Question about Dell Inspiron 6400 Notebook
Error accessing the lcd inventer
When i tried to boot my computer it shows darkness and it send me amessage with error code 2000-0322 when i tried a diagnosis test
  • wxsan2000 Jan 09, 2009
    5300:0D24
    Error accessing the LCD inverter
    Dell vostro 1200
  • Dell Master
  • 998 Answers
The error code 2000-032 (LCD Inverter error, unable to turn lamp ON/OFF) sounds like your LCD screen has a problem and needs to be replaced. The inverter circuit is located on a small circuit board on the LCD display panel. You can try reseating the LCD connector and see if this helps. Here’s a link to the service manual: http://supportapj.dell.com/support/edocs/systems/ins6400/en/sm/display.htm#wp1022270
Your responses are intended to improve the level of service provided. Please show your appreciation by rating your experience.
Thank You.
Posted on Nov 27, 2008
AI switch on my Acer its shows Acer explorer and then the screen go dark, nothing happening.
problem in lcd back light , open the lcd part and rehot mini ic on the lcd pcb 100% working
Nov 07, 2014 | HP 530 Notebook PC
HP G71-349WM Notebook Problem Starting Up
remove your hard drive put it into another laptop: when you boot the other computer; if the same problem reappears replace the hard drive
Feb 04, 2013 | Computers & Internet
Hp invent repeating startup error
If it is showing a blue scree of death (BSOD) and shuts downbefore you can read the error message try this:
Turn the computer off, then turn it on and immediately start hitting the F8 keyrepeatedly until you see SAFE MODE. Scroll down below Safe Mode and youwill see an option to Disable Automatic Restart. Select it and rebootyour machine. Next time it boots up you will be able to read the errormessage. You'll probably need a system disc or repair disc to fix theblue screen error message.
Mar 26, 2012 | HP xw4600 Workstation - 1 x Intel Core 2...
The screen goes very dark within a minute after booting up = I can just barely see the menu page
When you say screen goes very dark when it booted to windows so it means that when you turned on the laptop when the dell logo flashes the screen was fine? if thats the case could you please try this. after turning on the laptop you will see the dell logo flashes immediately keep tapping on F2 and then it will show you the BIOS setup utility, please check if in BIOS setup display goes dark as well. If yes then try this, after turning on the computer when dell logo flashes keep tapping on F12 to boot menu then select utility partition to run the diagnostics. Please run test on the LCD check if display goes black when running the LCD test. Then try this when you sees the dell logo keep tapping on F8 to boot in safe mode check if in safe mode display goes very dark. Try this too, boot in F8 then select last known good configuration check if the settings on your display will be fix. If you can boot to safe mode no problem then uninstall the display or video driver. then restart computer.
You can also try to connect an external monitor if you have one just try to isolate if issue is on the LCD or the video card. If the display is dark as well in external monitor then video card needs to be reseated if fails then replaced. In situation like this most video cards is integrated to the motherboards. So replace motherboard.
Dec 08, 2009 | Dell Inspiron 2200 Notebook
It turns on but does not show up it too dark to see anything I tried the auto adjust button but still nothing
if you are able to boot in safe mode then boot it and remove the display driver from control panel......and restart system normally.......if its not booting at all then check for RAM module on the motherboard and then check CMOS battry.....do reply back
Oct 19, 2009 | Acer AL1715 (Black, Silver) 17" LCD...
Please help me!!!!!!!
if you stopped flashing your phone in mid process, then you may have to send it in to be done manually.
or you can try holding *and # when you turn it on to access the boot menu and see what happens
Mar 10, 2009 | Motorola Mobility RAZR V3i Cellular Phone
Compaq Presario Disk Boot Failure, insert sytem disk and press enter
If you have your original Windows install disk, you can boot off of that, and should be able to recover most of your files, assuming your drive has not died fully. Depending on how important your files are, you can send the drive to a drive recovery service. I did that a couple years ago, they were able to recover all my files but it was EXPENSIVE. $1200.
Feb 19, 2018 | Computers & Internet
Dell Inspiron 6400 Notebook Logo
2,496 people viewed this question
Alun Cox
mukhtar21 shaikh
mukhtar21 shaikh
