Question about Whirlpool GH5184XPQ Microwave Oven
Microwave error message
I have a whirlpool GH5184XP and when I try to pop popcorn I recieve a error message that reads F3H
  • Anonymous Mar 28, 2014
    the touch screen does not function but the manual numbers do
  • 446 Answers
Unplug your unit for 1 minute and plug it back again, you'll be surprised ...it will work again cheers
Posted on Nov 26, 2008
Whirlpool Microwave MH6700xW-0 Blows internal fuses regulary
Assuming your power line voltage is okay, it would not surprise me that after 27 years, your high voltage capacitor is drying out and increasing its capacitance. This will cause variance in the high voltage output, which can stress the magnetron and increase current consumption.
You can order Whirlpool parts my model number here.
http://tinyurl.com/gv383
For more free DIY and other help & advice, feel free to contact me via my site.
William E. Miller, AS-EET
http://www.microwavecontrol.com
Microwave Oven Control Panel Repair Nationwide
"Recycling by repairing since 1982"
Mar 16, 2017 | Whirlpool Microwave Ovens
Whirlpool Microwave error F3H
F3H Humidity sensor failure 1. Unplug microwave oven or disconnect power.
2. Connect a new sensor to the board (at P5).
3. Plug in microwave oven or reconnect power.
4. If no failure code appears when starting sensor function:
 Replace old sensor.
5. If failure code appears when starting sensor function:
 Replace power supply board.
6. Plug in microwave oven or reconnect power.
Aug 04, 2010 | Whirlpool GH5184XPQ Microwave Oven
Whirlpool gold gh5184xpb Everything seems to be working but it doesn't heat. If you use the buttons for popcorn or dinner plate, an error message F3H appears. Recently got a wireless router in our home...
its very unlikley to be the wireless router,,,
things like this just happen,,,i would say the magnatron had gust given up the ghost, thats the part that gets the food hot,,,safest bet is have it looked at but get ready to buy a new unit as its likley to be the cheepest way out
please dont go poking about inside your microwave,,
it will still have 1000's of volts inside it,,, these volts will kill you if you tuch the wrong part,,be warned!!!
Jun 05, 2010 | Whirlpool GH7155XHS Microwave Oven
F3h error on a whirlpool microwave
Unplug microwave for 2 minutes or so then try again.
May 07, 2010 | Microwave Ovens
Error message
may be u dnt have any service
Dec 04, 2009 | Whirlpool GH6177XPS Microwave Oven
Whirlpool Gold Accuwave wont heat
Hi, there are three issues that will cause a no heat situation in a microwave. these issue are a failed Magnetron, busted cut-off fuse and, failed diode.
I recommend checking all these area that are located inside the microwave for faults.
The most common issue will be a failed Magnetron.
The diode and, fuse will be located on the noise filter assembly.
May 19, 2009 | Whirlpool MH7140XF Microwave Oven
Error code F3H on model GH5184XP
F3H is a humidity sensor error.
You may be able to clear the error by unplugging the oven for a couple of minutes. Then plug it back in, reset the clock and try again.
If it still has the error after a reset, please write back so we can give you another suggestion.
We're happy to help you and we'd appreciate your thoughtful rating of our answer.
Jul 18, 2008 | Whirlpool Microwave Ovens
Dacor Microwave/Conv Oven DCM24S
Placing the bag on an inverted glass bowl or pyrex casserole dish worked!!!!!  For 2 years, I have cursed my Dacor microwave for its inability to make popcorn (burns a hole in the bag, bag stays flat, almost no kernels pop, etc...)  I read the last suggestion to use the glass plate and I am now sitting with a bowl full of perfectly popped popcorn - with only 1 kernel unpopped.  The metal tray in the microwave conducts too many waves through the bag I guess.
Thanks for the solution!
Apr 15, 2008 | Dacor DMT2420 1200 Watts Microwave Oven
Microwave troubleshooting
I found the fix to the F3H error on another site. Just turn the power to the microwave off for ~2 minutes at the circuit breaker, and then turn it back on. Microwave will start working again then.
Feb 23, 2008 | Whirlpool GH5184XPQ Microwave Oven
Microwave suddenly stopped working
Code F3 indicates an open / defective thermistor / temperature sensor. The first suspects when a microwave is not heating would be the door switches, bad connections on the magnetron terminal or bad connections on the control board. If you or a friend decide to work on it, we have *critical* safety, disassembly, and troubleshooting info (as well as a text file which helps in diagnosing and repairing door switch problems) at our site, which is linked at our listing here on FixYa: http://tinyurl.com/yzjozk
Jun 25, 2007 | Kenmore 61652 Microwave Oven
Whirlpool GH5184XPQ Microwave Oven Logo
709 people viewed this question
Top Whirlpool Microwave Ovens Experts
William Miller
William Miller
Chuck
Are you a Whirlpool Microwave Oven Expert? Answer questions, earn points and help others
