Question about Zebra TLP 2844-Z Thermal Label Printer
Cannot print i;m using Printer Zebra TLP 2844.. i have done auto sense media gap sensing, bit it sill cannot print any doc... when clik,the printer icon, its shows and dissepear suddenly..
  • jglinville Dec 12, 2008
    we're an academic program trying to get the printer to work with lims software for tracking "evidence" in our lab. same problem. the test page works, but it won't print from LIMS software
    Problem Solver:
  • 15 Answers
The printer doesn't understnd the label. So it just reads and drop. The label has to be in ZPL (or I read somewhere PCL) language and then it will work
Posted on Dec 11, 2008
Zebra TLP 2844 label gaps
you can try contacting zebra. im not familiar with that model.
Aug 25, 2017 | Zebra TLP 2844 Label Printer
TLP 2844 GAP sensor problem (I guess)
I had the same problem. I found out later there was a small piece of label sticking against the sensor, thus blocking the sensor from sensing the end of the label. As soon as I removed the label (open the cover, it is on the top part) it immediately started to work as usual. Hope this helps.
Apr 22, 2009 | Zebra Eltron TLP 2844 Thermal Label...
Hi, My printer model is TLP 2844.i m facing the problem in printing. The printer is hang after one or two lines printing and red LED are ON and I press Green button repeat same as before. Please solve my...
Solid red light. This indicates the printer is in an error state and will not print until the error is cleared. Check to make sure the printer is not out of labels or out of ribbon if it is a TLP model.
A solid red light will occur if
  • the printer is out of labels
  • the printer is out of ribbon ( TLP models only )
  • the printhead is open, not latched down all the way. Press down on the top cover of the printer to see if the error light clears and goes to green.
  • the ribbon spool is slipping on the ribbon spool holder on TLP models:
These 2 links will help you troubleshoot the problem:
https://support.zebra.com/cpws/docs/eltron/2844/28x4_rib_det.htm
https://support.zebra.com/cpws/docs/eltron/2844/2844_tsguide.htm
Click on this link. Or copy and paste it into your browser.
If I could be of further assistance, let me know.
If this solves your issue, please be kind to rate it.
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Mar 15, 2009 | Zebra TLP 2844-Z Thermal Label Printer
Cant print on butterfly label with Zebra TLP 2844 printer
This is a problem of label sensing.
You are probably using the Gap sensor on the 2844, unfortunately the shape of the butterfly labels means you are sensing the wide gap between the labels in the centre, so it will not print anything in the apparent gap area on both ends of the label.
What your label or system supplier should have done is supplied you with the same labels but with a 3mm wide black mark on the underside of the label backing paper, centred between the labels. You can then change the printer sensor setting in the driver to Black Mark. You will then be able to print anywhere between the black marks.
Any problems with this contact us directly at Lancer labels Ltd
Nov 28, 2008 | Zebra TLP 2844-Z Thermal Label Printer
MY ZEBRA TLP2844 print a symbol...
de-install then re-install the printer driver.
also if it has multiple interfaces (such as serial and parallel) be sure to load the appropriate driver.
Nov 22, 2008 | Zebra TLP 2844-Z Thermal Label Printer
Zebra TLP 2844 Desktop Printer
make sure you have selected the correct media in the printer driver. The tracking mode has 3 options, (1) Web Sensing (Cut Labels), (2) Mark Sensing (Black marks on back of liner) and (3) Continuous . In your case select continuous. It sounds like the printer is in the wrong media mode and is feeding labels looking for a mark or gap and when it doesn't find one it flags a media error.
Aug 15, 2008 | Zebra TLP 2844-Z Thermal Label Printer
Zebra TLP 2844-Z Test page print within Win XP
This printer requires special software to print labels with. It uses a unique PCL language to work with. Thats why when you use these printers with Fedex or UPS software, it typically downloads forms first before working.
Zebra used to see a label designer program to work with it. You might want to check with them to see if they still carry it.
Jul 28, 2008 | Zebra TLP 2844-Z Thermal Label Printer
Zebra LP 2844 prints blanks
If the printer is printing nothing but blanks, try another roll of labels.
If the printer is printing blanks in between labels, it probably needs to be gap sensed. You can do this by:
1. turn the printer off.
2. hold the feed button down and then power the printer back on while still holding the feed button down.
3. release the feed button when the light flashes.
4. the printer will then regap itself
5. when the regapping is done, press the feed button once. It will print on the label that it is 'out of dump'
6. the printer should then be ready to go.
May 03, 2008 | Zebra LP 2844 Thermal Printer
Zebra TLP 2844-Z Thermal Label Printer Logo
175 people viewed this question
Top Zebra Office Equipment & Supplies Experts
Dave Busselle
Level 1 Expert
Marvin
Marvin
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Zebra Office Equipment and Supply Expert? Answer questions, earn points and help others
