Question about Emerson ET-14J2 13" TV
Drive transistor Hey guys, can anybody tell me where the drive transistor on a sony trinitron tv is located ? thanks
    Novelist:
    Champion:
  • 275 Answers
Look for a 3 pin component mentioned as Q501. That is the Hor. Drive transistor in Sony Tvs
Posted on Nov 28, 2008
Hi guys, TV Sony Trinitron KV-32LS35U The tv was working normally when suddenly went off and started a Red L.e.d flashing 2 times before steady green for 2 seconds. Please tell me it will not be too
the horizontal output transistor is not recieving any voltage or it is burnt out and since it could have shote some resistors around the fbt transformer
Jan 18, 2013 | Televison & Video
Red light flashes six times
6 blink's means H stop or Horizontal Drive failure. Check the Jungle and its soldering connection terminals for possible bad soldering or loose connection. In some cases jungle ic found defective.also check your horizontal drive transformer windings and connection that is connected at the base of horizontal output transistor. Open winding or loose connection would result to absence of horizontal drive at the base of horizontal output transistor..
Feb 13, 2011 | Sony FD Trinitron WEGA KV-32FS120 32" TV
My sony trinitron 32" tv just went black and the
Hello
Six blinks of standby light in Sony TVs denotes the absence of horizontal oscillation.
No Horizontal (H STOP), no raster, goes to the blinking self-diagnosis function immediately. Check C515 & 516 and the jungle IC, IC206.
In most cases the Ic is foud defective. anyway check its soldering points for any loose contact, or bad solerings. Check the line drive transformer, a very little transformer soldered directly to the main printed circuit board, very close to the horizontal output transistor. Check its primary winidngs for open. If it gets open no horizontal drive signal will be present at the base of the horizontal output transitor, that also may the cause of horizontal stop.
Nov 20, 2010 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Where are the transistors located on a sony trinitron wega television
Hello
There are so many transistors in your TV can be located at several sections. Whithout knowing the exact section we can't answer you. Specify the section at least.
Ok.
Oct 24, 2010 | Sony FD Trinitron WEGA KV-36FS120 36" TV
When i put my tv sony trinitron on, i hear the sound for 15sec en then the tv go out en de leds blanks
Hello
There is some sort of indirect short inside your TV. It is in the main circuit board. Most of this kind of fault in Sony Tvs are related with horizontal output stage. You just replace the horizontal output transitor [which drives the Line Output Transformer] of your TV first. If the transitor is leaky, the above said falult may occur. If it doesn't help Line Output Trnasformer [LOT] may need replacement. Check whether the replaced transistor overheats within seconds or minutes. If it overheats the LOT is faulty. Ok.
Oct 18, 2010 | Sony FD Trinitron WEGA KD-36FS130 36" TV
My 36xbr800 blinks six times then pauses then blinks six times, this is repeated......
Check the voltage input to horizontal output transformer [LOT]. Check the voltage at the collector point of the line drive transistor. If the line drive transformer primary gets open this type of fault mau occur. Also check the frequency ant the collector point of line drive transistor and the base point of line output transistor. It should be aroung 15625 Hz.
Check and replace the horizontal output transistor if needy. Replacing it is better. The horizontal output is not working or a short in secondary power supply of SMPS or lot secondary, is your problem
Oct 14, 2010 | Sony FD Trinitron WEGA KV-36XBR800 36" TV
Power light flashes 3 times
more than likely the sony has a bad flyback
It is available from
www.electronix.com
Thanks Guy
May 19, 2008 | Sony FD Trinitron WEGA KV-27FS100 27" TV
Tv screen not work
No picture, FR406 ok
Check the video output amplifier stage for failure
Display dead rest of functions ok
Change transistor Q1701 on Timer operation board
Nov 24, 2007 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Sony Trinitron 32" was watching and it just powered off and I can't turn it back on.
solder the horizontal drive .and horizontal output transistors and transformers
Nov 19, 2007 | Sony FD Trinitron WEGA KV-32FS120 32" TV
1996 Sony 32" Trinitron - Suddenly lost picture and sound
The most common problem with TV was the failure of the Horizontal Output Transistor, this will also damage 2 transistors in the power supply and a resistor in the power supply also. (From memory): Horizontal Output location # Q501, 2 power supply transistors Locations Q601, Q602, and resistor Location R607. Also solder the Horizontal drive transformer, you can find it by following the circuit board from the base of the Horizontal output. Some models used an IC instead of the 2 transistors in the powersupply, it will have six legs and check like 2 transistors. Good Luck.
Jun 04, 2007 | Sony KV-32S26 32" TV
Televison & Video Logo
104 people viewed this question
Top Emerson Televison & Video Experts
matt martin
matt martin
 Grubhead
Grubhead
Are you an Emerson Televison and Video Expert? Answer questions, earn points and help others
