Question about SanDisk Sansa m240 MP3 Player
SanDisk Sansa m240
When i insert my mp3 USB cable into the computer, in the device manager it has its own like USB hardware. i cant open the files on my mp3. i dont know how to open it, it clearly doesnt work with the usb cable. before i just used to insert the usb cable and it would appear on My Computer, but now its not even there when i insert it. so when i insert the usb cable, in the device manager there appears a new thing 'Windows Poertable Devices'. and i dont know how the hell to open the folders on my mp3. i saved some data on it and now i cant open them. please if anybody knows how to fix this problem email me!!! wahid@mail.ru
Hi i have been facing a pro with my sony mp4(2GB) china made player i've been formatted it with fat32 after formatting it became 108 mb one of my friend said format it with fat and i did it became 101 mb how can i fix the pro pls mail me sanscruz_justforu@yahoo.co.in
Posted on Jan 07, 2007
Does anyone know if mine, a SanDisk 1.0 GB is salvageable? The CD that came with it was destroyed when my helper cut into it opening the plastic...:( so it has never been used...is there away around this...
Definitely! You don't need the software at all. Just connect the player to your computer with the USB. It should open as a disk drive (if it asks you, choose 'open folder to view files') and then you can just copy music to it with drag and drop. Then use 'safely remove hardware' before you unplug it again, and you should be 'good to go'.
Mar 31, 2011 | SanDisk Sansa m240 MP3 Player
Used for years. Deleted mp3 files. Tried to reload new mp3 files by select all and drag and drop to audible folder. Message said it was full and would only load partial. Deleted partial load safely...
Sorry mate it has been corrupted and and may not work any more it seems the set up and read file that is like a operating system has been moved or deleted. The same things happens with usb drives.or has been disconnected without using the disconnect usb device icon.
Jan 31, 2011 | SanDisk Sansa m240 MP3 Player
How do you erase songs you downloaded?
1. Turn on and connect your Sandisk MP3 player to the computer using the USB connection cable.
2. Select "Open folder/device to view files" when prompted by Windows Explorer. You can also look for the Sandisk MP3 player under "My Computer."
3. Navigate to the folder on your device where your songs are stored.
4. Select the files (songs) you want to delete and press the "Delete" key.
5. Exit from the window, then disconnect the USB cable from the Sansa MP3 player. The player will automatically turn off. The memory will update the first time you turn the player on
after deleting songs.
Sep 29, 2009 | SanDisk Sansa m240 MP3 Player
Sansa m240 files won't show up on computer
Uninstall/remove the mp3 player from the device manager of windows while its plugged into you computer and unplug afterwards from your usb port and plug it back in, windows now sees a new device and starts installing it.
Go to the configuration panel\system and click at the tab hardware and klik at the button device manager.
This should solve the problem.
Succes.
Aug 31, 2009 | SanDisk Sansa m240 MP3 Player
Cant delete recordings off of sandisk sansa
If you connect the mp3 player to a computer. You can open up the device as a folder and delete any files including the recorded files from the computer.
Benjamin
Mar 20, 2009 | SanDisk Sansa m240 MP3 Player
Sansa m240
Your device is too full.
The device needs 8MB of free space to create the database or menu.
Connect the device to your computer, go to My Computer>Device Name (m240)>Open the device and manually delete some songs, 10 should suffice.
Disconnect the device and re-start it.
Your device should function as normal.
Best of Luck.
Oct 13, 2007 | SanDisk Sansa m240 MP3 Player
Sandisk sansa m240 mp3 player
You can connect the device to your computer and manage it thru "My Computer. Open My Computer, then open the device (i.e. Sansa m240). Inside there is a Music folder, you can delete them from here. You can also drag songs here to transfer to the player. If you are not able to see the "music" folder, you may need to enable "Hidden Files and Folders" on your computer. Best of Luck.
Sep 06, 2007 | SanDisk Sansa m240 MP3 Player
Recognise my sansa
to old for vista to recognize
Apr 29, 2007 | SanDisk Sansa m240 MP3 Player
A SanDisk Sansa m240 MP3 Player problem regarding the install cd!
First remove the Sansa from computer if you have attached it. 1. Open your Sansa mp3 player menu (with menu button next to volume control) 2. Choose settings 3. Choose USB 4. Change setting under USB from 'Auto Detect' to 'MSC' 5. Exit menu with menu button Plug your Sansa into computer with USB cable. You can now see the mp3 player as external drive, and you can drag mp3 files into it. Put your files into Sansa's Audible folder.
Sep 09, 2006 | SanDisk Sansa m240 MP3 Player
SanDisk Sansa m240 MP3 Player Logo
54 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Mohamed Ismail
Mohamed Ismail
 Ben
Ben
Level 1 Expert
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
