Question about Philips Magnavox MWR10D6 DVD Recorder
Just bought, set up to record with TV and used a Memorex DVD+R
It stated "incompatable". What DVD disk is the best and will work?
  • 558 Answers
I wanted to let you know that this model dvd recorder will burn dvd -r, +r, -rw and +rw. if you have a problem with a brand of dvd disk then return the disks and use another brand, my dvd recorder (same model as listed here) likes maxell memorex the manual you have with the recorder has the prefered disks listed that have been tested. some disks need to be formatted before you use them to record.
hope this helps
Posted on Dec 13, 2008
  • 905 Answers
You can then only use the dvd-r cd's and not the dvd-rw disc
Posted on Nov 26, 2008
I just received the above laptop for Christmas and was attempting to make a set of recovery disks. The first disk recorded fine. I am using Memorex DVD DL disks. The second disk recorded almost halfway...
what is the error message.
simple if the error presits go to service center.recovery discs means os and its cost is included in laptop mrp.to correct this error is service center paople headace.software needs to be reloaded
Dec 31, 2010 | Computers & Internet
CyberHome DVD 1600 won't record to Sony disk
I believe the recorder is bad, it should be able to accept all brands and types of disks. You might want to try another brand and type of disk just to make sure, if it does not work, the recorder is bad. Good luck to you!
Jan 03, 2010 | Cyberhome DVR 1600 DVD Recorder
I have a Magnavox MWR 20v6, I keep on getting error messages.
I figured how to get the Memorex DVD-R's working again. I went and bought a DVD lens cleaner and all the errors stopped at least for a while I hope.
May 25, 2009 | Philips Magnavox MWR20V6 DVD Recorder/VCR
Trouble with DVD+RW Disks being compatiable or staying formatted
cos they are cheap - get some decent branded discs such as TDK or tayo yuden and it should be fine
Also check the manual and or requirements on there website and it should show which are the best discs to use for that player but TDK or tayo yuden should be fine.
www.svp.co.uk or any where you can buy discs from should be fine
Apr 15, 2009 | Panasonic DMR-EZ47V DVD Recorder/VCR
Dvd recorder formatting problem
#1
Insert your ( memory card , flash disk , cellphone , .... ) into your computer.
#2
Open up 'My Computer'. You should see it under the list of available drives.
#3
Check its contents first to make sure that you have the right drive.
#4
In 'My Computer', right-click on the drive and choose 'Format'.
#5
Leave all the options as they are and click on 'Start'. This is a non-reversible process so make sure this is what you truly wanted to do in the first place.
#6
Once the process is completed, take the memory card out and insert it into your Digital Camera or any other device. Try to browse to it to make sure it works fine
welcome
May 20, 2008 | Panasonic DMRES15 DVD Recorder
Error code E 4 54040990
You need to go into the set up menu and select recording options. On the recording options menu, scroll down to dubbing options. On the dubbing options menu select either VCR to DVD or DVD to VCR.
Recording and Dubbing are not the exactly the same thing. You use the record buttons to record TV directly to VCR/DVD you use the dubbing buttons and set up to record DVD to VCR or VCR to DVD.
Hope this helps.
Dafid
Apr 16, 2008 | Philips Magnavox MWR20V6 DVD Recorder/VCR
Incompatible disk message
You need to read page 8 of the JVC CU-VD20 DVD Burner instruction manual:
Recommended DVD-R Vendor - JVC, TDK, Verbatim, SONY
Writing Speed for DVD-R is 8X maximum, this is the real issue as I first bought 16X TDKs and they did not work, so now I need to buy 8X.
That's a bummer as most stores only supply 16X now.
Nov 30, 2007 | JVC Everio Share Station DVD Burner Burner
Mini DVD Camcorder Problem
You will never be able to recover the information. Sony's system really will have problems with third party brands; there is particular engineering that makes this so. In my shop (Sony authorized), I have seen this problem many times. If you insist on using other brands, get used to problems. As your laser assembly wears it will become more problematic. Good luck, magic seadog
Jun 14, 2007 | Sony Handycam DCR-DVD201 DVD Camcorder
Dvd disk cannot be used to write
You should ring Sanyo helpdesk direct for fault like this as you shouldnt be having problem of this nature also would be good idea to go back to where you bought it to see if they have heard of problem,.
May 15, 2007 | Sanyo DRW-1000 DVD Recorder/VCR
Philips Magnavox MWR10D6 DVD Recorder Logo
98 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
