Computer won't boot up
When i power on the hard drive it starts to boot but then my monitor just goes to a blue screen saying "inaccessible_boot_device" with about four different paragraphs of other things its telling me. Nothing i do will take me away from this screen. PLEASE HELP!! THANK YOU!!!
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 162 Answers
Hi, Reboot and get into BIOS. Make sure that the hard drive is set to boot first. (Enter the BIOS by pressing either F2 or F8 when u switch on your PC). Let me know how you get on.
Mixtrixx
Posted on Nov 26, 2008
When I power up computer it just goes to a blue screen what do I do
Remove all memory and try again. Remoive cpu and reinstall, try again. If that doesnt help, remove hdd and boot, it should boot ti blsck screen saying no o/s. If it does, make boot disk or usb drive of a small linux distribution called puppy linux, its only 168mb so its fast to download and burn to cd, or use unetbootin to make a bootable usb drive of same puppy image. Boot to cd or usb by accessing BIOS and changing boot order to usb or cd. Puppy seems to be very compatible with most hardware and you may like it better than windows for web snd email. Very simple and fast. You can wipe hard drive and reinstall windows from puppy tools if hdd mbr is faulty.
Sep 02, 2015 | Computers & Internet
Pc starts but black screen
Bad video card, bad hard drive, bios battery. If you have a screen but only a blinking cursor on it, likely a bad hard disk drive, meaning all your data and files are now gone, also your os is likely inaccessible. If you can heart it boot up like normal through speakers then video card or monitor, more likely the monitor's power supply is bad, find another monitor (size not important, just the display connector) and connect it to your PC with the power off. If it works then it's the monitor that is bad, purchase a new monitor, if another known working monitor doesn't solve the screen issue, it's probably your video card. A new card is cheap and you should be able to install a new one and have basic display until you install the drivers.
Sep 02, 2013 | Dell Inspiron 2600 1.2GHZ Celeron...
I have a toshiba satelite L655-s5117 laptop and it won't boot up even when i try and boot from windows 7 disk it won't
Probably a faulty hard drive. go into the setup screen and verify the HD setting is correct. save your settings and reboot. if this doesn't solve it, then take out battery and disconnect power, remove hard drive and reconnect. try reboot. if none of that works, then replace hard drive and reinstall OS.
Mar 10, 2013 | Computers & Internet
MY WINDOWS 2000 WONT BOOT UP (BLUE SCREEN SAYS INACCESSIBLE BOOT DEVICE MESSAGE. TRIED SAFE MODE AND LAST KNOW GOOD SYSTEM (NO LUCK) PLEASE HELP. MY BUSINESS INFO IS IN THIS COMPUTER. THANKS KEVIN...
Unfortunately, it sounds like your hard drive is out. Or the boot track has been damaged. You can try a repair using the win 2000 cd. Read the following link :
http://www.techspot.com/vb/topic8356.html
Since it is your business computer, I would advise that you have the hard drive removed from the unit and have your data saved, before attempting any action.
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Dec 02, 2010 | Computers & Internet
Please help! First power on, when boot up, my Dell 5150 goes directly to "Start Windows Normally" screen selection. Sometimes when boot up, screen goes to a blue with "A problem has been detected and...
Main cause of the problem is a corrupted operating system which can be cause by a virus or a defective hard disk or a defective memory module. First to try is to replace your memory with a certified good one. If the problem persists, Try to reinstall you windows using your CDRom. If there still the problem, replace hard disk.
Sep 11, 2010 | Dell Dimension 5150 (DIM515MIN) PC Desktop
Computer does not boot, blue on light lites up but
Now when you say blue power light, what are the rest of the lights doing, does the hard drive light flash, does the fans turn on, does the hard drive make it's spinning noise, if so you may just have a bad LCD inverter which is very common and about a 40$ part. you can test this by trying to hook the laptop up to an external monitor and see what happens.
Sep 24, 2009 | HP 417035-001 - HP Pavilion dv2000 Series...
Mine similar except the blue light stays on ,monitor goes black
Have you tested the monitor? The monitor could be faulty. Try hooking up the computer to another monitor or another computer up to that monitor if possible. If the monitor is testing good then make sure all USB devices are disconnected and try to boot again. Then open the case and blow out any dust. Check the motherboard screws are tight. If the screws holding the motherboard to the case are loose it can cause a grounding issue. Then swap out the power supply with a working one and see if that fixes it. Disconnect hardware one at a time and re-boot. One of the devices...cd-rom,harddrive,ect could be faulty. Make sure the video card is fully seated and test the card in another working computer or test a working card in that computer. If it has on-board video then install a video card if available and see if it works. If none of these things work then the board is bad and needs replacement.
Sep 10, 2009 | SimpleTech SimpleDrive Pininfarina 320GB...
Blue screen during booting
Yes, unmountable boot volume usually means you need a new hard drive. However, if you have a windows xp cd, you can boot to the recovery console (press R at the first prompt) and try running a chkdsk /f command. Sometimes that will help. Thanks and good luck! Oh and if you could remember to give this solution a rating of fixya. Thanks!
Jan 18, 2009 | HP Pavilion ze2000 Notebook
Laptop restarting
Although it could be the hard drive, it could be any number of things as well. First, when the computer starts up, press the F8 key to bring up some options. Select disable automatic restart. This should allow the computer to stop at a blue screen so we can get some information from it. Do this and report back what that information says and we'll go from there. Thanks.
Jun 14, 2008 | Toshiba Satellite P35-S609: Pentium 4-3.2...
X5DAL-G restart
if theres a click, then its either the hard drive or the monitor click when it shuts off, motherboards don't make a sound. When its starting up press F8 to enter safe mode and select last known good configuration and see if it starts as normal, but is sounds as though the boot.ini is damaged on a bad sector of the hard drive and either try a windows repair or replace the hard drive.
Sep 26, 2007 | GE Supermicro X5DAL-G E7505 Mainboard...
Computers & Internet Logo
46 people viewed this question
Alun Cox
David Payne
David Payne
