Question about Garmin GPS
My garmin nuvi 350 voice guidance started to fade away and have been working on and off for quite sometime.Can somebody have a similar problem and any solutions available?thank u
  • Garmin Master
  • 2,130 Answers
Please read the article that I wrote on this topic. I can help you resolve this problem.
http://www.fixya.com/support/r1094734-no_sound_or_garbled_sound_nuvi_series
- Jim
Posted on Nov 26, 2008
Voice guidance lost
If the unit is turned off prior to loading everything, there is a good chance it will blow the voice file away.
You will have to go to the Garmin web updater and re-install the voice you want.
Jun 08, 2010 | Garmin nuvi 780 GPS
My garmin 350nuvi will not acquire sattelites
Make sure to flip your antenna horizontally or 90 degrees and not vertically or 180 dgrees. I see to many people try to use their older nuvi this way and it does not function well.
Try also updating your unit with the latest firmware from Garmin, this helps sometimes.
You may have moved to a location that is far away from the last location your Garmin nuvi 350 was last use, try to keep your unit on for 30 minutes or more to see if it will acquire GPS sattelites.
Last, certain vehicles have shielded windshields and GPS does not work well with these windshield, this can be eaisly verify by simply taking your nuvi 350 out of your vehicle and turn it on with a clear view to the sky, if that still does not work, it could be a defective GPS receiver or GPS connection in which case you should consider sending it in to Auto Nav 2000 Plus, Inc in San Jose CA or Garmin.
You may also consider replacing your nuvi 350 with a newer model nuvi with fresher map.
Good luck
Apr 03, 2010 | Garmin Nuvi 350 Car GPS Receiver
The voice stopped working on my Garmin Nuvi 350 in mid sentence
what has happened? my etrex said low batteries. I changed batteries. now all I get is searching for sattellites? can anyone help?
Mar 30, 2009 | Garmin Nuvi 350 Car GPS Receiver
My Garmin Nuvi 350 sound not working
I had this problem with the 760. Solved by going to settings>language and discovering I had no choice for "voice". I pressed that selection and picked american english and my problem was solved. Garmin support said sometimes the program gets corrupted and that choice needs to be made again.
Jul 03, 2008 | Garmin GPS
Garmin Nuvi 260 - how to activate text to speech
Question: How do I change the Voice Language setting on my nuvi 2xx?
--> Answer: All of the Garmin® automotive GPS units that speak street names are also loaded with basic voice prompts (example: Turn Right in 500 feet) as well as Text-to-Speech (TTS) voices that speak street names. If one of the basic types of voice prompts has been selected, the voice prompts will not speak street names. In order to change this setting on the nüvi® 2xx series, follow these steps:
  1. In the Main Menu, touch Tools (Wrench icon).
  2. Touch Settings.
  3. Press the Down arrow in the bottom right corner.
  4. Select Language.
  5. The first line on this screen is the Voice language. Touch the Current Voice option for the GPS device listed to change the Voice.
  6. Select a Voice that is labeled TTS. These will speak street names. Options without the TTS label will say the distance until the next turn, but will not include the street name.
  7. Select OK. The Voice has now been changed.
The device should now speak street names. This is tghe solution that I found on the Garmin site. It worked for my device. Hope this is helpful. solution = solution1description.innerHTML; Last modified on: 04/14/2008
--> Other recommended links Next Solution >> nuvi 260 nuvi 255 nuvi 200 nuvi 270 nuvi 205W nuvi 260W nuvi 250 nuvi 250W nuvi 255W nuvi 205 nuvi 200W -->
Dec 28, 2007 | Garmin nuvi 350 GPS Receiver
No sound
okay first i need to know the make and model many gps systems and almost all models are wired differnt
Dec 15, 2007 | Garmin nuvi 350 GPS Receiver
Garmin nuvi 350 troubleshooting
1)Does it make beeping sounds when you touch the screen buttons?
2)Can you hear the voice when you listen through an external headset?
If your answer is no to #1 and yes to #2 then you may have a dead speaker.
In the setup screen there is a way to select different voices/languages.  Try a different voice.
When those models first came out there was a problem with the software not recognizing the voice files.  There was a free update done to correct the problem.  If your current software version is less than 5.00 you should update.
Here's the update page:  http://www8.garmin.com/support/collection.jsp?product=010-00455-00
Oct 26, 2007 | Garmin nuvi 350 GPS Receiver
GPS Logo
346 people viewed this question
Top Garmin GPS Experts
Marvin
Marvin
Steve
Will Halftowaite
Are you a Garmin GPS Expert? Answer questions, earn points and help others
