Question about Maytag Dryers
8 year old gas dryer that hasn't worked since the first year
I own one of the first neptune front load gas dryer. Big deal at the time. Had problems under warranty. It never seems to have heat, just tumbles the clothes. I had a repairman out twice to replace heating element. This last time he said it was heating (barely at best), but that was the way the gas dryers worked.
I have to hang my clothes on a line and my towels on the railing to dry. I then air tumble them to try to soften them.
Help!!! I love the washer but the dryer is useless., However, I have never had to worry about shrinking anything ever in this dryer.
What do I do?
Peggy Goldman
    Genius:
  • 1,028 Answers
If that is a gas dryer and you have some heat suspect the 2 black coils on the burner valve there are problems with them failing to to open valve after 1 or 2 heating cycles ..also be sure vent to outside to clear and hose on back not flattened or kinked also it needs to as short as possible..also RARELY thermal fuse has been know to be intermittant it is supposed to blow but not reset internal connections may be faulty jump it out temporarly to verify let me know outcome good luck
Posted on Nov 26, 2008
I have a maytag neptune which is about five years old. It runs fine, but the dryer does not heat up. What should I do orcheck to diagnose problem?
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Jul 11, 2011 | Maytag Neptune MDE5500AY Electric Dryer
Not getting any heat on any setting. My Neptune dryer is now 6 years old. Is it possible a fuse has blown? Thank you.
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Oct 06, 2010 | Maytag Neptune MDE5500AY Electric Dryer
Unit will not dry clothes....vent is clear; no breaker problem; not over loaded; was working fine. unit is 6 years old.Will sometimes heat up at the start of the cycle but does not stay heated.
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
heatman101
Sep 09, 2010 | Maytag Neptune MDG5500AW Gas Dryer
Have a neptune front load dryer heat does not work either does the lights on the control panel. heat works for a second but panel where time and
heatman101
Sep 09, 2010 | Maytag Neptune MDE6700A Electric Dryer
Matage neptune mah8700aww purchased five years
4 screws takes the front off the washer to find the leak, dryer probably needs drum rollers. If you didnt know maytag went bankrupt for a reason
Jul 28, 2010 | Maytag Neptune MAH5500B Front Load Washer
My maytag dryer is not staying hot to dry clothes
Hi, If you have a gas dryer2_bing.gif.
The most common problem with a gas and no heat is the ignitor going bad...
Here is a tip that I wrote about that problem...
Gas Dryer2_bing.gif not Working Gas Dryer2_bing.gif Not Heating
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
If your dryer2_bing.gif is electric2_bing.gif..
There could be a number of different problems...
Check out this tip that I wrote about this problem...
Dryer2_bing.gif Troubleshooting2_bing.gif Electric2_bing.gif Dryer2_bing.gif won t Heat
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
May 19, 2010 | Maytag Neptune MDG9700A Gas Dryer
Maytag Neptune gas dryer. Lint-free. 4-1/2 years old. Good air flow. Burner only stays on for 5 seconds. Takes forever to dry a normal load and not getting hot. Temp is on normal. Time dry or automatic. Do...
Hi, sounds like a plugged vent. Pull the dryer out from the wall and disconnect the vent.Clean out any lint and make sure you have good airflow to the outside.
Jan 19, 2010 | Maytag Neptune MDG5500AW Gas Dryer
Maytag neptune gas dryer front loader 9 years old has begun to squeak what is the most likely cause?
Either one of the rollers or the idler pulley is causing the squeak. Most common to go bad in a maytag dryer is the roller on the right, it sits just above the heating element. You need to take the drum out and spin each of the rollers and the idler pulley to determine which one is the problem, and replace it. good luck. Shane
Oct 03, 2009 | Maytag Neptune MDG5500AW Gas Dryer
Dryers Logo
53 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
