Question about Samsung DLP HL-P5663W 56" TV
Shadow top to bottom of screen on left side about 2" wide...
50" Samsung DLP 3 yr's old. It just appeared; started out as a 1" shadow top to bottom and within a week it's now a 2" shadow on the left hand side of the screen..
  • Anonymous Nov 29, 2008
    I have the same problem with my 56" but its shadow is about 6"
    Genius:
  • Samsung Master
  • 1,689 Answers
This can be the sync wheel assy, failure in the drive circuit for the display chip, or an illumination fault. You will have to give the set out for service.
Jerry G.
Posted on Nov 26, 2008
I just replaced the color wheel on my samsung hln5065w. Picture is great but there is a shadow on the right side of screen from top to bottom. The shadow on the top of the screen is wider across the screen...
Its a Good Possibilty that its the New Color Wheel causing this,if the colors are not complete on the color wheel then that will be why you are seeing shadow on right hand side of screen.
I know I ordered color wheel for mine and had to send it back,it did the same thing.
I compared it to the old color wheel and the new one did not have Solid colors on it.
Can you see picture behind the shadow? or is it shadow and no picture?
Mar 06, 2011 | Samsung HLN5065W 50" Rear Projection...
My dlp tv has a shadow about 6'' wide and full ht of tv
Hello: The problem is that a small mirror on the light tunnel has fell off causing a shadow in the picture,. In the past the only way to repair this problem was to replace the entire Optics Engine. But Samsung decided it was replacing entirely to many light engines so they decided to allow and train technicians on how to do it. It involves removing the color wheel and behind it is the light tunnel where light from the lamp shines on to a maybe 1 1/4 inch small block with three mirrors on all sides, your problem is that one of these mirrors has come loose from its side, causing a shadow with the pic still in the background. So if you call a technician to come, if he has'nt had the training from samsung on how to do the procedure then he will want to replace the entire optics engine which is the expensive way of doing it.
So when calling as if they know how to replace light tunnel. There are some adjustments that also needs to be done once it's replaced. To verify what i am saying go to this site to find out more. http://www.avsforum.com/avs-vb/showthread.php?t=758625
Call if you need more info will be glad to help..
Delhielectronics@live.com
Phone: 702-418-1389
Sep 26, 2009 | Samsung DLP HL-P4663W 46" Rear Projection...
Optoma RD-50 DLP has dark vertical shadow on right side of screen
turning off the main can be very harmful to rear projectors if you dont wait for the cooling off period, for instance when you turn off the tv from the remote, the fans inside are still on in order to dissipate the heat given out by the lamp. as a result some of the lens inside the engine may have burns-in caused by excess of heat.thus leading to shadows on the screen.
hope this helps
please rate me!
Mar 19, 2009 | Optoma RD50 50" Rear Projection HDTV-Ready...
Shadow along side
does this shadow go from top to bottom on the left or right side app 1" to 2" wide ? if so your light engine needs to be replaced
Jan 17, 2009 | Toshiba 46HM95 46" HDTV
Shadows on screen
Try moving a medium powered magnet (not one for picking up heavy objects and not a refrigerator holding one) over the distorted area. If that doesn't work, try a more powerful one. This worked for my Toshiba LCD. Good luck!
Jan 04, 2009 | Sylvania 6626LCT 26 in. LCD Television
Samsung dlp tv
Yes, it could. There is a light pipe in the light path that could now be broken from the bumping or it could just be out of line from the bumping. Another problem could be the mirrors in the projection path could just need adjusted by the 3 screws that are beside the mirrors. This may also happen when bumped.
Mar 20, 2008 | Samsung HLR5667W 56" Rear Projection HDTV
PICTURE SHADOW
Search for "Light Tunnel".
Feb 05, 2008 | Samsung HL-R5078W 50" HDTV
Hl-44266w screen allignment
Don't recommend replacing the light tunnel if you never had any experience with DLP optical systems. you need to pay careful attention to the way you remove any screws or you will be forced disassembling the engine multiple time to get the alignment correctly.
Jan 01, 2008 | Samsung HL-R4266W 42" HDTV-Ready...
Left side of television just started having a shadowing problem?
I have the same problem and was told by a technician that I need to replace the light engine. Probably around $ 700.00.
Oct 15, 2007 | Samsung HL-R6167W 61" HDTV
Shadow down right side of screen on a toshiba 44NHM84 44" DLP television
shadows at the bottom of the screen sound like moisture that was "wicked up" between the screen layers and dryed out leaving a stain. DO NOT get these screens wet, use nothing but a damp soft cloth; just a few drops of water running down the screen can cause a fairly large stain. Some people have suggested that they may be professionally cleaned, but the risk of damage is too great on the user level.
Nov 12, 2006 | Toshiba 44NHM84 44" TV
Samsung DLP HL-P5663W 56" TV Logo
238 people viewed this question
Henry  Thomas
Henry Thomas
