Question about Mitsubishi CK-32308 TV
Pitchure will go black with power button lit..
My tv is a 30" screen and 2 monthsago it started to fade out on pitchure.a couple seconds later it went back to normal. well as the last week or so it loses pitchure completely with power button still lit, so we shut it off.. and a few minutes later , we will turn tv power button on,, and then it goes on..seems to go black on picture more and more now. is it the tv tube? please help sweetleaf
SOURCE:
  • 192 Answers
SOURCE: Picture with gray box
The text mode in the closed caption is turned on.Turn off the closed caption. I don't have the schematic in front of me, so, I will wing it. There may be a button on the remote that says CC, if so then use that button to turn it off, if not then go to the service menu and you may have to search a bit. Either way it's an easy fix and you can do it yourself. If you can't find it, then, reply and I will give better instructions when I get into my shop next week.
Posted on Aug 12, 2007
  • 1153 Answers
SOURCE: TV turns off a second after turning on....
You have a high voltage shutdown problem, look at the threads here on Mitsubishi and you will find your answer.
Posted on Sep 21, 2007
  • 1153 Answers
SOURCE: black screen and have sound
find problem here in threads,
SOURCE: Mitsubishi WS-55807 TV won't turn on
I have the same problam,I got this tv for free and i am trying to find out what is wrong with is so i can fix it.has any of yall got yalls fix if so what did you do to get it to work.
Thanks
Dustin
Posted on Jul 01, 2008
SOURCE: Turns off as soon as I turn it on. ws - 65819
I had the same problem. The repairman said the Convergence ICs were bad, located on the big aluminum heat sinks on the center board in the TV. He replaces both, and a couple of fuses (that look like resistors).
The tv worked fine for a couple of days then did exactly the same thing. They are coming back out to fix it next week. If there is anything different, I'll post an update.
Posted on Mar 22, 2009
Turned on my Element FLX 3210 32" TV this morning. When it powered on, there was a black spot in the middle of the screen that reached from the top of the screen to the bottom. The left and right...
there are 2 capacitors on the power board that need replaced with exact replacements. They will be labeled ec17 and ec18 on the power board. The caps themselves will probably be brown or black and say 10uF 450v on them. You should be able to get the parts at radio shack or digikey or mouser. You will also need a solder gun and some solder. Check youtube on how to solder and always remember to unplug the TV before servicing.
Dec 21, 2010 | Element Electronics FLX3210 32 in. LCD TV
Was playing Super Smash Brothers, played 1 5 stock 1v1v1v1 against 3 computers, then went and started a second round. It lasted for about a minute or 2 and then it locked up... i hit the reset button, and...
Well I think that the expansion pack has died I had a problem while I was in the middle of perfect dark it would freeze and then 2 seconds later the screen went black and than it went to the tv screen saying no signal. the expansion packs make it look like it died but it didn't.
Nov 01, 2010 | Nintendo 64 Console
Last night watching tv, picture cut off (black screen) but power light on set stay on. then after bout 30 seconds the power button went off. Turn set back on , powere light lit but no picture and again...
Power supply board is dying not giving the tv correct voltage anymore.The power supply board,that the board power a/c cord plug into it.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish power supply board for the replacement.
Sep 10, 2010 | Sanyo DP50747 50 in. Plasma TV
My HP laptop screen will not do anything. The first time this happened, I was in the middle of something and the screen suddenly became a bunch of black and white random-ness. I shut it down, and tried...
Perform the following:
1. Disconnect the AC Adapter.
2. Remove the Battery.
3. Hold the Power button down for 30 seconds to 1 minute.
4. Reconnect the AC adapter and do NOT connect the battery now.
5. Turn on the Notebook power.
If turned on, shut down the Notebook, insert the Battery and turn it on again. That's it.
Cause:
With an extensive use of the notebook, some times notebook would store some static charges which indeed will stop the notebook from powering up or charging the battery.
Performing above procedure will not effect any personal data or delete any pictures from the hard drive on your notebook.
Aug 22, 2010 | Computers & Internet
I have 2 Polaroid flat screen tvs. The 19
A trip to the dump may be the most cost-effective answer.
Jul 19, 2017 | Televison & Video
PSU hangs the system: can't turn on; turns of in 30 min
either the power supply needs replaced or there is a short on the board...
pull the mb and guts of the system out of the chassis
connect the power supply with one cpu and one stick of memory for testing.. no add-in cards installed
then test the power capabilities..
if the system works out of the chassis.. ( alot of work to do ...understood )then there is short to the chassis of the from the motherboard
i really think the power supply is the issue though
Sep 29, 2009 | Computers & Internet
Sharp LCD TV, Screen goes black sound stays on
Capacitors on the power pack are going bad they need to be replaced that should fix the problem.
Apr 07, 2009 | Sharp LC20SH7U Television
Compaq R3000 laptop screen went black
Give this a try -
1. Remove all USB devices such as printers, mp3 players etc etc.
2. Remove the power-cable and the battery
3. Press and hold the power button for 30 seconds
4. Put the power-cable back in but not the battery and none the USB devices.
5. Turn the computer on
Let me know if it doesnt work.
Jan 20, 2009 | Compaq Presario 2190US Notebook
Tv screen goes black
No, if the picture of your tv screen is clear when when you watching. the troble of your tv is looseboard, and you replace your CRT socket too.
Apr 16, 2008 | Sony KV-35V35 TV
Televison & Video Logo
24 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
