Question about Dell Precision M60 Notebook
Dell M60 When ever i puch the power button only cap lite blink and no display shown any reason wht this happened , while the reson behind thta i am working on my laptop and blue screen appear and then display gone? any solution Shahzadf
  • Anonymous Jan 16, 2009
    I have problem with ethernet.
  • 4 Answers
At the left of your power button, past the word PRECISION, there is a slot for a screwdriver. With the screen fully open, use that slot to remove the power and volume buttons. At the other end of the stip you removed will be the connector that connects the buttons to the motherboard. Reconnect it better.
Posted on Jul 08, 2009
HiI have a dell desktop and won't start. for a second the fan spin than the power button turn yellow. help
hi,
Does your desktop is making any beap sounds? Are you able to see the dell logo on the startup on the screen? Please do let me know these things.
Mar 08, 2012 | Dell OptiPlex GX280 PC Desktop
Precision m60 power not staying on
hi first check addopter if power work fine then check ram if ok check proccessor if ok press main chip on board then check shortage may bee any fet or capceters shorts
Jul 18, 2010 | Dell Precision M60 Notebook
After my Dell preciso M60 was powered up, the screen display broke into small segments and flashing, and computer got frozen. Any idea?
check the HDD. use another HDD then install new OS... because sometime the problem comes from the HDD
Jun 24, 2010 | Dell Precision M60 Notebook
Dell precision m60 press the power button the screen blinks for a second the lights next to the power button stay lite for about 3-4 seconds then the entire laptop turns off. ANy ideas guys?
You could have a bad peice of memory or a bad memory slot. Pull the memory out and try one peice at a time in each of the two slots. If you only have 1 peice you will need to either borrow a peice of the same memory or buy it. You also could have a shorted battery so pull the battery out if the ram is ok and try to boot. Another idea is the cd rom may have a problem so pull it if the ram and battery are ok. After doing all this if the system will still not boot the motherboard must have a short and needs replacement. This model also had an issue with the power board where the power button is. The connector on the motherboard was poorly designed and very sloppy. Over time it gets worn and causes a similar issue. The temporary cure is to press very hard on the power button to see if it will boot and then leave it running. You can also put pressure on the underneath side around the docking port and press the power button. This issue however requires a new motherboard. The M60 is almost the same as the D800 infact most parts are interchangeable. You could switch out the motherboard to a D800. I refurbish the D600 AND D800'S daily so I am fimilar to this issue. Let me know how you make out. Phil pmgibs1@verizon.net
Feb 23, 2010 | Dell Precision M60 Notebook
Dell M60 screen is dead, works fine when connected to a external display and screen itself makes a picture (when lighting the screen with a flashlight), the lamp is just off. Any way to replace the lamp?
here are the possible problems and solutions
Issue 1: Lid button sticking
this is a common issue with this model that the lid button sticks closed. fiddle with it to see if it opens and the light comes on.
issue 2: Inverter for the monitor is bad
this is not to uncommon an issue when this problems shows itself. Laptops monitors light up with a fluorescent bulb. This is powered by an inverter. These can go bad and if they do the light will not turn on. you need to take this to a service station. i don't recommend trying to replace without knowledge of this. They are high powered and you can hurt yourself or damage the screen
issue 3: fluorescent bulb went bad
this is usually the least common but could have happened. usually happens when peopel spray their screen with cleaner and it drips down inside the bottom. This can be fixed by a service center but coudl get costly. best bet is buy a new screen.
Feb 11, 2010 | Dell Precision M60 Notebook
My precision m60 wont turn on
remove the LCD hinge cover, see if you can turn it on pressing the power button directly. Also the suspend switch in the hinge cover could be sticking.
Sep 20, 2009 | Dell Precision M60 Notebook
Dell Precision M60 won't start up
Without battery connected it wont work. Better buy a new batterry connect it and plug it for charging for 8Hrs conitnuosly without switching on the laptop.
Apr 20, 2009 | Dell Precision M60 Notebook
Dell M60 volume buttons
At the left of your power button, past the word PRECISION, there is a slot for a screwdriver. With the screen fully open, use that slot to remove the power and volume buttons. At the other end of the stip you removed will be the connector that connects the buttons to the motherboard. Reconnect it better. I had this problem too.
Nov 07, 2008 | Dell Precision M60 Notebook
Dell Precision M60 won't boot up
This is a memory problem, most likely. Try swapping the SIMs or putting them in one a time.
If you only have the one SIM, see if you can borrow someone elses
Feb 21, 2008 | Dell Precision M60 Notebook
Problem with my dell dimension 4600
Does the hdd lite come on? cd lite come on? The blinking lite on the power is an indication the bios or power supply is having trouble. strip the unit of all devices except hd, kb and use the vga built in video. Remove the ram also. restart and see what happens.
Dec 08, 2007 | Dell Dimension 4600 PC Desktop
Dell Precision M60 Notebook Logo
271 people viewed this question
Alun Cox
