. When the indicator lights steady, press RESUME three(3) times. The indicator should be orange.
  7. Press POWER to set data
Jan 03, 2008 | Canon MultiPASS MP730 All-In-One InkJet...
Canon PIxma i4200 - INK
see may be there is problem with the catridge bcoz it is not sensing the ink level it is bettre if you have other catridge first you check wit that or you try to remove the ink and claen the cartridge and refill it again. bye
Oct 01, 2007 | Canon PIXMA iP4200 InkJet Photo Printer
197 people viewed this question
