Question about Sony FD Trinitron WEGA KV-21CL10 21" TV
Sony 2167 No power on
I have a Sony TV model number KV-2167MT Trinitron. I'm facing problem while switch on from front switch Standby LED blinking while press any switch Like Volume up down, program up down. but power not on. I found 2sd1878,PS801 and F502 crystal (near CXA1213 IC) faulty. After replace all component it work 30 minutes after that transister get short again I change tr. twice but problem is same. Tr. 2sd1878 short after 30 minutes. I check output voltage 110V DC is normal. Please suggest. I have a Sony TV model number KV-2167MT Trinitron. I'm facing problem while switch on from front switch Standby LED blinking once while press any switch Like Volume up down, program updown. but power not on. Low level humming is hearing from power supply.
  • Anonymous Dec 07, 2008
    when my tv i power it on after 3 seconds it will shutdown automatically
    Genius:
  • Sony Master
  • 1,667 Answers
I have not worked on your particular model. But, I have serviced many TV sets over the years. My answer will ge generic.
Check all the capacitors in the horizontal output stage and power supply areas for high ESR. All the caps that are out of spec must be changed.
The high voltage multiplier & flyback can also cause the fault you are having.
You have to consider that the DC voltages are not the only important spec that has to be met. There are also many power drive signals that work with reactive devices. If there is any defect in the critical areas there will be failures.
Jerry G.
Posted on Nov 26, 2008
2 Suggested Answers
SOURCE: Sony 2167 No power on
check video processor output diagram and signal amplitude if u can find video processor raplace it and try it must work
Posted on Sep 14, 2007
Sony tv model KV-HA21M80 is having problem front stand by L.E.D is blinking 4 times and stopping
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. Electro help
Jan 14, 2015 | Sony Televison & Video
Sony CRT TV not switching on power on LED keeps blinking
How many times do this standby LED blinks at one time switch on? These blinks are fault indications. From the number of these blinks, you can get an idea about the faulty section circuit inside. Count it. If you wish to get more details, check this site. Pull up older posts there. Check this site with patience, as it has over 2200 posts now. All are related to electronic equipment repair help. Blinking codes to Sony CRT based TVs and all other models are given in detail. Check it and confirm.
Apr 08, 2013 | Sony FD Trinitron WEGA KV-29LS35 29" TV
I have a Sony Trinitron 32" TV. The picture don't
Hello
Blinking of standby light in Sony sets are fault indications. You just count the number of blinks occur at a time, by switching the set ON-OFF by its front panel power switch, not by the remote control handset. Just do it for at least three or four times, count the exact number of blinks occurs there, and inform it to me through Fixya. Through the number of blinks, I can locate the faulty section, of somtimes to the exact fault location. Count it keenly and inform me. OK.
Dec 16, 2010 | Sony FD Trinitron WEGA KV-32FS120 32" TV
My Sony KDF-50WE655 does not turn on. Only the standby LED Flashes several times and then goes steady green, but the lamp light remains off.
Hello
You just count the number of blinks of the standby light before it goes out to green. In sony sets this blinking count ic critical for us to locate the faulty stage. You just count it after switch it Off by Power switch and Switch it On by the power switch at the front of the TV, for at least three or four times, and make sure abut the number of blinks, and report it to me. Ok
Nov 14, 2010 | Sony FD Trinitron WEGA KV-36FS120 36" TV
TV won't turn on, standby LED starts blinking
HI, this is the result of an unstable power sector in this unit. the fly back is malfunctioning and, you will need to replace it asap. i will list the part number below and a link to a site as well. you can purchase this part on-line if you wish.
FBT ASSY NX-4521//X4
Sony Part Number: 1-453-310-11
CLICK HERE TO ORDER
Jun 21, 2009 | Sony FD Trinitron WEGA KV-27FS120 27" TV
SONY TRINITRON KV-2167MT power not on
Please replace Horizontal Output Transistor in KV-2167MT and TV will start function.
Nov 26, 2008 | Sony FD Trinitron WEGA KV-21CL10 21" TV
Sony wega model: kv-32FS120 doesn't turn on
Check your power supply board and resolder the pcb, check the switching diodes and zeners.
Jan 30, 2008 | Sony FD Trinitron WEGA KV-32FS120 32" TV
No Power on Sony TV
Be sure to use an ORIGINAL Sony transistor and be sure to resolder the pins of the small horizontal driver transformer and all parts connected to and around it, and your set should be fine.
Aug 17, 2007 | Sony FD Trinitron WEGA KV-20FS120 20" TV
Aug 13, 2007 | Sharp 32C-240 32" TV
No Power on
Hello, please check the transistor 2SD1878 near flyback transformer and fuse PS801. Best regards, Arpi
Jul 18, 2007 | Sony FD Trinitron WEGA KV-20FS120 20" TV
Sony FD Trinitron WEGA KV-21CL10 21" TV Logo
170 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
