Question about SanDisk Sansa e250 MP3 Player
Sansa e250 freeze up after taking it out while in the middle of "writing"
Well i had accidently took my sansa from tha plug in while it was still writing and now when it comes on it goes to refresh database eveytime and when its like 75% done the screen either goes black or a black screen with white lines come on. I have let it sit and turned it back on , plugged it back in, and took out the battery and waited , and nothing has worked.
    Problem Solver:
  • 8 Answers
This Should fix it! Thank you for contacting SanDisk Technical Support. We should be able to fix your player. Disconnect the player from the computer if it is connected. Please copy and paste the following link into your web browser address bar, and then click Go or hit your Enter key. When prompted, choose the option to Save the file to your Desktop. http://www.sandisk.com/Assets/File/Downloads/firmware/e200fw01.00.12.exe Once you have downloaded the file, please follow these instructions. 1) Double click on My Computer so that you can see it on your screen. 2) Turn the player off. 3) On the top of the player is a Hold switch, move it to the right (toward the headphone jack) so you see Orange. 4) On the left hand side of the player is a Record button, press and hold it while connecting the player to the computer. Continue holding the Record button until you see a new icon under My Computer called 16MB FORMAT. Once you see that icon you may release the Record button. 5) Double click the file you downloaded earlier and run it. Follow all of the on-screen instructions, and when you get to the prompt where it asks you whether you would like to Format it, choose Yes. Once it is done, click Finish. 6) Disconnect the player and look at the screen. Several things will be displayed, and when you see Key Lock, System Shutdown, move the Hold switch on the top back to the left. 7) Turn the player on and watch the screen. If you see a Refresh Database Fail error, you will need to follow steps 1-7 again until you do not get the error. If it does not work the first time, it could take up to 3 times for it to work.
Posted on Jan 16, 2007
Thanks alot ++++++++++++++++
Posted on May 14, 2008
Sorry but when I got to step 5 it said that Error: The application failed to read the version details :(
help plz!!
Posted on Apr 21, 2008
AWWW YEA
Posted on Apr 20, 2008
SOURCE:
Sansa e250 wont charge when plugged into the computer.
Sounds like the internal battery needs to be replaced.
Hope this helps. Good Luck!
Aug 07, 2009 | SanDisk Sansa e250 MP3 Player
My sansa e250 keeps connecting and disconnecting from the computer. every time i plug it into the computer, it keeps saying that it's connected and disconnected to the computer. this switches repeatidly...
If it is flashing constantly, go into Start --> Control Panel --> Printers/Other Hardware --> System --> Hardware --> Device Manager --> and uninstall either the Sansa or the MTP device. Disconnect the Sansa from the computer, and reinstall the software that came with the mp3 player.
-Tha Mp3 Doctor
Jan 17, 2009 | SanDisk Sansa e250 MP3 Player
I lost the drivers and my computer wont pick up my sansa
Uninstall all of the Sansa software.
Go to the Sandisk website and download the clean version of the software.
Reinstall the software.
Make sure your sansa player is not plugged into the computer until AFTER you have finished this process.
-Tha Mp3 Doctor
Dec 26, 2008 | SanDisk Sansa e250 MP3 Player
How do i get my sansa e250 to conncet to my tv
Plug a 1-to-2 audio jack from the headphone jack of the Sansa to two audio inputs (red and white) of the TV. Change your TV's source channel to the appropriate input (AV1, AV2, Video 1, Video 2, etc). Find the song on your Sansa and press play. you may have to adjust the volume on the Sansa AND on your TV.
-Tha Mp3 Doctor
Dec 20, 2008 | SanDisk Sansa e250 MP3 Player
Writing from media
It depends on how many songs you are trying to transfer. I wouldn't try transferring more than 10 at a time - should take 2-3 minutes max. 200 songs is going to take at least an hour on some players, and you are prone to run into problems.
-Tha Mp3 Doctor
Dec 16, 2008 | SanDisk Sansa e250 MP3 Player
Adding music
Wait until it is done syncing no matter what the player tells you, and don't send more than 10 songs at a time.
-Tha Mp3 Doctor
Sansa e250 Connecting Writing
is there a charger (cord plugged into the base) plugged in?
Jul 29, 2008 | SanDisk Sansa e250 MP3 Player
Sansa e250
Go ahead and do this, in case the DB is corrupted:
Format - Erases Everything: Connect your Sansa player to the computer and open Windows Media Player. Click on the Sync tab. Pull down the drop down menu underneath the Sync tab by moving your cursor over the Sync tab and left clicking on the little black arrow underneath the Sync tab. Highlight "Sansa 1GB" (wording may vary slightly), and then select "Format." - this should erase everything.
Firmware Upgrade- Erases Everything: Get the latest firmware upgrade from Sansa - it updates the firmware and erases every song in the player all at once. Note: this method doesn't work if already have the latest firmware. Go to this website and click "Firmware Updater" to find out: http://www.sandisk.com/Retail/DriverDownloads.aspx
-Tha Mp3 Doctor
Apr 08, 2008 | SanDisk Sansa e250 MP3 Player
Sansa e250 crash
you can try a firmware upgrade if you go sundisk website
they will have to software for that
Mar 06, 2008 | SanDisk Sansa e250 MP3 Player
Sansa seems to be frozen at startup
is my sansa broke or wat. when i plug the usb cord in the sansa comes on and wen i take it out it goes off , but the screen don't come on......i suffered the problem of wen the screen do come on it stops at the sansa rhapsody part then start over back to the big sansa screen then sansa rhapsody..........someone please help!!!!!!!!!!!!!!!!!!!!!!!
Sep 11, 2007 | SanDisk Sansa e250 MP3 Player
SanDisk Sansa e250 MP3 Player Logo
230 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Joe Negus
Joe Negus
Gyula Lacz
 Ben
Ben
Level 1 Expert
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
