Question about Sony DAV-S300 System
How do I remove the words "video 1" on the top left of my screen?
  • Lalit Varadpande
    Lalit Varadpande May 11, 2010
    try pressing the OSD/Display button on the TV remote til it goes
  • 10,594 Answers
Press Display / Info button on TV Remote this will disappear on-screen display.
Posted on Nov 26, 2008
Scanning and picture malfunction
give a good whak on back of picture tube
Aug 19, 2014 | Sony BRAVIA KDL-46W5500 FULL HD...
BOSE LIFESTYLE 50 REMOTE CONTROL NOT WORKING
FOR THE BOSE LIFESTYLE 50 SYSTEM (Model P1 - Personal Music Center remote)
You can re-calibrate the remote first by following the steps below:
1. press and hold down on the display screen in the top middle area of the remote
2. After a few seconds the word CAL will appear in the middle and the word SOURCE will appear in the top left area of the remote.
3. Press the SOURCE button.
4. The word KEYPAD will appear in the top right area of the remote
5. Press the KEYPAD button and a small circle will appear in the bottom right of the remote.
6. Press the Circle
This should've recalibrated the remote.
If you need to relink the remote to the system, HOLD down the mute button while having the remote as close as possible to the unit. You will hear a beep . Release the button, after a pause , you will hear the remote beep twice.
This re-links the remote to your system
If the backlight is not working, your options are
1. Spend $349 and get a new one from Bose Or
2.Spend $220 and get a used one on E-bayOR
3. Use your remote with the lights on so that you can see the display :-)...the cheapest way OR Invest in an LED Book light that you can clamp on the remote and use that for your light ($9.99)
Sep 10, 2012 | Bose LifeStyle 50 System
How to hook up cable box, dvd player, and tv, to the home theatre system
Instructions things you'll need:
  • Composite video cable
  • TV
    • 1 Place the front left and right speakers on each side of the TV with the speaker labeled "Center" either above or below the TV screen. Set the rear speakers behind the seating area at head level and place the subwoofer on the floor a few inches away from the wall, which can absorb bass sounds if the sub is pressed against it.
    • 2 Connect the plug on the end of each speaker to the jack labeled for that speaker on the back of the Durabrand receiver. The cables are permanently attached to the speakers, so each may need to be moved closer to the receiver. For example, the left front speaker connects to the jack on the receiver labeled "LF."
    • 3 Plug the video cable from the Video OUT jack on the back of the receiver to a Video Input jack on the back of the TV.
    • 4 Plug in the Durabrand receiver and TV to the electricity and switch on both components.
    • 5 Press the "Input" button on the TV remote several times until the Durabrand signal displays on the screen.
Mar 25, 2011 | Durabrand STS98RW Theater System
Connected samsung ht x720 (home cinema system 2.1) to v+ box.Cant get picture when playing a DVD.Can hear the sound tough.Thanks
You probably need to change the incoming input signal on your tv.
In other words, your audio is coming directly out from your dvd player, and going directly to the audio power amp.
Your video does the same thing, except it goes to your tv. Your tv has multiple places for "incoming" signals to hook in to it. Take a look at where you're hooking your video in - the input should be marked ... something like "Component 1" "Component 2" "HDMI 1" "HDMI 2" ... something like that.
On your remove, there will be a button that says, "Input." When you push this, you will see that your TV brings up an input selection window. Pressing the "input" button on your remote should scroll through the ports on the tv. Briefly pause on each input selection to see if it begins receiving a video signal from your DVD player.
Nov 19, 2010 | Samsung Audio Players & Recorders
How do you unlock the tray for the panasonic sc-bt200 .when i press the button to insert a disc it says the word lock and it won"t open
Cannot eject disc. ≥The unit may have a problem. While the unit is off, press and hold (>> / >>I) and (< OPEN/CLOSE) on the main unit at the same time for about 5 seconds. Remove the disc . After disc removal or if this does not work you may need to reset to factory defaults. for the player alone.
To return all settings other than some settings to the factory preset.
≥Select “Yes” in “Restore Default Settings” in the Setup menu.
This returns all values in the Setup menu and the on-screen menu, except for “Remote Control Code”, “On-screen Language”, “IP Address/DNS Settings”, “Proxy Server Settings”, “Network Service”, “DVD-Video Ratings” and
“BD-Video Ratings” to the default settings.
If this does not work then you may need to reset everything to the factory settings.
To return to the factory preset. Everything Reset.
(No setting)
≥Reset the unit as follows:
1 Press [POWER] on the unit to turn off the unit.
2 Press and hold (>> / >>I) and press [POWER] and [< OPEN/CLOSE] on the unit at the same time for more than 5 seconds until “PLEASE WAIT” is displayed on the unit.
3 The power is turned on and then turned off automatically.
Cheers!
Feb 15, 2010 | Panasonic SC-BT200 Home Theater Systems....
I want to set up my dav-fr10w to 'interlace' option so i can play the dvd's on my tv, but it's set to 'progressive' right now and the instruction manual doesn't give the specific information to change it....
To cancel Progressive scan output or to change output to interlace signal format, follow these steps..
1- Select DVD by pressing Function button on unit.
2- While holding down |<< (review) button, press Function button on unit.
This will change output signal to interlace/ composite video output from yellow pin/ S-Video.
Hope this info will help you.
Thanks.
Feb 05, 2010 | Sony DAV-FR10W System
When watching a dvd, screen goes black and the word video appears on the screen in the upper right hand corner. Picture sometimes comes back, and then goes out again.
It sounds like your TV/monitor is losing the video feed. That's why it displays 'Video' - the label assigned to the input - so you'll know the TV is turned on but missing the input. You would get the same response from the TV if you turned the DVD off. I'd look at the integrity of the video connection from the DVD.
Jan 19, 2010 | Audio Players & Recorders
Pass word for dvd playing hts6510/05
1. Make sure there is no DVD in the player.
2. Switch on the player and press DISPLAY on the remote.
3. Key 99990 on the remote.
The screen will then show Regional 1 usa ect ok
Jan 26, 2008 | Philips HTS-6500/37 System
Philips Home theater system
Just run the yellow cord that came supplied with the HTS from the CVBS plug in the back of the HTS to any available yellow video input on your TV, then you want to change your TV's video/source/input/channel (the wording varies by tv manufacturer) to Video 1/AV 1/Aux 1, or whatever your television is calling the yellow input that you plugged into.
Also, Philips number is 1-888-PHILIPS
-Tha Mp3 Doctor
Jan 12, 2008 | Philips HTS3410D/37 700W DVD Home Theater...
Protection displayed on screen
See my post "HT-DB120 - PROTECTION due to shorted output stage "
Nov 08, 2005 | Samsung HT-DB120 System
Sony DAV-S300 System Logo
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
