Question about Clarion DB175MP CD Player
Wiring diagram for cd player
Hi there, i have a cd player only , the combi 8 pin at the back suggests that it goes to a head set unit , but all i have is the cd player , so nif i could get the wiring instuctions for the 8 pins and what the wires are for , i could try and put it to use , i have the following info off the radio
the modle number , PN-211OU serial number , 0055243
it is a calrion , nissan cv704 8/12cm compatible cd player.
could you pls let me know what the wires are for and what colour do what???
hoping you can help.
    Sergeant:
  • 324 Answers
That actually is not for a head set, tha tis for a remote, you plug in the remote that you can buy from an audio store and mount it on the dash....
Posted on Nov 26, 2008
I have a KDC-X469, It's supposed to have an AUX setting. When I scroll through the source button, AUX Doesn't appear. What do I do?
Try scrolling through the menu to see if you may have aux turned off. Some decks have a feature in the menu to turn aux on and off.
May 30, 2012 | Kenwood eXcelon KDC-X469 CD Player
My kenwood head cd unit in my car keeps on flashing "protect" i checked all wires in the head unit and nothing.it will stay ok for a while but it goes back to protect...
hi,
Check the speaker in you car which are connected to you head unit. if the speaker or the wire which runs to the speakers have some problem then the head unit will show protect.
Also one more possibility is, the faulty output amplifier IC in the head unit. if the audio out put IC is short or fail then also the unit will show the same. Audio output Ic means the audio amplifier. Check the speaker and wire first. Mainly the wire check is there is any insulation damage in it. if the insulation get damaged possibility to get contact with the metal part of the body of the car then also the protect will appear.
ok
Apr 04, 2011 | Kenwood CD-324M CD Player
I have a 1998 Pioneer head unit to put in my car. the #is 1256237179. Is There anyway to get a diagram to see how to hook it up?
Well you can please follow the below steps -
1. Disconnect your car battery. It is vitally important to your safety that you never work on any type of electronic in your car with the battery still connected, as this puts you at risk for electrocution.
2. Remove the old stereo by taking off all the dashboard panels surrounding your stereo, sliding out your old stereo head unit, and unplugging all the wires that are connected to the head unit. Discard the old stereo.
3. Take your Pioneer car stereo head unit and plug each of the positive wires from your car speakers to the positive terminals on the head unit. Take all of the negative speaker wires and connect them to the negative terminals on the head unit.
4. Attach the stereo's black ground wire to a metal bolt or screw located near where the stereo is mounted in the dash.
5. Connect all of the ignition power wires to your Pioneer stereo.
6. Take the harness connector and plug it into your car stereo. Now plug the antenna into the back of your head unit.
7. Slide the stereo back into the dash, screw it in place, and replace the dashboard pieces you removed earlier.
8. Reconnect your car battery, turn the car on and test out your new Pioneer car stereo. Please post comments for more help or information..........
Good Luck!!
Thanks
Jan 16, 2010 | Sony CDX-F7710 Car Audio Stereo CD MP3...
CD Only output
Most radios go into a silent protection mode when speaker wires are shorted, so it's worth checking those.
Oct 22, 2008 | Alpine CDM-7874 CD Player
Kenwood 8pin harness
looking at back of 8 pin harnes, with wires facing you and tab facing up, left to right,
top
plugged into head unit i----------- i
______________________| |___________________________
| 1st pin, - blank | 2nd pin - Black wire | 3rd pin blank | 4th pin blank |
| 5th pin - yellow | 6th - pin blank | 7th pin- green| 8th blank |
Sep 27, 2008 | Kenwood Excelon DDX-7015 Car DVD Player
Need a Nak CD-45Z wiring harness, or diagram
Rob, I had the exact same problem, I kept searching on line and came upon Alex in Australia, he deals in Nakamichi products, and has the part (plug/wiring harness). He charges $55 for the part and $30 for express shipping.
Here's his email: aminassian@optusnet.com.au
I have also found a site with the Manual: http://www.nakremotes.com/default.htm
Click on "Model List" and look for your model, in the manual there's the wire color code for the pinout. I also have the pinout by wire color, no room to include, will send in another response.
TOP
[ 1 2 3 4 5 6 7 ] Looking @ pins in socket
[ 8 9 10 11 12 13 14 ] Naka CD45-Z deck
Note: The above diagram is done from the perspective of looking directly on to the connector pins. If you are having trouble figuring out which way is which, just use the ground wire, which is always black, as a reference for making sure you are doing the pins correctly.
Jun 11, 2008 | Nakamichi CD-45Z CD Player
Clarion drx9675z head unit connector
Go to pacparts.com
They are authorize parts dist. for Clarion
Feb 01, 2008 | Clarion DRX-9675Z CD Player
Wireing harness.
Hi diamante,
For your reference, pls see below image.
Further, here is a page of the official Clarion standard wirings and their color codes.
Here is a source of the connector for your reference. You don’t need the speaker connector since your unit does not have any built-in amps.
Additionally, if your vehicle’s wiring connections are not of the ISO-standard type or if you just want to verify, please follow this link for the installation adapters you may need to fit your Clarion DRX-9675Z CD Player to your particular vehicle.
Hope this be of help/idea. Pls post back how things turned out or should you need additional information.
Good luck and kind regards.
Nov 15, 2007 | Clarion DRX-9675Z CD Player
Clarion DB175MP CD Player Logo
480 people viewed this question
Top Clarion Car Audio & Video Experts
xxxxxx xxx
Are you a Clarion Car Audio and Video Expert? Answer questions, earn points and help others
